Weeping proportioning valve help please - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Old 07-23-2019, 02:50 PM   #1
davlin56
davlin56's Avatar
Member #29204
Default Weeping proportioning valve help please
After having difficulty getting the brakes in my panel truck to bleed, we discovered the old OEM proportioning (combination) valve was rusty and corroded inside. I replaced it with a new brass one from a local supplier, which remedied the bleeding problem, and the brakes work fine. The problem now is I have fluid weeping from around the reset pin on the front of the valve. A search on the internet would suggest that this is quite a common problem. I'm using DOT 5, so I'm not worried about paint. It's more of an annoyance than anything else. There's a small rubber cap that goes over the fitting housing the pin. I'm wondering if I clean off the fluid residue, put a small dab of urethane or silicon in the cap, stick it back on and let it cure, it may stop the leak. Has anyone tried this? Or is this a bad idea and I should replace the entire assembly? If I can solve the problem and avoid having to re-bleed the system, that would be great. But I don't want to be putting a Band Aid on a bigger problem. Suggestions?
davlin56 is online now   Reply With Quote
Old 07-23-2019, 05:25 PM   #2
Ace57
Ace57 has made a donation to the forum!
Ace57's Avatar
Member #12242
This happened to me years ago. It was a CPP proportioning valve, and because they are not too far from where i live, I took the P-valve off my car and took it by their warehouse/store and they removed the front metering valve and put a new one in. The leaking stopped. (it had nothing to do with the rubber boot, it was the valve.) He told me I didn't need to remove the entire P-valve to fix it ...which implied I could have brought the car to them, had the metering valve replaced while on the car, and not worry about re-bleeding the system.
If your supplier isn't close by, maybe the vendor will send you a new metering valve and you can replace it yourself.....looks like a pretty simple task.
Ace
ZZ4/700R4/FORD 9"
Ace57 is online now   Reply With Quote
Old 07-23-2019, 06:07 PM   #3
SLIM
SLIM's Avatar
Member #18096
I haven't seen that problem for a few years now. Hope it's not back again. I always thought it was the round gasket material at the front that was incorrectly not impervious to gasoline.
SLIM is offline   Reply With Quote
Old 07-23-2019, 07:23 PM   #4
BamaNomad
BamaNomad's Avatar
Member #31544
One of my friends drove his newly (2 yr old) restored Nomad to Omaha from TN and before he arrived there, the combination valve failed on his car... He spent Sunday and part of Monday going thru all that. Apparently CPP's combination valves are also poorly designed/fabricated...
Calling a combination valve a proportioning valve is a misnomer; the proportioning action inside the combination valve is only one of it's functions as they include a safety switch if a cylinder fails, and hold off function, (metering valve), as well as the proportioning function. I've never heard of a true 'proportioning valve' failing by leaking...
BamaNomad(er)
'55, '56, '57 Nomads
North Alabama area
Gary
BamaNomad is online now   Reply With Quote
Old 07-23-2019, 09:39 PM   #5
Ace57
Ace57's Avatar
Member #12242
I'd like to think someone other than CPP offers a brass combination valve that is higher quality, but suspect they might all come from one Chinese manufacturer....
Does anyone know of one that is better quality?
ZZ4/700R4/FORD 9"
Old 07-23-2019, 10:27 PM   #6
astroracer
astroracer's Avatar
Member #32299
It's the metering valve. There is a couple of rubber seals in the assembly that split and start leaking. You will not seal it up with anything smeared on, it is under pressure when you step on the peddle.
Here is the link:
http://www.classicperform.com/Store/...ucks/PV-MV.htm
Call CPP and verify this will work with your prop valve. They have them and they are only 10 bucks or so. I ordered two when mine went out.
I replaced the valve, topped off the fluid and had the brakes back good as new after a half mile or so.
Mark
astroracer is offline   Reply With Quote
Old 07-24-2019, 12:06 PM   #7
davlin56
davlin56's Avatar
Member #29204
Thanks for the input guys. Ace57 & astroracer, that's exactly the information I was looking for...a relatively simple solution without tearing it all apart!! The supplier is really good at backing their products. I'll see if that's a part that they carry. Once I have one I'll swap it in before we hit the road to Bowling Green.
This forum and the people on it are AWESOME!!!
Old 07-24-2019, 02:26 PM   #8
SLIM
SLIM's Avatar
Member #18096
Once it's repaired, by any method rebleeding will be necessary. When fluid leaks from anywhere in system air has entered.
Old 07-24-2019, 02:50 PM   #9
mr55/56
Member #25615
I robbed a 79 Z28 and 75 Chevelle parts cars for my valves, no issues yet.
mr55/56 is online now   Reply With Quote
Old 07-24-2019, 03:01 PM   #10
nhramike57
nhramike57's Avatar
Location: Edmonton, Alberta, Canada in the Summer & Mesa, Arizona part time in the winter
Member #6523
Wilwood Adjustable Proportional valve.. Compensate for staggered tire sizes and Brake / caliper upgrades. I've had ones in cars over 20yrs ..never fail or leak.
Mopac Performance should stock it in Langley.. $45 CAD.
There is no Substitute for Cubic inch's except Cubic dollars
If you are looking for details on my build so far..
https://www.trifive.com/forums/showthread.php?t=33614
nhramike57 is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
