Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Hi Performance
User Name
Password
Mark Forums Read
Hi Performance Tell us your stories. Ask or answer questions, or just say hello.
Reply
Thread Tools Display Modes
Old 01-19-2006, 12:26 PM   #1
Tenn210
Senior Member 1 Blue Star
Tenn210's Avatar
Member #37
Default No tub - traction ?
I really don't want to tub my 55 and I'm wondering if I can get a big enough tire in my stock wheel well for the track. Does anyone have any suggestions as to what tire and size to get? AND, am I wasting my time and $$ trying to stay within the stock wheel well?
I'm not going to be a hard core racer but I would like to make a few track passes on test and tune nights. I should be making 400-425 rwhp when my mods are complete.
Thanks.
__________________
Tennessee210 Coffee drinkers are better thinkers...I just haven't had enough.
Tenn210 is online now   Reply With Quote
Old 01-19-2006, 12:52 PM   #2
MikeKy55
MikeKy55's Avatar
Member #10
Default
These cars vary a little from one to another. But you should be able to get a 255/60R15 on it. Back spacing is important. I think? mine are 4.5 backspacing.Thats what I have and it's pretty close. In fact before I added the traction bars if I went into a curve 10MPH over the posted limit, they rubbed the inside of the quarter panels a little. I have the old style slapper bars that bolt to the bottom of the springs and clamp toward the front of the axle.
Some say moving the springs under the frame rails, but they won't gain much if any without at least doing a mini tub.
I'm with you though, I couldn't bring myself to cut one of these cars. Save that for the rust buckets. BUT, that's my opinion and others see it differently.
Mike
__________________
''Thank a police officer for being the one who runs to a report of 'Shots Fired' while others run away.''
http://www.youtube.com/watch?v=8QuJeYqNzew
MikeKy55 is offline   Reply With Quote
Old 01-19-2006, 01:48 PM   #3
Tenn210
Tenn210's Avatar
Member #37
Default
Thanks Mike. I currently have 265/60/15's (I think) and they fit pretty nice but I would still like some input from some folks that have had some track time. I will soon be replacing my 10 bolt with a strong 12 bolt or 9" and would like to know if I will be able to get enough traction without tubbing. Thanks,
__________________
Old 01-25-2006, 08:07 PM   #4
ih8rice
Senior Member
ih8rice's Avatar
Default
If you can manage to squeeze a 275/ 60 drag radial in there it would be nice members on another board says it can be done with a 7" wheel with 3 3/4" bs. I cant verify that, you could certainly hook that much power on an 8" slick with tractionbars, but thats alot of power and I like to have some meat under me at 110 mph
edit: can I talk you into a minitub?
ih8rice is offline   Reply With Quote
Old 01-27-2006, 09:41 AM   #5
Tenn210
Tenn210's Avatar
Member #37
Default
I don't know about the mini-tub. I already have my car painted and trunk is so purdy. I'll look at the drag radials or maybe get an extra set of wheels with slicks for fun night.
__________________
Old 02-11-2006, 02:29 PM   #6
jaspermaggie
Member
Member #79
Default ok this it it
I have a 4dr that gets the front off. No sway bar in front and Lakewood street/drag shock. This will make the front jerk up for distrabution, the shocks will keep it up. Use lake 55/50 shocks in the rear. It will sqat down and put you in the back seat. You must use a traction bar adjustable is better. You can use a rear sway bar. With the sway it will drive better on the hiway and keep the rear from twisting on green lights. I use a 245/60/15 bfg et street drag at 12-16 psi at the strip and 30 for street. This will work and all bolton. I run a 283 with about 400hp with a 3000 rpm stall and a th350 auto air shift.
This is great for the strip. If you put a front sway for street it will be awsome, take it off at the strip. Traction = distrabution and psi. If you just did the psi you will be better at the track and it is cheep. Put a 1800 rpm stall later good street/strip could drive everyday. The stall will be like NOS on a 425hp.
danchuck Helwig sway bar (big) also have traction bars
jaspermaggie is offline   Reply With Quote
Old 02-11-2006, 02:33 PM   #7
jaspermaggie
Member
Member #79
Default slicks
If you get slicks it will put you in a different class. The problem with that is track inspection. Might need drive shaft loop 3" seat belts helmet and more. Same car just slicks. Use the street drad BFG.
Old 02-20-2007, 09:33 PM   #8
twolaneblacktop
twolaneblacktop's Avatar
Member #594
Default Go ahead, minitub that thing!!!
My 55 is mini tubbed with a 28 x12.50 Mickey Thompson E.T. street. I added 4 to 5 inches to the inner fenders with adjustable ladder bars and coil overs instead of the leaf spring side swap often used. The E.T. street with the equilavent to a 275/60 on a 7'" rim should hook the horsepower you have. I don't think a 8" wheel will fit and I also prefer a lift bar instead of the "slapper bar" style traction bar. As far as rearends go I would install the 9" ford. 12 bolt chevy's are hard to find, expensive, and unless you put C-clip eliminators in it they can come out and destroy that pretty quarter panel if an axle breaks......Learned the hard way, I destroyed a 67 Camaro quarter with a broken stock axle.
twolaneblacktop is offline   Reply With Quote
Old 04-07-2007, 09:15 AM   #9
Johnny Blaze
Senior Member
Member #159
Default
Sure you can hook with out tubbing.
Good springs, shocks and lift bars, like cal tracs.
Slicks you will need to run a DS loop, but its a good idea anyway.
Drag radials are good, on the right car. Your chassis has to be set up prefect or they will not work well. Theyalso do not work well on stick cars.
Look at OSCRA, there are lots of cars running stupid fast on 10" slicks.
In fact our track has a class that is limited to a 26"x8.5" slick and they are running in the 5's in the 1/8th.
So, yes it can be done.
What is your chassis setup currently?
Johnny Blaze is offline   Reply With Quote
Old 04-11-2007, 06:56 PM   #10
twolaneblacktop
Member #594
Default Where are ya at Johnnyblaze???
What state are you near Johnny Blaze??? I'm near Louisville, Ky and watch the OSCA cars everytime there at our local track!! They added some more classes for the 2007 season that my 55' "might" qualify in..... I said "qualify" not win!!! I just want one of the sticker's on my windshield, would have to make a great picture to hang in my brother's office at the Chevrolet dealership...... Are you near Ky or is the OSCA other places than here??
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
