Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Hi Performance
User Name
Password
Mark Forums Read
Hi Performance Tell us your stories. Ask or answer questions, or just say hello.
Reply
Thread Tools Display Modes
Old 12-22-2007, 05:17 PM   #1
Tuned55
Senior Member 3 Gold Stars
Tuned55's Avatar
Member #92
Default Oil Pressure Gauge
I could use some help with my oil pressure gauge. I am using the Custom Rod Gauges. They all work fine with the exception of the oil pressure. I turn on the key and it pegs. The sender has two terminals and I have swapped the wire to the gauge to both locations. With the sender being a two terminal is there another wire that sould be attached to the "extra" terminal?
__________________
Bruce
Southern Utah
My Build Photos
Tuned55 is offline   Reply With Quote
Old 12-22-2007, 06:45 PM   #2
acardon
Trifive Leaders Club
acardon's Avatar
Member #1888
Default
One wire of the sender needs to go to ground.
__________________
Don
acardon is offline   Reply With Quote
Old 12-22-2007, 07:15 PM   #3
Rick_L
Member #2256
Default
Don may be right.
My Custom Rod Gauges oil pressure sender only has 1 terminal. I'd surmise that it's internally grounded. But if there's a second terminal it almost has to be ground.
Custom Rod Gauges uses VDO senders and movements. If you suspect a bad sender, then you can get the numbers off it and look at the VDO website and get a part number. Then you can get one at a place that sells VDO.
Getting some customer support from Custom Rod Gauges is reputed to be as hard as getting FEMA to New Orleans.
Rick_L is online now   Reply With Quote
Old 12-22-2007, 08:36 PM   #4
Tuned55
Tuned55's Avatar
Member #92
Default
Thanks, I'll try a ground on it.
Ditto on any kind of a response from them. Absolutly no email replies. I have called them in the past about the proper sending unit for my fuel gauge took several tries to get results. The last was a some instructions that should have come with them. I had the gal fax them to me while I had her on the line.
Thanks again
__________________
Bruce
Southern Utah
My Build Photos
Old 12-22-2007, 09:36 PM   #5
Tuned55
Tuned55's Avatar
Member #92
Default
I went out to the shop, ran a jumper wire to the sender and there it was, a fully funtional oil pressure gauge
__________________
Bruce
Southern Utah
My Build Photos
Old 12-22-2007, 09:52 PM   #6
Rick_L
Member #2256
Default
I love a success story.
Old 12-23-2007, 02:08 AM   #7
grandmas55
Senior Member 1 Silver Star
Member #4101
Default
Who needs the jokers at Custom Rod Gauges when you have the guys here at Trifive.com?
grandmas55 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
