Old 01-26-2010, 09:22 PM   #21
bob p
bob p's Avatar
Member #2977
Here's an excerpt from the Knowledge Base at the Buick Thunder Forum .
****** [ START ]******
Brake Fluid Facts
by Steve Wall
As a former materials engineering supervisor at a major automotive brake system supplier, I feel both qualified and obligated to inject some material science facts into the murky debate about DOT 5 verses DOT 3-4 brake fluids. The important technical issues governing the use of a particular specification brake fluid are as follows:
Fluid compatibility with the brake system rubber, plastic and metal components.
Water absorption and corrosion.
Fluid boiling point and other physical characteristics.
Brake system contamination and sludging.
Additionally, some technical comments will be made about the new brake fluid formulations appearing on the scene.
First of all, it's important to understand the chemical nature of brake fluid. DOT 3 brake fluids are mixtures of glycols and glycol ethers. DOT 4 contains borate esters in addition to what is contained in DOT 3. These brake fluids are somewhat similar to automotive anti-freeze (ethylene glycol) and are not, as Dr. Curve implies, a petroleum fluid. DOT 5 is silicone chemistry.
Fluid Compatibility
Brake system materials must be compatible with the system fluid. Compatibility is determined by chemistry, and no amount of advertising, wishful thinking or rationalizing can change the science of chemical compatibility. Both DOT 3-4 and DOT 5 fluids are compatible with most brake system materials except in the case some silicone rubber external components such as caliper piston boots, which are attacked by silicon fluids and greases.
The big bugaboo with DOT 3-4 fluids always cited by silicone fluid advocates is water absorption. DOT 3-4 glycol based fluids, just like ethylene glycol antifreezes, are readily miscible with water. Long term brake system water content tends to reach a maximum of about 3%, which is readily handled by the corrosion inhibitors in the brake fluid formulation. Since the inhibitors are gradually depleted as they do their job, glycol brake fluid, just like anti-freeze, needs to be changed periodically. Follow BMW's recommendations. DOT 5 fluids, not being water miscible, must rely on the silicone (with some corrosion inhibitors) as a barrier film to control corrosion. Water is not absorbed by silicone as in the case of DOT 3-4 fluids, and will remain as a separate globule sinking to the lowest point in the brake system, since it is more dense.
Fluid boiling point
DOT 4 glycol based fluid has a higher boiling point (446F) than DOT 3 (401F), and both fluids will exhibit a reduced boiling point as water content increases. DOT 5 in its pure state offers a higher boiling point (500F) however if water got into the system, and a big globule found its way into a caliper, the water would start to boil at 212F causing a vapor lock condition [possible brake failure -ed.]. By contrast, DOT 3 fluid with 3% water content would still exhibit a boiling point of 300F. Silicone fluids also exhibit a 3 times greater propensity to dissolve air and other gasses which can lead to a "spongy pedal" and reduced braking at high altitudes.
DOT 3 and DOT 4 fluids are mutually compatible, the major disadvantage of such a mix being a lowered boiling point. In an emergency, it'll do. Silicone fluid will not mix, but will float on top. From a lubricity standpoint, neither fluids are outstanding, though silicones will exhibit a more stable viscosity index in extreme temperatures, which is why the US Army likes silicone fluids. Since few of us ride at temperatures very much below freezing, let alone at 40 below zero, silicone's low temperature advantage won't be apparent. Neither fluids will reduce stopping distances.
With the advent of ABS systems, the limitations of existing brake fluids have been recognized and the brake fluid manufacturers have been working on formulations with enhanced properties. However, the chosen direction has not been silicone. The only major user of silicone is the US Army. It has recently asked the SAE about a procedure for converting from silicon back to DOT 3-4. If they ever decide to switch, silicone brake fluid will go the way of leaded gas.
The single most common brake system failure caused by a contaminant is swelling of the rubber components (piston seals etc.) due to the introduction of petroleum based products (motor oil, power steering fluid, mineral oil etc.) A small amount is enough to do major damage. Flushing with mineral spirits is enough to cause a complete system failure in a short time. I suspect this is what has happened when some BMW owners changed to DOT 5 (and then assumed that silicone caused the problem). Flushing with alcohol also causes problems. BMW brake systems should be flushed only with DOT 3 or 4.
If silicone is introduced into an older brake system, the silicone will latch unto the sludge generated by gradual component deterioration and create a gelatin like goop which will attract more crud and eventually plug up metering orifices or cause pistons to stick. If you have already changed to DOT 5, don't compound your initial mistake and change back. Silicone is very tenacious stuff and you will never get it all out of your system. Just change the fluid regularly. For those who race using silicone fluid, I recommend that you crack the bleed screws before each racing session to insure that there is no water in the calipers.
New developments
Since DOT 4 fluids were developed, it was recognized that borate ester based fluids offered the potential for boiling points beyond the 446F requirement, thus came the Super DOT 4 fluids - some covered by the DOT 5.1 designation - which exhibit a minimum dry boiling point of 500F (same as silicone, but different chemistry).
Additionally, a new fluid type based on silicon ester chemistry (not the same as silicon) has been developed that exhibits a minimum dry boiling point of 590F. It is miscible with DOT 3-4 fluids but has yet to see commercial usage.
Brake Fluids: DOT 4, DOT 5.1, and DOT 5 Silicone
Q: Sir Tech,
My bike's brakes are currently filled with DOT 4. Is it true that I will get better performance if I switch to Bel-Ray Silicone DOT 5 Brake Fluid?
A: No, Years ago, many road race teams used DOT 5 silicone brake fluid to get higher boiling points than the DOT 3 & 4 brake fluids of that era. DOT 5 silicone is not hygroscopic, meaning it won't absorb water from the air, so it retains its high boiling point over time. On the other hand DOT 3, 4 and 5.1 brake fluids are glycol based and do absorb water from the air, which then lowers the boiling point. That is why you will see wet and dry boiling points, with the dry boiling points always being higher. Glycol based brake fluids may start out with a fairly high dry boiling point but as they absorb moisture the boiling point decreases. So every time your brakes get really hot and then cool, condensation occurs and moisture is absorbed. That is why it is important to replace your brake fluid regularly. It may seem obvious that DOT 5 silicone is the best choice, but not so. Today most road race teams use DOT 4 or DOT 5.1 glycol based brake fluids because the dry and wet boiling points today are very high and in some cases higher than DOT 5 silicone. The number one reason not to use DOT 5 silicone is a slightly mushy lever or pedal feeling as compared to glycol based brake fluids. This is the nature of the product. Street riders may not feel the difference, but the race teams prefer the precise feeling of glycol. The only motorcycles that I know of rolling off the production line with DOT 5 silicone are harley-Davidson® and other American made motorcycles; and that is mainly where we sell our Bel-Ray Silicone DOT 5 Brake Fluid. I recommend you stay with the DOT 4 fluid for performance, not to mention the enormous job it is to switch your system over from glycol to silicone. If that job is not done properly, you run the risk of coagulation if remnants of DOT 4 are mixed with DOT 5 silicone. I hope that's not too much for you at once. Maybe you should read half, take a play break, then read the rest.
DOT 5 Silicone versus DOT 5.1
Q: Sir Tech,
The master cylinder cover of my bike says fill with DOT 5 brake fluid. Can I use your Bel-Ray Silicone DOT 5 Brake Fluid?
A: I'll bet your bike is of European descent! In that case do not use DOT 5 silicone in your brakes. Use DOT 5.1 brake fluid. There is much confusion around this dilemma and making an error could be serious. DOT 5 silicone brake fluid is generally not recognized in Europe, so they call DOT 5.1 DOT 5 for short. In America, the brake fluids' names are DOT 3, DOT 4, DOT 5 and DOT 5.1. All are glycol and compatible with each other except for DOT 5 , which is, obviously, silicone based. In Europe beware, they do not recognize DOT 5 silicone and, therefore, call DOT 5.1, which is a glycol product, DOT 5. This can cause great confusion and obvious problems. DOT 5.1 got its start during the introduction of anti-lock or ABS brakes, where a light viscosity brake fluid was used to assist the modulation of the anti-lock mechanism. Suddenly DOT 5.1 is in vogue today and many are buying it under the guise that it must be better than DOT 4 because it is the next sequential number. Not so! To get the best performance brake fluid, check the wet and dry boiling points. In many cases, depending on the manufacturer, DOT 4 has higher boiling points than DOT 5.1. Today, DOT 5 silicone brake fluids are mainly used in the harley-Davidson® motorcycles since this is what they come with from the factory. The advantage is that if any fluid spills, it won't damage the custom paint jobs. Do your community a favor and pass this info on to another European bike owner or, better yet, quiz your dealer to see if he is "in-the-know".
DOT 4 VS. DOT 5 Silicone Coagulation
Q: Sir Tech,
I bought a 1987 harley-DavidsonĘ Sportster and I recently removed the front brake master cylinder cover to find a bunch of thick gunk inside. What happened and what should I do?
A: If you own a harley-Davidson®, think purple! Your H-DĘ motorcycle came stock from the factory with DOT 5 silicone brake fluid and part of the regulated requirements for DOT 5 silicone is that it be purple colored so as to stand apart from the ever so popular DOT 3, 4 or 5.1 brake fluids which are glycol not silicone. Apparently, your hog's previous owner was more concerned with his tattoos turning green than with his brake fluid being purple and most likely added some DOT 3 or DOT 4 brake fluid to the system. This is a big no-no, bad boy! What happens when you introduce DOT 3, DOT 4 or DOT 5.1, all glycol based fluids, to DOT 5 silicone, which is obviously silicone based, is coagulation! The fluid will clot and, as you so eloquently described, form thick gunk. My advice to you is to consult a qualified technician. After all these are your brakes we are talking about! Have him fully flush the brake system and replace all the rubber parts with new ones and then go back to DOT 5 silicone brake fluid. If you do not re-build the master cylinders and calipers or replace all the rubber parts, there will most likely be remnants of the glycol in the rubber which will cause the problem again. To avoid "thick gunk" in your shorts due to grabbing the brakes and not impeding forward velocity, I recommend you heed my advice with the utmost seriousness and expedience.
******[ END ]******
1957 Beauville Wagon
1957 Wagon commercial
bob p is offline   Reply With Quote
Old 01-26-2010, 10:00 PM   #22
That's a good article.
Obviously, you can conclude that most any these are suitable for your car. There is no pat answer.
And it rolls back to all the comments everyone posted. Again there is no pat answer.
But the facts have been presented pretty thoroughly at this point.
Old 01-26-2010, 11:01 PM   #23
bob p
bob p's Avatar
Member #2977
There were a couple of minor points in the last article that I disagreed with, just because I am a chemistry nerd:
Fluid boiling point
1. When water dissolves into DOT 5 fluid as a contaminant, the DOT 5 fluid is considered "wet". The mixture is an azeotrope that has a wet boiling point of 356 degrees F. It will not boil at 212 degrees F as stated in the article.
2. For water to layer out at the bottom of a DOT 5 brake system, the system would have to be GROSSLY CONTAMINATED with water. Because DOT 5 is hydrophobic and won't pick up water from the atmosphere, that means that any gross water contamination that's left in the system was left there because of human error. Those comments about "water globules" sounded very hypothetical and very improbable to me.
3. Soft pedal at altitude can happen with any type of brake fluid if the system has been inadequately bled. Yes, it can be more of a problem with DOT 5 because air is about 3X more soluble in DOT 5 than in DOT 3 / 4. This makes it especially important that the fluid was handled / installed properly. (You can't, for example, use an air pressure bleeder with DOT 5 fluid, as that will force air to dissolve in the fluid.)
When any car that has air contamination in the brake system is taken from sea level to high altitude, the ambient pressure decreases and dissolved gases become less soluble in the uncompressed fluid. Some air will "boil" out of the fluid and could become trapped in the system. Any bubbles or air pockets that are already in the system will enlarge as the ambient pressure decreases. Essentially your brakes have a case of "the bends." When the system is re-pressurized (brakes applied) the pedal will feel softer than it felt at sea level because as you start to apply the brakes you're working against bubbles are larger than they were at sea level.
At altitude, any air in the lines will be more of a problem than it was at sea level, regardless of what type of fluid is in the system. The bottom line is that if there is any air in the system then we have a system that is functioning improperly because of human error; poor performance shouldn't be blamed on the type of fluid being used because its possible to eliminate the problem using proper service techniques.
Old 01-26-2010, 11:04 PM   #24
bob p
bob p's Avatar
Member #2977
I agree completely -- there are many good solutions, they all work well, and the "right" fluid for you is the one that fits in with your personal objectives and your maintenance schedule. There's more than one way to skin a cat.
I'm still hemming and hawing about whether or not I want to keep all of my cars on DOT 3 / 4 and do the periodic flushes, vs. using DOT 5 in my non-ABS cars just so that I can eliminate them from the brake service rotation.
Right now I've got 4 cars, 2 trucks and 5 bikes, so there's a lot of maintenance to do. I just bought a professional pressure bleeder, hoping that it will make the process less tedious and that it will pay for itself in time saved. Well, at least that's the reason that I gave to justify its purchase!
Old 01-26-2010, 11:16 PM   #25
Petmils 1957 4DR Belair
Petmils 1957 4DR Belair's Avatar
Member #5737
I still don't know what sofine 55 had for brake fluid he never said I'm curious!!!!!
Peter
Petmils 1957 4DR Belair is offline   Reply With Quote
Old 01-27-2010, 02:48 AM   #26
classic gary
classic gary's Avatar
Member #5707
Well, that sounds pretty much like what happened in my experience. the brake system in that case was ALL NEW, never had fluid in any of it till i filled it. Tried silicone first........oh well.
I'll try it again with this car. And I'll let ya'all know how it goes.
classic gary is online now   Reply With Quote
Old 01-27-2010, 02:55 AM   #27
classic gary
Member #5707
[/QUOTE]The bottom line is that if there is any air in the system then we have a system that is functioning improperly because of human error; poor performance shouldn't be blamed on the type of fluid being used because its possible to eliminate the problem using proper service techniques.[/QUOTE
maybe i'm being a bit touchy, um, my techniques are just fine. and yes it can be harder to bleed brakes up here in the altitude, but, after i put in the DOT 4 the brakes worked perfect.
Old 01-27-2010, 10:34 AM   #28
geoffcb
geoffcb's Avatar
Member #7662
I've used silicone fluid in my '57 with dual system (front discs, rear drums) since the early 90s with no problems whatsoever.
geoffcb is offline   Reply With Quote
Old 01-27-2010, 10:43 AM   #29
mr 265
mr 265 has made a donation to the forum!
mr 265's Avatar
Member #10768
The guys are right it wont mix ,,, you have to flush the system,,sometimes if you change over it will make the wheel cyl, leak or also the booster ,,it does something to the rubber and can be a real pain to repair
mr 265 is online now   Reply With Quote
Old 01-27-2010, 01:03 PM   #30
bob p
bob p's Avatar
Member #2977
I'm sorry for offending you, Gary. I wasn't aiming that comment about "service techniques" directly at you, I was speaking in general about people who are familiar with DOT 3/4 but not so familiar with DOT 5.
DOT 5 does have some peculiar qualities that could make it difficult to use even for experienced people. The way that it easily entrains air means that someone who is very familiar with conventional brake fluids could easily make a mistake that could cause problems with DOT 5 without even realizing it.
Some methods that are commonly employed by knowledgeable techs with DOT 3/4 fluids shouldn't be done with DOT 5 -- like using a garden sprayer type pressure bleeder -- the pressure will cause forced aeration of the fluid and that's not good. Its also important to use a bottle that's not been agitated. And then you have to do a LONG flush after you get good pedal feel, rather than stopping there.
Doing a large volume flush after you've got a good pedal helps to make sure that all of the fluid that was in the system that had contact with pressurized air is completely displaced from the system. The reason for this is that first dose of fluid that went into the empty system was pressurized with the air in the lines when the pedal was pumped to send it through the lines. That fluid is air-entrained. It needs to be purged. That's why with DOT 5 you need to do a complete system purge and replace all of the fluid with new fluid after servicing a component. With 3 / 4 you can just change a part and bleed until you get a good pedal feel, but with 5 you really need to do a complete fluid exchange.
There are lots of subtle differences with DOT 5 that aren't immediately apparent. It shouldn't just be treated as if its one of the other fluids or there can be problems. I guess its safe to say that anyone considering DOT 5 needs to do a little homework before taking the plunge. As a brake fluid, its a horse of a different color -- purple.
Even though I've been using DOT 5 in two vehicles for 19 years, I have to admit that I learned a lot more about it as a result of this thread. Thanks everyone.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
