My old current testor not good. - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Metal Fabrication & Repair Questions > Welder advice, Hand tool Advice Shop Tool.
Welder advice, Hand tool Advice Shop Tool. This is a section to ask for help/advice on all your tool questions. What welders work best and what shop tools work best, How to use a welder, and any other tools. Remember if you have tools for sale they should be put in the classifieds.
Old 05-31-2019, 10:46 AM   #1
bsa_bob
bsa_bob's Avatar
Member #19942
Default My old current testor not good.
Mine has a wire attached ,that you hook up to ground, then touch for"live wires" with the tool part of it.A fellow in my garage" had one. I should have asked; where he got it,it appeared -He just touched wires with JUST the tool part, and didn't use a wire to ground.We got on another subject and I..................................forgot to ask. Would you know anything about this testor?where i might find a good one? thanks bob s
This one i have- is the only one i ever had.
55 chevy 2-dr sedan. slow build -I ain't 60 anymore
bsa_bob is offline   Reply With Quote
Old 05-31-2019, 02:28 PM   #2
davidc
davidc has made a donation to the forum!
davidc's Avatar
Member #9348
Bob, I have a 12v tester that looks like an ice pick with a wire to attach to ground. I also have a "no contact" tester for higher voltage (120/240v) for around the house. No wires attached. I do not think it will detect 12v in a car.
davidc is offline   Reply With Quote
Old 05-31-2019, 04:07 PM   #3
bsa_bob
bsa_bob's Avatar
Member #19942
Yours sounds just like mine. thank you davidc==bob s
Old 05-31-2019, 09:46 PM   #4
angs1957
Super Moderator
angs1957 has made a donation to the forum!
angs1957's Avatar
Member #2237
The tester with a ground strap is all you need to do a quick check to see if power is present or not.
If you want to do a bit more and measure what your actually testing then you need to upgrade to a multi-meter as you have more options to perform more tests.
angs1957 is offline   Reply With Quote
Old 06-01-2019, 07:52 AM   #5
55 Tony
Member #22177
I just noticed the other day that they now make voltage test lights with LED's instead of a bulb. Problem is that it will work even with a very very poor positive connection with a high resistance. The current it takes to light the old style lamps is what makes them better than using a volt meter at times. The new ones defeat that purpose. New technology gone bad.
1955 Bel Air Sport Coupe
55 Tony is offline   Reply With Quote
Old 06-01-2019, 08:31 AM   #6
bsa_bob
bsa_bob's Avatar
Member #19942
Thank you fellas for the good tips -keep what I got! ~~~~~~~ see ya next time bob s
Old 06-01-2019, 10:17 AM   #7
abdiver7777
abdiver7777's Avatar
Member #35808
One other tip for chasing voltage on 12v systems with a test light....
Grab a few straight pins and simply push into the wire you are checking if there aren't any convenient exposed terminal sand then use the pin as a contact point for your test light....
The higher quality 12v test lights had a very sharp point for this purpose but The straight pin leaves a much smaller hole in the insulation.....
Another tip....
A small 12v bulb with wires soldered to the base and power point can be used in series of a wire to check for any parasitic draw of a 12 volt system.
I always start at the battery terminal for that one.... Radios and clocks draw power so that's the first fuse to pull....
abdiver7777 is offline   Reply With Quote
Old 06-02-2019, 08:17 AM   #8
bsa_bob
bsa_bob's Avatar
Member #19942
Another tip....
Thank you much abdiver 7777 bob s sounds good
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
