Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
User Name
Password
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Parts on Ebay
Reply
Thread Tools Display Modes
Old 04-10-2012, 05:00 PM   #1
Rogue56
Member
Member #224
Default Troubleshooting a backfire
As all things come to pass, I was just to the point of being able to drive my 56. The paint was just finished, I put all the newly polished stainess on the body, the 700R4 tranny was attached to my (fairly new) 454 crate motor. And then as you probably can guess, something went wrong. The motor - 454 510hp used to run flawlessly but when I tried to start it a couple of days ago, it started backfiring throught the carb. I figure timing is off. I also heard some tappet noise on the passenger side. Anyway, I checked the timing. At idle it sounded fine with no backfiring. When I upped the rpms, it started backfiring. I checked the timing and it was at 16 btdc, just where I had set it before. I loosened the distrib and turned it a bit to see if I could get the backfiring to go away, no luck there. I put in new plugs and checked the plug wires, dist cap, and rotor and they all looked good. As a matter of fact, I've probably only got about 50 hours on the motor total. It's just taken me years to get it to the point I was able to drive it.
I took off the valve covers and found that the #8 intake & exhause roller rockers were loose, so I did a static valve adjustment on the whole thing. I did notice that the #6 exhaust push rod only opened the valve about 1/4 inch where the others were a good 3/4 inch. I took a compression reading on all cylinders and they were at 145psi.
Sooooo, my question is is there anything else I might be able to check to find the backfire problem. Would the #6 exhaust valve not opening all the way cause the backfire problem. I guess it's possible the new cam has a flat lobe and that's why the #6 exhaust valve is not opening all the way. I haven't checked the oil for metal yet, but will do that within the next day or two.
Any suggestions/advice anyone might have is GREATLY appreciated.
Thanks. Steve
__________________
We're not in kansas anymore Toto.
Rogue56 is offline   Reply With Quote
Old 04-10-2012, 05:23 PM   #2
hawaiian
Member
hawaiian's Avatar
Member #19837
Default
What type of lifters do you have? If it's Hydraulic you might have a broken spring in the lifter.
hawaiian is offline   Reply With Quote
Old 04-10-2012, 07:57 PM   #3
dennisk
Senior Member
Member #5365
Smile
Thanks. Steve
I took my'56 out for a drive this past Saturday. It started backfiring and running really bad. it was the first time it had been driven in over two (2) months. The gasoline in the tank had also been in there for two (2) months. I filled it up with fresh gasoline and drove it really hard. The backfiring did stop after the fresh gasoline! I also discovered that the negative cable on the battery was loose! Maybe my backfiring was bad gasoline? The loose negative cable or the combination?? Dennis
dennisk is offline   Reply With Quote
Old 04-10-2012, 08:05 PM   #4
mickeywestsr
Trifive Leaders Club
mickeywestsr has made a donation to the forum!
mickeywestsr's Avatar
Member #1970
Thumbs up
If not a broke spring I'd worry about lobbed cam.
__________________
GO VOLS
COWBOY
mickeywestsr is offline   Reply With Quote
Old 04-10-2012, 08:16 PM   #5
Big Bob
Big Bob's Avatar
Member #19595
Smile
A few things to check for this backfire problem would be a lean
carb mixture,choke too lean and eng. cold, two mixed up spark plug wires,or
leakage across the dist.cap may cause backfire by enabling spark
to occur in a cyl. which is on its intake stroke.Hope this helps.
Big Bob
Big Bob is offline   Reply With Quote
Old 04-12-2012, 08:48 PM   #6
HYPURR DBL NKL
Senior Member 1 Silver Star
HYPURR DBL NKL's Avatar
Member #9112
Default
I have seen bad gas cause this, have no intelligent explanation for it, other than I've seen it before. Only other thing I can think of is an exhaust valve hanging open, will let it back fire through the carb. Check the plugs, they can cause this too. Keep us up to date, kinda curious to see what ya find, good luck! Forgot to answer your other question, exhaust valve won't cause carb backfire, intake valves will.
Phil
__________________
Phil's '55 11.22 @ 117 N/A.
HYPURR DBL NKL is offline   Reply With Quote
Old 04-12-2012, 10:09 PM   #7
BADD55
Senior Member 1 Gold Star
BADD55 has made a donation to the forum!
BADD55's Avatar
Member #5166
Unhappy Bad and Sad News!!
Hello there Rogue56, I hate to be the bearer of bad news, but I think you have a worn out camshaft!!---You have just described classic symptoms, of a wiped out exhaust lobe on the cam!!---The reason it starts popping or backfiring as you try to accelerate the engine, is the exhaust valve is not opening enough to expell all the spent exhaust gasses for that firing cycle, so when the intake valve opens on the intake stroke, it trys to send the trapped exhaust gasses back out the intake,because that's the only place they have to go, this is the popping you're hearing!!--The more RPM the engine has the more rapid and louder the popping gets!!---Good luck milton
__________________
Milton's 55--6.62et @107mph---1.50 60ft.---1/8 mile on pure motor!!---SBC
BADD55 is offline   Reply With Quote
Old 04-13-2012, 04:01 AM   #8
1956 Sedan Delivery
1956 Sedan Delivery's Avatar
Member #4798
Default
Quote:
I agree about the cam or a broken exhaust rocker could do the same.
1956 Sedan Delivery is offline   Reply With Quote
Old 04-13-2012, 08:33 AM   #9
TheHotrodHandyman
TheHotrodHandyman has made a donation to the forum!
TheHotrodHandyman's Avatar
Member #8438
Default
The #6 exhaust valve not working properly is likely the cause of your backfire. Now you need to find out why it is not opening all the way and you will find the real problem.
__________________
-Bruce
TheHotrodHandyman is offline   Reply With Quote
Old 04-13-2012, 12:52 PM   #10
tewitt1949
tewitt1949's Avatar
Member #10798
Default
Quote:
I had the same problem years ago and I had some lobes wore off the cam. Since your push rod is loose, something is wearing to give you extra clearance.
One other time I had a motor (stock 350-350hp) that run great. After I run it hard for a race, I could hear a weird noise out the exhaust. To make a long story short, I lost 2-3 c-clips of the top of my hydrolic lifters. After running it hard the lifters would pump up a little more and hold the those 3 valves open a hair. By the time I got it slowed down the lifters went back to normal and valves went closed. That was a hard one to find what was going on. Didn't pop out the exhaust or out the carb.
tewitt1949 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
