Machine Shop - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Welcome to Trifive > Project Update Section, Post your Project updates here
Project Update Section, Post your Project updates here This section is for Project Updates only, So post any updates of your trifive projects. >Do not post tech questions in this area of the forum = Remember only projects updates should be posted here.
Old 03-29-2019, 07:09 PM   #11
alaskastreamin
alaskastreamin's Avatar
Member #44195
You should ask him about aligning the lifter bores and sleeving them.
After our boat accident, I spent a several days with our friend in Minnesota who is a machinist. I helped him dyno a 383 to get base line numbers (530hp @ 6800 rpm's. Then tore it down, reamed the lifter bores to be in perfect alignment with the cam lobes. He then installed sleeves that extended into the cam tunnel and up into the lifter valley some. This gave more sidewall for the lifter to bear on. Also (this was interesting), He machined a groove in the bushing. I asked why? He said,.. Do you remember when we were on the dyno and the oil pressure was bouncing? That was because the high lift cam was pushing the lifters higher than the oiling grooves were in the lifter. Every time a lifter goes full height, the oil passage is blocked off for a split second. Take this times 16 lifters and the pressure gauge bounces.
By adding the groove in the bushing, the lifter gets oiling 100% of the time.
Also by truing up the bores, the roller will sit flat AND centered on the cam lobe.
This was the only modification he wanted to do for this test. 24 hours later we had the motor back on the dyno. Oil pressure was rock steady and after re-adjusting the timing and jetting for the modification, he gained 38 hp!!
This work was done oct. 2016 and he submitted the article that was in engine builders magazine sometime in 2017.
There are other things he does that just amazes me. This modification is relatively cheap and is a great bang for the buck.
Ron Pratt
Sitka Alaska/ Okanogan Washington
'55 2 door post Belair
'37 Chevy Sedan delivery
'34 Ford 3 window coupe Blower motor
'68 AMX BBC Blower motor
(Few others)
My '55 build thread: https://www.trifive.com/forums/showthread.php?t=180548
alaskastreamin is offline   Reply With Quote
Old 04-11-2019, 12:25 PM   #12
Bobby's prostreet56truck
Bobby's prostreet56truck has made a donation to the forum!
Bobby's prostreet56truck's Avatar
Member #10227
Default Update
Well seams as though I will be putting more into my big block than I had thought. It has to be bored out, so much for using the stock stuff in it. He said he will need to 0.30 or 0.40, He is going to do a rough cut then check it. Anyone out there that needs some stock bearings and rings for a 402 I have them.
I Like Shiny Stuff!
Bobby's prostreet56truck is online now   Reply With Quote
Old 04-11-2019, 01:24 PM   #13
ETriggs
Trifive on Facebook Admin
ETriggs has made a donation to the forum!
ETriggs's Avatar
Balloon Park Champion! Othello Champion! JigSaw Puzzle Monkey Champion! Smack-n-Bash Champion!
Member #1133
Send a message via AIM to ETriggs
I've gotten to the point where I expect every motor I take in to be bored one size larger than what it was.
Eldon Triggs
1957 Bel Air Sport Sedan "Bertha"
ATFA Charter Member #270
ETriggs is offline   Reply With Quote
Old 04-11-2019, 06:38 PM   #14
Member #10227
I am thinking this will be the last one I ever build. But I have said that before Lol.
I Like Shiny Stuff!
Old 04-11-2019, 08:31 PM   #15
Churchkey
Churchkey's Avatar
Member #25539
Sounds like you have found a competent shop.
I use Roberts on Bonnie Oaks in Chatt
Churchkey is online now   Reply With Quote
Old 04-11-2019, 08:43 PM   #16
a 375 hp factory 402/396 has a pretty high compression ratio, rectangular port heads and is not happy on todays gas. they also don't make much power down low where you need it on a street car. You might want to re think your build particularly compression and cam combo.
1956 210 delrey sedan 383 700r4 12 bolt posi
1968 Camaro 468 bbc power glide 12 bolt
1968 Camaro 408LS power glide 12 bolt super gas
1971 el Camino 383LS 700r4 12 bolt posi
still searching for the right 56 nomad project.
Old 04-11-2019, 09:18 PM   #17
This comes under the category of NOMB John....I'm curious as to how you would recommend Bobby build his engine.
* See my painfully slow and overly detailed build thread here: https://www.trifive.com/forums/showthread.php?t=79427
* I have a vast data base of TriFive restoration & upgrade articles for our members' use...Send me a PM with your EMAIL ADDRESS and subject matter...See this link:
* Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
_________________david aka POPS & sherry
Old 04-11-2019, 11:04 PM   #18
I would pick a cam like a comp extreme energy 268 or 272 and keep compression around 9.6 to 1 .
Old 04-12-2019, 10:49 AM   #19
Sounds like a good streetable combination to me.
What heads would be the best?
Old 04-12-2019, 12:03 PM   #20
honestly the rect port are over kill and the engine will be lacking in bottom end like most rect port engines do, a good open chamber oval port would be a much better choice.
Similar Threads
Getting Closer, machine shop called hddude Super Stock / Pro Street and Modified Discussion 55-56-57 18 03-18-2010 09:39 PM
NorCal machine shop? dennis55 Chit Chat Area, Anything on your mind goes here. 16 02-24-2009 11:05 PM
Machine shop in Virginia Beach Area 03ac Hi Performance 1 01-02-2009 02:10 PM
machine shop in WA tattooedSGT Classic Repair & Restoration Body Shops 5 11-02-2008 05:37 AM
machine shop shawnmil Classic Repair & Restoration Body Shops 6 02-29-2008 09:23 AM
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
