Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Steering , Power and manual- Rack & Pinion - 605
User Name
Password
Trifive Steering , Power and manual- Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Parts on Ebay
Reply
Thread Tools Display Modes
Old 06-10-2012, 12:10 PM   #1
carshowleo
Member
Member #10380
Default Easiest way to clearance frame for CPP 500?
I am replacing the 605 steering box with a CPP 500 and have a clearnace issue with the frame. The instructions mention that some frames need to be clearanced and of course that is my case. The interference is where a weld attaches the crossmember and front frame. The car is done but I have the motor and transmission out at this time. I feel that if was heated and dimpled it could work but there are brake lines in the area. The other option cosidered was to grind away the area but worried this will comprmise the welded frame area. What have the rest of you done to overcome the clearrance issue?
carshowleo is offline   Reply With Quote
Old 06-10-2012, 12:27 PM   #2
roger1
Trifive Leaders Club
roger1's Avatar
Member #5484
Default
__________________
'55 Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed September 2012
'57 3200 Pickup - 305 TPI / 700R4, Restomod Completed October 2015 PROJECT THREAD
Photo Albums
Note: Sorry, the site now requires that you must sign up as a member in order to view my albums.
roger1 is offline   Reply With Quote
Old 06-10-2012, 12:31 PM   #3
557B210
557B210 has made a donation to the forum!
557B210's Avatar
Member #5571
Default
Leo....Do you have a one-piece or two-piece frame? On my two-piece frame a good ding with the sledge hammer did it.....However, on my one-piece frame, I had to grind the weld down for clearance....Below is a photo of the one-piece frame with the CPP500 box installed.
__________________
_______________________________
-I have a vast data base of TriFive restoration & upgrade articles for our members' use....Send me a PM with your requirements and I'll strive to provide what you need...Please include your email address and the topic
-Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is offline   Reply With Quote
Old 06-10-2012, 01:18 PM   #4
carshowleo
Member
Member #10380
Default
It's a one-piece frame so I'll try a hammer like Roger's and then break out the grinder to make it fit like your photo. Thanks guys.
Old 06-10-2012, 01:35 PM   #5
TheHotrodHandyman
TheHotrodHandyman has made a donation to the forum!
TheHotrodHandyman's Avatar
Member #8438
Default
Most every install of a CPP 500 box on a 1 piece frame has this issue, Nothing a little heat and a hammer or a bit of grinding can't cure. I just went through it yesterday on a 55 with a 1 piece frame. I have never had a clearance issue with the 2 piece frames.
__________________
-Bruce
TheHotrodHandyman is offline   Reply With Quote
Old 06-10-2012, 02:47 PM   #6
jbchevy3
Member
jbchevy3's Avatar
Member #21011
Default
I used a Zizz wheel or cutoff wheel and cut a V shaped notch out to clear mine, worked great.
jbchevy3 is offline   Reply With Quote
Old 06-10-2012, 03:06 PM   #7
carshowleo
Member
Member #10380
Default
Thanks POPS and everyone else for the feedback. Ground a bunch of steel out and it fits. Now it's time to finish installing the 383 stroker with 200-4R and get this '55 back on the road.
Old 06-10-2012, 11:26 PM   #8
Fiddy5Coupe
Senior Member 4 Gold Stars
Fiddy5Coupe's Avatar
Member #3076
Default
Leo?, is it Leo? Anyway, did you find that you need to shim it as well to line up with the steering column? Mine's off by a 1/4 inch, maybe more.
Fiddy5Coupe is online now   Reply With Quote
Old 06-11-2012, 12:19 AM   #9
557B210
557B210's Avatar
Member #5571
Default
Quote:
Had to shim mine as well.....Its covered in the Assembly Manual here:http://www.trifive.com/garage/57%20C...Manual/9-3.gif
__________________
Old 06-11-2012, 08:10 AM   #10
Old Buzzard
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
Default Me too....
Quote:
A couple shims... GTG...
__________________
Chuck
Injector inspector.
55 210 sedan/ LQ9 tyrfryer..:evilgrin0002:
Hotrodding and dragracing since 1955.:eek:
USAF 1960-1964
Old Buzzard is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
