Where are you mounting your ECU?
This is the LS section where a ECU is needed. Why not stick to the stock section if this question upsets you.Mine is in my Subaru, don't think they needed them in 1957.
Joe
My PCM is also mounted in the same position.I haven't needed to access it but once in 6 years when adding wires after a swap from T56 to 4L65E.Only the PCM is behind the panel FP relay & fuses are easily accessible.If it was a 58x system then likely I may have mounted ECM & TCM differently do to the smaller size.I located mine on behind the removable right side wheel house lower panel and have lived to regret it. Am chasing a phantom engine control harness problem and although accessing the ECU isn't too difficult the harness connectors and adjacent harness are really difficult to access. In fact it looks like I'm going to have to remove the fender!
Nobody to blame but myself and I rank that decision as about the worst one I made when installing my 5.3. I don't know where the best location is but wouldn't recommend the one I chose.
Not sure how much help higher education would be in this case...Will someone enlighten me on the Proper Spelling and definition of ECU.
I was assuming it had something to do with an Electronic Control Unit.
Maybe I should have taken advantage of a Higher Education but it was not to Be!
