Review of the Arizona Speed Marineís twin blade 58MM throttle valve. - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
User Name
Password
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 05-18-2011, 11:26 PM   #1
trifive
trifive has made a donation to the forum!
trifive's Avatar
Member #1
Default Review of the Arizona Speed Marineís twin blade 58MM throttle valve.
I recently decided to install a new throttle valve on the Big Block Ram Jet in my 57 Chevy,
Why did I do this, for a couple of reasonís, First I found out the OEM throttle body that was on the big block ramjet setup I had was only 600 or so CFM, that was originally designed for a 305 TPI engine, Plus I was having problems with it, due to a sticking throttle valve, leaking gaskets etc.
So since I needed to repair it, I decided to upgrade to the latest and the best Throttle valve I could find, in my opinion, for a fair price.
Since the GM Ramjet system is based on the system designed by ASM, I figured they were the experts in the field.
After doing a lot of research I decided to go with the 1050 CFM 58MM Twin Blade Throttle Body that ASM sells.
Installing the new throttle body was a snap only took a couple minutes; Bolts directly in place of the old throttle body, Uses the same sensors etc.
The new throttle body is machined out of billet aluminum and has dual springs on the throttle lever, so I no longer needed the extra return spring I was using on the old valve.
The car started right up, I did do a few adjustments to the MEFI 3 Computer to fine tune the engine for the additional air fuel ratio etc.
I took it for a drive and the throttle response was fast and responsive. It felt like when I had the 2 four barrel carbs on my big block but with a lot more power.
Cruising down the road it ran smooth and was very responsive at all speeds.
I havenít dino tested it, but they say that you should get an extra 50 horse power just from the new throttle body upgrade, I donít know how many HP increase I got, but you hit the gas and it throws you in the back of the seat like a pilot taking off with a Jet,
I am very satisfied and pleased with ASM's twin blade 58MM throttle valve and would highly recommend it to anyone.
So let all those ricers use the bottle to make power we do it the old fashioned way, Ram Jet.
Otis
trifive is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-18-2011, 11:33 PM   #2
hotrodg726
Trifive Leaders Club
hotrodg726 has made a donation to the forum!
hotrodg726's Avatar
Member #12165
Default
Otis , I'm glad to see you are getting it sorted out. glad to see that the throttle body paid off. are you getting more comfortable with the mefi-burn? let me know , John
hotrodg726 is online now   Reply With Quote
Old 05-18-2011, 11:39 PM   #3
trifive
trifive's Avatar
Member #1
Default
Yes a lot more comfortable, I got to pick up the 57 tomorrow, I just had the transmission rebuilt , for heavier duty performance hope it holds up behind the ramjet.
otis :
Old 05-19-2011, 12:19 AM   #4
Chevynut
member
Chevynut's Avatar
Member #1769
Default
I am using a similar dual 58mm Holley throttle body on my Ramjet 502 for the same reason. The "stock" TPI dual 48mm throttle body is only 635 CFM, which seems really stupid for a 502. I also went to 42 lb/hr injectors, but that's not necessary if you have enough injector already. I didn't have any so I bought the 42's instead of the stock RJ502 29s???
I'll be really interested to see if you got more horsepower. Since I believe the 48mm TB chokes the bigger engines above about 4500 RPM you should be able to maintain your torque to higher RPMs, which means more peak HP.
Chevynut is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
