LS Header Clearence Issue - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > LS & LT Installation Questions and Answers
LS & LT Installation Questions and Answers Special Category just for asking questions about installing a LS Installation in your Trifive Chevy.
Old 10-11-2019, 03:27 PM   #1
Flynman
Flynman's Avatar
Member #45190
Default LS Header Clearence Issue
I have a Gen3 6.0 LQ9 with PRC cylinder heads and an Art Morrison Chassis. I am putting long tube headers on it and I have some clearance issues with one the header bolt holes that is not being used for this application. The hole sticks out past the block for use with a different engine I assume. The headers are Ceramic coated so I cant knock a dent into it to get the 1/4 inch clearance that I need. I am wondering if I could grind/cut off that ear about 1/2 way through which would leave just a semi-circle portion attached to the head? Wondering if this could cause any cracking or heat disappation issues? What do you think?
Keith R
Flynman is offline   Reply With Quote
Old 10-11-2019, 03:56 PM   #2
Are you talking about the blank hole in the left hand side of the photo?
Yes you can do what you propose, but if you cut/grind on that spot and leave bare steel exposed, it will rust. No harm functionally but surface rust will look bad.
If it was mine I'd leave it alone.
Also with no bolt there, I have to wonder about exhaust leaks. Without a bolt hole for both cylinders, why did they cut the flanges like that?
Old 10-11-2019, 04:06 PM   #3
BO185
LS Tech and Moderator
BO185's Avatar
Member #1955
Just remove the area you need clearance with Radius it to not leave sharp edges and will be fine. The PRC heads have holes on bottom of the head, which are for aftermarket blocks. Won't effect anything on a stock block nor leak exhaust. The head is AL so no issue with rust.
Four Seasons Metalworks
-CnC Metal art
-Custom Signs
-Custom metal parts
-Powder Coating Services
Gen III/IV "LS" swap info
TECH: LS motor to Early Auto Transmission
Email or PM me your LS questions if you need help
[email protected]
-55 210 delray 235/3sp
-73 IH 1210 Travelette SV392, 5sp, 4x4, 4.10's
-73 IH Scout II Vortec 6.0L 4L65e np241
-01 VW Beetle TDI 50+MPG!
BO185 is online now   Reply With Quote
Old 10-11-2019, 04:26 PM   #4
Flynman
Flynman's Avatar
Member #45190
Rick L it's the cylinder head bolt on left bottom. I did not install the missing header bolt on top left yet because header flange won't sit flush and I was just test fitting it. The headers have 3 bolt holes per 2 tubes which matches the header bolt pattern on the cylinder heads.
Old 10-11-2019, 04:29 PM   #5
Flynman
Flynman's Avatar
Member #45190
Thanks BO185!! I thought that was the case, but it doesn't hurt to check with others who have more knowledge!!!
Old 10-11-2019, 06:49 PM   #6
Flynman
Flynman's Avatar
Member #45190
Okay so I cut off about 1/3 of the extra bolt hole and now have good clearance. Just have to shape and smooth it a little bit!!
Old 10-11-2019, 09:50 PM   #7
I missed which hole. I thought you wanted to cut on the header not the head.
Old 10-11-2019, 10:37 PM   #8
personally I would pull both heads and put them on a 90 degree mill table and mill the extra head bosses off flush with the block deck surface. it would look much better that way.
1956 210 delrey sedan 383 700r4 12 bolt posi
1968 Camaro 468 bbc power glide 12 bolt
1968 Camaro 408LS power glide 12 bolt super gas
1971 el Camino 383LS 700r4 12 bolt posi
still searching for the right 56 nomad project.
Old 10-11-2019, 10:55 PM   #9
NickP
NickP's Avatar
Member #2134
Concur
“Luck is what happens when preparation meets opportunity.”
NickP is online now   Reply With Quote
Old 10-16-2019, 02:29 PM   #10
papastoyss
Member #29186
Before I did that I would pull the header & try to saw off the flange w/a air powered body saw like Horrible Freight sells.
papastoyss is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
