Ls headers - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > LS & LT Installation Questions and Answers
LS & LT Installation Questions and Answers Special Category just for asking questions about installing a LS Installation in your Trifive Chevy.
Old 08-21-2019, 06:05 PM   #1
56ls408
Member #50214
Default Ls headers
Anyone know if the hooker 2292-1 headers will clear the shift linkage from a column shift going to a 4l65e currently have the patriot shortys but hate the clearance to the 500 box also might pick up a few hp my first time posting 56 bel air 408 ls3 thanks for any answers
56ls408 is online now   Reply With Quote
Old 08-21-2019, 06:58 PM   #2
Old Buzzard
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
Try a search. This has been discussed frequently.
Injector inspector.
55 210 sedan, rust bucket. The last hoorah!
Hotrodding and dragracing since 1955.
USAF, 67th Recon Tech. Yokota AFB, Japan.
6594th Test sqdn, Westover, AFB, MA. The guys that brought you the Cuban missile pics. 1960-64.
Old Buzzard is online now   Reply With Quote
Old 08-22-2019, 12:35 AM   #3
56ls408
Member #50214
Default Ls headers
Thanks for replying yes I tried a search first but couldnít find my specific answer the hooker site states the 2292-1 wonít clear auto column shift just wanted to see if someone had used them with a shortened auto stock column (CPP) mine works fine with the shorty patriot that are now on it thanks again
Old 08-22-2019, 08:22 AM   #4
Old Buzzard
Member #3388
I'm thinking that the interference would/could be w/ the linkage rods, and not the actual column tube.
Maybe, someone will add to the info.
Injector inspector.
Old 08-22-2019, 12:50 PM   #5
56ls408
Member #50214
Default ls headers
Guess I didnít make my question clear yes my concern is whether the linkage between the column shift lever and the trans will clear even with more modifications the long tube headers.I have the shift works linkage kit currently on it which works great except for no reverse lock out always have to be carefull if Iím manually shifting through the gears usually just leave it in drive or manual 3 works well that way thanks Iím going to try & call hooker but not expecting much also going to ask if they have changed theyíre o2 bung locations read that everyone has to reposition them not a big deal except Iíll like to get them already coated
Old 08-22-2019, 01:17 PM   #6
The 2292 headers do clear a power steering box quite nicely. I think they'll clear the arm that's on the column just fine. But the #7 tube does sweep back more than on a typical SBC header so clearance to the linkage rod is a possibility. If you mounted the engine further forward the linkage would probably clear - but of course that might cause other problems like crowding things between the accessory drive and radiator/fans, as well as oil pan to steering clearance.
Keep in mind that the collectors haven't had any flange on them in the past, so if you want them, that's another deal with buying coated headers besides the O2 bung.
Old 08-26-2019, 10:27 PM   #7
56ls408
Member #50214
Default Ls headers
The #7 tube could be why hooker states it wonít work.with the patriot mid length on it now the #7 tube is pretty much straight down & the column lever only misses it by about 1/2 ď or so when pulled down to l1 I wouldnít have enough room to move the engine forward any only about 1/2 to 3/4 between the water pump pulley & radiator electric fan may just have to rework the #3 tube to the 500 steering box for a little more clearance I have heat wrapped now & only about 1/4Ē clearance after dinging it still gets the p/s fluid hot & I cant run a cooler I tried it effects the hydro boost unit because of the restriction through the cooler thanks for the input
Old 08-26-2019, 11:28 PM   #8
How does the cooler provide a restriction of consequence? A cooler is often recommended as a cure for hydroboost problems - so that is a contradiction.
Not saying you're wrong, just that it's a contradiction to other reports. (Wouldn't be the first time.)
The cooler I bought for mine (not tested yet) shouldn't be any more restrictive than a long return line.
Old 08-27-2019, 10:56 AM   #9
BO185
LS Tech and Moderator
BO185's Avatar
Member #1955
Hydroboost return needs to go DIRECTLY back to the Reservoir NOT through a cooler, hence your issues. The cooler only cools the steering gear fliud (which is what gets hot) as most times fluid is by passing the HB internally anyway. EVERY OEM installs hydroboost this way with ZERO issues.
Also Tee'ing the HB into the steering return is asking for trouble. Ideally you want to add a second return for HB to the res. you can connect it to PS return AFTER the cooler with ideally a Y connector. If you have to use a Tee make sure the HD is the straight section of tee to the res.
Install a cooler and install your HB return CORRECTLY which is directly to res and it will fix your PS fluid getting hot.
Also do you run Premium gas with the LS3?
Also you can get a shift dent for 4L60’s its same as 700r4 if using a modified stock column https://www.classicchevy.com/assets/...vy/53-370P.pdf
Four Seasons Metalworks
-CnC Metal art
-Custom Signs
-Custom metal parts
-Powder Coating Services
Gen III/IV "LS" swap info
TECH: LS motor to Early Auto Transmission
Email or PM me your LS questions if you need help
[email protected]
-55 210 delray 235/3sp
-73 IH 1210 Travelette SV392, 5sp, 4x4, 4.10's
-73 IH Scout II Vortec 6.0L 4L65e np241
-01 VW Beetle TDI 50+MPG!
BO185 is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
