Carb advice - Page 3 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Old 07-16-2019, 05:57 PM   #21
un4given
un4given's Avatar
Member #15884
You guys are making me re-think the Eddy carb now
I appreciate the spread bore suggestions but am set on a square bore.
For you Holley fans which model would you recommend?
Churchkey and Mr55/56 suggested this one.https://www.amazon.com/Holley-0-1850...gateway&sr=8-2
What about this one?https://www.summitracing.com/int/par...0-vs/overview/
I will be ordering from Summit so I am shopping from their site.Thanks to all that have replied so far!
Kinda Fonda Wanda!
un4given is online now   Reply With Quote
Old 07-16-2019, 08:32 PM   #22
Bill Jenkins
Member #43115
Your links came up Demon
IMO, Holley, order manual choke and pin it open unless you drive in freezing weather !
Bill Jenkins is offline   Reply With Quote
Old 07-16-2019, 09:38 PM   #23
Stick with the Edelbrock 650 AVS2
* See my painfully slow and overly detailed build thread here: https://www.trifive.com/forums/showthread.php?t=79427
* I have a vast data base of TriFive restoration & upgrade articles for our members' use...Send me a PM with your EMAIL ADDRESS and subject matter...See this link:
* Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
_________________david aka POPS & sherry
Old 07-16-2019, 09:52 PM   #24
Churchkey
Churchkey's Avatar
Member #25539
https://www.amazon.com/Holley-0-1850...gateway&sr=8-2https://www.summitracing.com/int/par...0-vs/overview/
Demon is touted as a good carb but is it 200 bux better than a 1850? IDK never ran one I like 1850 Holley's for street cruisers 1860's for track. Used to get my track carbs from Barry Grant he is no longer in business.
Whatever you get you will need to change the jets the linked Demon will be very rich for your 283. I run an 1850 manual choke on a 355 & currently have 62 jets in the primary down from 66 @ start up. Secondary = no fuss it has a metering plate. They are available with an E choke.
Your $$ your call.
Good luck
Churchkey is online now   Reply With Quote
Old 07-26-2019, 10:35 AM   #25
Bill Jenkins
Member #43115
1850 Advantages include cheaper.
It is square bore so you can upgrade later.
650 DP Advantages include (IMO) better value, it will feed up to 425 HP, should you upgrade. Includes dual feed, second accelerator pump circuit 100% go when you mash da gas, second metering block so you can tune for your needs, for $135, you can get HP main body with down leg boosters and choke tower delete.
Old 09-29-2019, 12:36 PM   #26
un4given
un4given's Avatar
Member #15884
Hey guys,just thought I would update this thread.I went with the AVS2 650,Air Gap manifold and 4 hole 1/2" spacer,Lokar throttle pedal and cable.Installed everything and was surprised I had no leaks and it pretty much fired right up!
Took it out for a quick test run and it ran real well.I still have some fine tuning to do with the throttle cable but at least it runs and drives.I still need to tweak a few thing like lines and hoses and I will be doing a plug chop soon to see how much tuning I need to do to the carb.I did buy the tuning kit so this should be straight forward.I want to thank everyone on this thread for their advice and encouragement.
Couple of pics...
1.What I started with.
2.Inspector.Always there making sure I do things properly.
3.Intake and carb installed.
4.Assembled and running.
5.Finally out of the garage!
Kinda Fonda Wanda!
Old 09-29-2019, 01:04 PM   #27
Trifecta
Trifecta's Avatar
Member #33688
Originally Posted by 557B210 View Post
All things considered, I believe your choice of an Edelbrock AVS2 650 is the correct one....From what I can tell, you should be able to successfully tune it for your 283 now and a larger displacement engine later.
This is comparable to the replacement I'm getting for my 327ci, 335hp with a moderate Lunati Voodoo cam. I don't want to pirate into OP's thread, but I wondered if the 650cfm was more than I needed. I think a 600cfm would have been OK, but I don't think the extra 50cfm will hurt it.
I'm not a hot rodder so I don't know the advantage of a high riser manifold. I do know that hot air at the intake is not good except in cold temps, so what I did with the intake manifold was to use gaskets that blocked off the center ports going to the crossover..
Bob
Work Hard, Play Fair, Drive Safe, Rock On!!!
Trifecta is online now   Reply With Quote
Old 09-29-2019, 01:06 PM   #28
zoomer
zoomer's Avatar
Member #2661
Nice looking change in the engine bay ,clean looking car as well.
Noticed the plastic inline fuel filter. Never been a fan of those they tend to crack or leak at the seams over time given the heat in there and result could be FIRE. Better off with a metal canister style
Brian
zoomer is online now   Reply With Quote
Old 09-29-2019, 03:28 PM   #29
un4given
un4given's Avatar
Member #15884
Brian
Thanks!The fuel filter and line will be changed soon,just wanted to get it running.
Kinda Fonda Wanda!
Old 09-29-2019, 04:47 PM   #30
Rustaddict
Rustaddict's Avatar
Member #16602
Bob
As long as you stay with vacuum secondaries you should be ok.
Jimmy
Rustaddict is online now   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
