PS help needed - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Steering , Power and manual- Rack & Pinion - 605
Trifive Steering , Power and manual- Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Old 05-04-2019, 07:27 PM   #1
Mr. Fink
Member #48570
Default PS help needed
My uncle is working on a 55 Nomad. He installed a 500 PS kit. The pump he has gotten was for a blazer. He cranked and broke in his engine earlier this week. Steering wheel will not turn left or right. Fluid is full. Al the equipment is new. Any thoughts or suggestions?
Mr. Fink is offline   Reply With Quote
Old 05-04-2019, 07:42 PM   #2
Will the wheel turn with the engine off and tires off the ground?
Are the pressure and return lines reversed. The pressure port is the larger one on the box.
Old 05-04-2019, 07:49 PM   #3
Possible air in the system....There are specific P/S break in procedures...
Originally Posted by Rick_L View Post
I would use only GM approved power steering fluid in any p/s conversion such as a CPP or Borgeson box or a rack. Stock p/s works ok with Dexron ATF.
You should start the bleeding procedure by jacking the front end off the ground, filling the p/s reservoir, and turning the steering wheel through its whole travel 3 or 4 times - with the engine not running. Top off the fluid as you go, and don't let the reservoir go completely dry. Only then should you start the engine and repeat the process, again making sure that there is always fluid in the reservoir. Doing it first with the engine off does two things. It gets the fluid everywhere before you start the engine. If you don't do that it's very easy to have the reservoir run dry and suck air when you start the engine. And it won't take as long to get the job done.
Old 05-05-2019, 09:06 AM   #4
Mr. Fink
Member #48570
Thanks for all the suggestions. I will talk with him and report back. Thanks again.
Old 05-06-2019, 12:22 AM   #5
Jalapeno
Jalapeno's Avatar
Member #4149
I agree, I think the pressure and return lines are reversed.
The clamp-on hose on the pump goes to the small connection on the gear.
Jalapeno
Jalapeno is offline   Reply With Quote
Similar Threads
Converting old PS to new PS (?!?!) JosephCallery Trifive Steering , Power and manual- Rack & Pinion - 605 4 06-25-2009 12:55 PM
Changing 57 factory PS to non-PS? bfr57 Stock Chevy Discussion 55-56-57 14 12-14-2008 10:07 AM
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
