3925660 Muncie - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Old 08-21-2019, 09:10 PM   #1
Bradt56
Bradt56's Avatar
Member #47578
Default 3925660 Muncie
Hey guys... I have a Muncie that I have no idea what worth? It was freshened up I was told... Worked well when pulled out..Two ears have been welded.. But seems pretty good.. Don't want to rob anyone..And don't want to be robbed..Went to a 700r4... Thanks
Bradt56 is offline   Reply With Quote
Old 08-21-2019, 10:02 PM   #2
BamaNomad
BamaNomad's Avatar
Member #31544
As you've described it, I'd guess in the $400-500 range.
It would help if you included more information in your solicitation: M20 or M21? Year? How did YOU use it? cruising behind a mild motor? or drag racing behind a big block? With the broken ears, and no description of the *parts* or the stampings, then it has no value to a person restoring a camaro or chevelle or ? whatever the trans came from. If you get the numbers stamped on it and get the castings nos from both front and tail shaft housing, # of splines on the output, grooves on the input shaft, take a photo of the gears with the side cover removed, and additional photos of the trans, then That information *might* move it up a notch or two for someone...
BamaNomad(er)
'55, '56, '57 Nomads
North Alabama area
Gary
BamaNomad is online now   Reply With Quote
Old 08-21-2019, 10:31 PM   #3
Bradt56
Bradt56's Avatar
Member #47578
I will have to look for other numbers in morning..Was behind a 327.. Just cruiser.. Thanks for the start anyway
Old 09-08-2019, 01:01 AM   #4
Muncieman
Muncieman's Avatar
Member #15995
Send a message via AIM to Muncieman
Default YOUR 4 SPEED
Just a note about your trans. Any muncie that has had ears welded on should have the face of the case milled flat. MOst all of these cases that have been
welded have lost their flatness and need to be milled a few thousandth to be flat and parallel to the rear of the case.
Muncieman
Please contact me; GARY'S GEARBOX @ 267-424-5838 or email [email protected] for any of your Muncie, Borg Warner, Super T-10 or T-5 questions and needs.
GARY HOWARD aka The MUNCIEMAN
Muncieman is offline   Reply With Quote
Old 09-08-2019, 10:22 PM   #5
topdog
topdog's Avatar
Member #15087
Broken ears are common on the Muncie 4 speed. There is a heavy duty case available as a replacement but welded on ears is common place
topdog is offline   Reply With Quote
Old 09-08-2019, 11:57 PM   #6
BamaNomad
BamaNomad's Avatar
Member #31544
Muncie ears only break when they are being installed by someone who does NOT know what they are doing!
BamaNomad(er)
North Alabama area
Gary
Old 09-09-2019, 08:16 PM   #7
topdog
topdog's Avatar
Member #15087
If that's the case than what is being done wrong. Got any facts to back up that statement.
Old 09-09-2019, 08:36 PM   #8
zookpr
Member #4323
Using the 4 assembly screws as pullers to pull trans into the bell housing with any of the conditions below:
  • Painted bell housings - not cleaning the pilot diameter tightens up the fit.
  • Misaligned clutch disc or beat up pilot bushing (currently in another thread).
  • Installing the trans with an angular misalignment and forcing it.
  • Dings in pilot not inspected and corrected.
others for sure....
zookpr is offline   Reply With Quote
Old 09-09-2019, 10:27 PM   #9
BamaNomad
BamaNomad's Avatar
Member #31544
Yes, the ears get broken when people attempt to pull the transmission into the bellhousing using the bolts, and that is wrong. If the transmission doesn't slip right in without using the bolts to pull it, then the clutch isn't aligned with the input shaft grooves, and trying to FORCE it in with the bolts will only apply too much force to the ears.
One method of getting the transmission to seat all the way into the b/h is to put the trans in gear using the levers on the side and manually 'rotate' the entire transmission by hand (from underneath the car obviously) until the trans slips in. You may have to have some just 'partially' push in the clutch while doing this if the clutch plate isn't properly aligned. partially pushing in the clutch allows the clutch disk to 'slide' a little to align with the transmission. The transmission SHOULD move all the way in until there is contact between the front of the transmission is touching the rear of the bellhousing. If it seems to 'stop' approx 1/4-3/8" from touching, then the input shaft and clutch are not aligned to one another.
BamaNomad(er)
North Alabama area
Gary
Old 09-11-2019, 10:43 PM   #10
Had a few Tri 5's
Had a few Tri 5's's Avatar
Member #6536
Having grease in the pilot bearing that becomes a block when the shaft tip tries to go in. Add that with an impatient 17 year old on his back in the dirt in the dark with a flashlight and a wrench. That will break one of those ears right off.....
Had a few Tri 5's is online now   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Olde Kraken
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
