Carb size and brand suggestions - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Old 10-16-2019, 09:36 AM   #11
Originally Posted by Bradt56 View Post
So maybe better get cam and carb together? Cam does sound good.. I haven't paid attention to mileage.. Still working out some kinks..just Put in a 700r4... Slowly getting them worked out.. Thanks
So, what carburetor do you have on there now?
* See my painfully slow and overly detailed build thread here: https://www.trifive.com/forums/showthread.php?t=79427
* I have a vast data base of TriFive restoration & upgrade articles for our members' use...Send me a PM with your EMAIL ADDRESS and subject matter...See this link:
* Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
_________________david aka POPS & sherry
Old 10-16-2019, 09:58 AM   #12
mr55/56
Member #25615
If its a speeder get a 3310-1 Holley and a Duntov 30-30, no use for Thumper Cams.
mr55/56 is offline   Reply With Quote
Old 10-16-2019, 10:13 AM   #13
Bradt56
Bradt56's Avatar
Member #47578
It's an Edelbrock 1406 do believe..Big stall converter.. It does cruise down road pretty good it seems.. Just re timed it..But haven't got out on road since have done that (road washed out and car sits lower) stock rears (was 6 cylinder car) re do rear end next year I think.. Thanks again for replys and questions.. I do like to research and opinions help a lot on where to start
Bradt56 is offline   Reply With Quote
Old 10-16-2019, 10:38 AM   #14
un4given
un4given's Avatar
Member #15884
Like Pops suggested.Edelbrock AVS2.I just put one on and am very happy.Ran right out of the box and very easy to tune.Also buy the tuning kit and you will be set.
Kinda Fonda Wanda!
un4given is offline   Reply With Quote
Old 10-16-2019, 11:16 AM   #15
NickP
NickP's Avatar
Member #2134
The formula for calculating how much CFM (cubic feet per minute) your engine requires is: CFM = Cubic Inches x RPM x Volumetric Efficiency ÷ 3456. I'd use 85% on the VE.
“Luck is what happens when preparation meets opportunity.”
NickP is offline   Reply With Quote
Old 10-16-2019, 12:48 PM   #16
JG283
JG283's Avatar
Member #21451
It doesn't answer your question, but the factory rear end ratio was determined by the transmission, not the engine. Of course it could have been changed a few times since it was new.
JG283 is offline   Reply With Quote
Old 10-16-2019, 06:17 PM   #17
Bradt56
Bradt56's Avatar
Member #47578
That's kinda why was asking.. I've used a formula found on line.. Which was quite a bit less than what's on car now.. Figured cam had something to do with that..On the web you get lot's of reading with different answers.. That's why asked here..More feedback...And yep.. Not sure what was thinking on rear gear ratio..Do believe a 3:55... But probably change at some point anyway
Old 10-16-2019, 10:35 PM   #18
Any 650-800 cfm carb if correctly set up will work with your combination.
The Edelbrock 1406 you have is as good a choice as any unless the one you have is defective in some way.
I had a 1406 on a similar engine with less cam and less converter and had to increase the accelerator pump nozzle size. A higher stall converter may decrease the need for that.
I have had problems with Holleys idling correctly in recent years but I don't know if they all do.
I read all this stuff about the Edelbrock AVS carbs being so much better but there is no good reason for them to be unless they are just screwing up their other offerings. A puzzle to me.
Old 10-17-2019, 10:07 AM   #19
Old Buzzard
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
"just Put in a 700r4".
A good choice w/ that loose converter. The lockup converter will help w/ trans fluid heat.
Cruise rpm, that's lower than stall speed, tends to create a lot of heat. BTDT.
Injector inspector.
55 210 sedan, rust bucket. The last hoorah!
Hotrodding and dragracing since 1955.
USAF, 67th Recon Tech. Yokota AFB, Japan.
6594th Test sqdn, Westover, AFB, MA. The guys that brought you the Cuban missile pics. 1960-64.
Old Buzzard is offline   Reply With Quote
Old 10-17-2019, 10:50 AM   #20
Fiddy5Coupe
Fiddy5Coupe's Avatar
Member #3076
Originally Posted by Rustaddict View Post
My pick would be a 650 Holley with vacuum secondaries. You could probably even get by with a 600. I'd also pick a different cam. I believe those thumpers are ground to sound radical but not really be radical. I'd want one that was ground to be the best match for my engine, car weight, cruise rpm, etc at let the sound fall wherever it may. Your car will be peppier and spend less time at a gas pump as a result.
Yes, that Thumper cam they claim the power range is 2000-5800 rpm. With overdrive you may not always get to that 2000 rpm. You might consider swapping out for a cam that has a starting power range in the 800-1200 rpm range. It won't sound cool, but it'll be more responsive at lower driving speeds. And get one with 112 degrees of lobe separation, you'll get better vacuum for power brakes.
This, of course is based on the assumption you're building a cruiser, not a 1/4 mile car.
My friends call me Heidi Ho
Fiddy5Coupe is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
