EFI on Vortec heads? - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
User Name
Password
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 11-15-2018, 10:48 PM   #11
BO185
LS Tech and Moderator
BO185's Avatar
Member #1955
Default
Is there no option for a laptop pc over a tablet?
__________________
Four Seasons Metalworks
-CnC Metal art
-Custom Signs
-Custom metal parts
-Powder Coating Services
Gen III/IV "LS" swap info
TECH: LS motor to Early Auto Transmission
Email or PM me your LS questions if you need help
[email protected]
-55 210 delray 235/3sp
-73 IH 1210 Travelette SV392, 5sp, 4x4, 4.10's
-73 IH Scout II Vortec 6.0L 4L65e np241
-01 VW Beetle TDI 50+MPG!
BO185 is online now   Reply With Quote
Sponsored Links
Advertisement
Old 11-15-2018, 10:54 PM   #12
Rick_L
Trifive Leaders Club
Member #2256
Default
You are so right, brain fart here. Used to be the GM TPI distributor was what Holley specified for most anything Chevy.
As you say, the dual sync is only required for sequential systems. And Holley didn't start pushing sequential until they had their own "dual synch" distributor. As I understand it, sequential is great for emissions and economy at low engine speeds, at higher rpm where you're making power the injection pulses are so close together it's not an advantage.
They also have a non-dual sync "Hyperspark" distributor they are now marketing for the Sniper. That and their dual synch distributor have Hall effect triggers instead of magnetic triggers which are better for the Sniper because Hall effect has less EMI noise. Turn that around and read that as the Sniper is susceptible to EMI noise. Regardless, the Edelbrock optical distributor has NO EMI because it's optical.
There's a lot of stuff to keep track of and understand here.
Rick_L is online now   Reply With Quote
Old 11-15-2018, 11:02 PM   #13
hotrodg726
hotrodg726 has made a donation to the forum!
hotrodg726's Avatar
Member #12165
Default
optical ignition triggers bother me. I remember the multitude of unilite failures. I do find it interesting that the holley dual sync dist is a exact copy of the fast dual sync dist. with the exception of the pin out in the plug. heck it is even the same plug , just a different pinout. holley even sells an adapter for the plug on the fast dist. guess they figure people aren't smart enough to re-pin it.
__________________
hotrodg726 is online now   Reply With Quote
Old 11-15-2018, 11:05 PM   #14
Rick_L
Member #2256
Default
No, Edelbrock only has the tablet. As you may know, some of the Holley systems have a hand held controller with an SD card. But they allow you to use a laptop or pc either by transferring the SD card to the laptop or PC, or they do have a cable with dongle that let's you plug in direct with a laptop. Holley Sniper and Avenger are like this.
Remember this, the Edelbrock Pro Flow 4 sells for $1800-2100. A Holley multi-port system is approximately twice that, as was the old Pro Flow 3. Interestingly, Edelbrock has for now pegged their marketing on this system and has dropped their E-street TBI systems which "kind of " competed with Holley Sniper etc.
Old 11-15-2018, 11:19 PM   #15
Rick_L
Member #2256
Default
I also think the Pro Flow 4's distributor may be made by Mallory.
Another example of optical distributors is the Chevy LT1 from the 90s. But its primary problems were not the optical triggering, it was venting and contamination issues due to its location under a water pump that was prone to leaking coolant onto the distributor after some miles. It was a rotor/contact problem, and the fact that you couldn't replace the rotor and distributor cap because it was a sealed assembly. On those cars if you had a distributor failure or a water pump failure you really need to replace both at greater expense than normal or you were screwed. By greater expense I mean that you had to replace the whole distributor at a cost of several hundred $$ instead of a cap and rotor for $20-30.
Hopefully optical sensor distributors are better than when Mallory introduced the Unilite. But I don't know. Most of the rest of the world uses magnetic or Hall effect. Or coil near plug.
Old 11-15-2018, 11:20 PM   #16
hotrodg726
hotrodg726's Avatar
Member #12165
Default
you do not need the sd card after initial loading with a holley touch screen if going to a lap top. it is only there as the touch screen has no extra internal storage space.
if starting off with a laptop you do not need the sd card at all. everything you need is in the holley pc software.
I must admit the price of the edelbrock is attractive though.
__________________
Old 11-16-2018, 12:11 AM   #17
Rick_L
Member #2256
Default
Small point, you still have to buy the cable with the dongle.
But I guess that's like everything else.
Old 11-16-2018, 01:05 AM   #18
hotrodg726
hotrodg726's Avatar
Member #12165
Default
there is no cable with dongle to buy with the avenger, it is the same ecm as the hp. the ecu comes with a usb cord to connect to a laptop. it is 6 foot long , there are other lengths available though.
the sniper is the only holley efi needing a dongle cord, it adapts the can bus to be read on a pc with the sniper software. comparing the sniper tbi unit to the edelbrock is not really a good comparison. the avenger or hp systems are a better comparison.
__________________
Old 11-16-2018, 02:33 AM   #19
hutchenc
Senior Member 2 Gold Stars
Member #3786
Default
The Edelbrock system is interesting for sure. I wish they had done two things though.
First, I don't really like the idea of being tied to a tablet or phone to use the system. At all. I'd like to have a PC option like Holley offers.
Second, I wish they offered the harness to use with different hardware (i.e. you supply your own intake, rails, throttle body etc).
The price is attractive for sure, but I think Holley's Avenger and HP system is much more flexible.
If I were in the market for another EFI system, I'm not sure I'd jump in on this one yet. Too new...not enough customer review/install testimonies on the internet just yet.
I'd be curious to try this on my 355 if it'll clear the hood on my '72 Camaro, but with the intake being limited to a Victor Jr and the front intake style...not gonna try it on my 420 which has heads with intake ports that the Victor won't accommodate.
For the OP...I honestly think the best street option for a mild SBC with Vortec heads is a Vortec style Holley Stealth Ram (sometimes referred to as an HSR). I see them for sale all the time on thirdgen.org Classifieds used for like $500. Pick up the Holley HP harness and ECU for it for another $1.5K or so and you're set.
hutchenc is offline   Reply With Quote
Old 04-26-2019, 09:01 PM   #20
Rick_L
Member #2256
Default
Coming back from a few months ago to clarify/correct some things I said.
The information I got previously on the Edelbrock Pro Flo 4 distributor, that it's optical, is incorrect. The distributor has a Hall effect sensor, and uses a different trigger window width on the #1 cylinder to identify it for use with the sequential injection. So it does the same job as a Holley or FAST dual sync which also have Hall effect sensors. The main difference being that it uses a single sensor instead of two.
There's no data logging, but the tablet they supply now has software that can do mulitiple screen captures and save them. Not real data logging, but a crude way of capturing data.
I also did some reading on the Edelbrock E-street, which was a throttle body system with the sensors and ECU in the throttle body. It's now discontinued. Apparently it has the same EMI problems that the Holley Sniper and FiTech have.
The Pro Flo 4 is not as powerful as Holley HP or the equivalent FAST system. But it's half the price.
There's lots of competition in this market and things change pretty rapidly and prices drop with the newer products. Holley recently introduced the Terminator X system for LS engines - $1000 for the base system. Great for swaps with no manifold, injectors, or distributor because you use the LS stock pieces. Look for them to package something like it with a manifold, distributor, and injectors to compete with the Edelbrock within a year or so.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
