| Trifive Power Steering - Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions |
#1 |
Senior Member 1 Silver Star
I put 500 steering box in my 55. Do I need a differant pitman arm or other linkage?
#2 |
Senior Member 3 Gold Stars
No everything else will work
#3 |
Senior Member 1 Blue Star
I believe you need to use a pitman arm from a manual box-if you had original power steering, you will need to get a pitman arm for a manual box...correct me if I am wrong!
__________________
Mike |
#4 |
Mine is off a manual box. The reason I was asking was because the pitman arm only slides on to the shaftabout a 1/4". Don't really want to put the nut on and force it up the shaft and screw something up.
#5 |
You have to align the splines for it to go up.
#6 |
#7 |
If the splines are line up just install the nut and tighten it up I dont know the torque spec for it but with mine after the nut was install I had about 2 or 3 treads showing when tighten up, hope this helps you out. Are you sure you have the pitman arm not upside down its a taper shaft when installing it make sure the ball is up for the linkage. Later Bill
#8 |
If it is a used pitman arm (sometimes even a new one), you might have to hit the splines with a file to clean them up...still takes a bit to draw them together. Make sure it is lined up correctly and tighten 'er down.
__________________
Mike |
#9 |
Ok, I think I got it . got a flash light up in there, and its going on farther than I thought.
#10 |
Trifive Leaders Club ![]() |
It may not go all the way up on the splines, but you should have 2-3 threads showing after you install the nut and torque it.
| Thread Tools | |
| Display Modes | |
