Old 09-12-2017, 10:43 PM   #11
fuzz1957
fuzz1957's Avatar
Member #12196
Bob,
What you have now is what I started with on my 57. Here's what I did. Mine has a Muncie instead of auto. Same problem with exhaust routing. (2.5 inch exhaust pipes coming from rams horn exhaust manifolds). Bought the one like Acardon posted. Same problem, not enough clearance. On to plan C. Took the original one and cut and "notched" it up so exhaust pipes went through the "notches". Since it was made out of square tubing, it was relatively easy to do.
Fuzz
MAGA
American Tri-Five Member #136
fuzz1957 is offline   Reply With Quote
Old 09-13-2017, 03:03 PM   #12
RSpring
RSpring's Avatar
Member #5505
Send a message via ICQ to RSpring
Smile trans mount
Bob, check Jim Myers racing in Oregon,they have a nice adjustable that will fit about 3 combos,, Dick
RSpring is online now   Reply With Quote
Old 09-13-2017, 06:27 PM   #13
tahoe1955
tahoe1955 has made a donation to the forum!
tahoe1955's Avatar
Member #9222
Originally Posted by hotrodg726 View Post
Earl Williams has nice ones at a reasonable price.
Earl Williams is what I used on my 55 Nomad with the 700R, was very happy with it.
tahoe1955 is offline   Reply With Quote
Old 09-15-2017, 03:18 AM   #14
53burb
Member #23232
These our some other crossmembers I have considered. I bought a kit from Performance Online a couple years back and just now getting ready to install it. I have the same crossmember as the OP has. I like these xcrossmembers better for the same reasons. Any experience with either of these kits? The kit from Speedway uses self tapping bolts. Do you think they are strong enough?
Hopefully whatever comments/replies will help the OP & myself.
http://hhclassic.com/i-13874910-tran...od-tab-details
http://www.speedwaymotors.com/1955-5...SABEgLhlvD_BwE
53burb is offline   Reply With Quote
Old 09-15-2017, 12:18 PM   #15
Trifecta
Trifecta's Avatar
Member #33688
This is what I'm expecting today. Hopefully install it this weekend.
Danchuk # 12198
Personally, I think that being tubular will be stronger and won't fatigue. I plan to replace the self tapping bolts with longer bolts that go through the frame.
Bob
Work Hard, Play Fair, Drive Safe, Rock On!!!
Trifecta is online now   Reply With Quote
Old 09-15-2017, 11:06 PM   #16
53burb
Member #23232
Cool...keep us updated please....
Old 09-16-2017, 12:14 AM   #17
Trifecta
Trifecta's Avatar
Member #33688
Note the 1/4 angle bracket mounted to the frame where the current tranny mount is bolted to. This angle bracket will be used to mount the Danchuk 12198 support.
Bob
Old 09-16-2017, 12:48 AM   #18
Danchuk # 12198
Bob
Attachment 157448
do not drill all the way thru the frame. not needed and can cause frame buckling. use a nutsert in the inside wall . the only way to bolt thru the frame is if you put a sleeve into the frame to prevent crush.
Old 09-16-2017, 01:38 AM   #19
Trifecta
Trifecta's Avatar
Member #33688
I see what you mean, but it's too late. The holes were drilled for the other crossmember. The 1/4 inch thick angle bracket will keep the inside from caving in. I may have to use a similar bracket on the outside of the frame. Being 1/4 inch thick and angled will give it a lot of strength.
Old 09-16-2017, 03:13 AM   #20
irishsteve
Member #43450
Think I would weld the ends on,or install with screws,and drive to a welder/muffler shop,and have them weld.
irishsteve is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
