Edelbrock Fuel Line Kit - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Old 06-04-2019, 01:23 AM   #11
55Madman
55Madman's Avatar
Member #48606
Pops, I used a 90 degree street elbow and short hose nipple on the upper hose along with a 'thick' gasket from Edelbrock to help dissipate heat between my carb and Performer intake. More significantly however was that I did not use the fuel filter on the end of the carb line - just a brass nipple with the proper flare. The elbow doesn't really help with the appearance factor of the engine compartment - for that matter neither does the placement of the filter or the fuel regulator. But for me it's a reliability issue on that car (the '38). I'm a ways away from figuring out how to plumb things on the Nomad...
JR
55Madman is offline   Reply With Quote
Old 06-04-2019, 01:56 AM   #12
Speedi D
Member #11974
Originally Posted by Geo57 View Post
I don't know if anyone else has had this problem, but I am trying to install an Edelbrock fuel line kit. The problem is when the fuel filter is attached, it butts up to the heater hose connection on the intake manifold. There is no way to attach the fuel line to the filter.
George
I use this kit, don't have a problem - misses the hose fitting by 1/2". However I do use a 3/8" spacer under the carb as suggested by Wayne, post #10. In my case the Edelbrock carb tended to suffer from heat soak in the summer without the spacer so solved 2 problems..
Speedi D is offline   Reply With Quote
Old 06-04-2019, 10:00 AM   #13
Any recommendations on carburetor spacers?....I haven't bought one yet.
557B210 is offline   Reply With Quote
Old 06-04-2019, 01:12 PM   #14
Ace57
Ace57 has made a donation to the forum!
Ace57's Avatar
Member #12242
This is the one I'm using on my ZZ4...so far so good....starts/runs great cold or hot engine.
https://www.summitracing.com/parts/e...SABEgJdAPD_BwE
I'm also using that Edelbrock fuel connector, but didn't opt for their filter. I went to a finer micron "fuelab" filter (mounted further down the fuel line between carb and pump)
Ace
ZZ4/700R4/FORD 9"
Ace57 is offline   Reply With Quote
Old 06-04-2019, 01:21 PM   #15
Thanks Ace...I also see they have a .5" one as well:https://www.summitracing.com/parts/edl-8723
Old 06-04-2019, 02:07 PM   #16
Speedi D
Member #11974
Open plenum adds to bottom end, 4 hole adds to top end. Increment not much, by itself probably unnoticeable in street engine. Thickness may be more noticeable on the street, esp if a thicker spacer is used - 1 1/4 to 1 1/2 and up. Again, these are small details none by themselves will set you back in the seat.
Old 06-04-2019, 10:42 PM   #17
55Madman
55Madman's Avatar
Member #48606
At a Goodguys event a couple of years ago I struck up a conversation with the guys from Edelbrock...mostly about the transition surging the 1406 is prone to, but when I mentioned I was also concerned about heat soak one of them handed one of these to me (free gratis) and said it would take care of the issue. It did. Edelbrock #9265, .32" thick nitrile rubber. JR
Old 06-04-2019, 10:49 PM   #18
Thanks Madman...Found it at Summit: https://www.summitracing.com/parts/edl-9265
Old 06-05-2019, 06:01 AM   #19
hddude
hddude's Avatar
Member #10516
yup, that`s the one i use, madman.
hddude is online now   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
