Flowtech Headers - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
User Name
Password
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Parts on Ebay
Reply
Thread Tools Display Modes
Old 01-12-2010, 06:24 PM   #1
badnblack55
Senior Member 1 Silver Star
Member #4283
Default Flowtech Headers
Is anyone running flowtech headers? I will be running 3/4 forward side mounts manual steering box and removed the stock transmission horns. I can pick these up also so that would save even more money. http://cgi.ebay.com/ebaymotors/FlowT...Q5fAccessories
badnblack55 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-12-2010, 08:29 PM   #2
55mike
Senior Member 3 Gold Stars
55mike's Avatar
Member #608
Default
Quote:
Those look OK but not if you are going to lower your car...
__________________
Mike
Hear it run...
http://www.youtube.com/watch?v=2wEETd57ubs
A little power run...
http://www.youtube.com/watch?v=_BJ8P2rP9-g
55mike is offline   Reply With Quote
Old 01-13-2010, 07:05 AM   #3
V8PunkRocket
Senior Member 1 Gold Star
V8PunkRocket's Avatar
Member #1002
Default
Mine fit great, but like Mike said, they hang down pretty low so they won't work on lowered cars.
__________________
Some men are Baptists, others Catholics, my father was an Oldsmobile man.
When passing the torch, try not to hand out the end that's on fire.
Brian
'56 Chevy Bel Air
'55 Packard Clipper
'64 Corvair Monza ragtop
V8PunkRocket is online now   Reply With Quote
Old 01-13-2010, 09:55 PM   #4
badnblack55
Member #4283
Default
About how low do they hang below the frame I know not ever car willl be the same but a ruff estimate would work. My car has already been lowered but im not going any lower.
Old 01-13-2010, 10:38 PM   #5
classic gary
classic gary's Avatar
Member #5707
Default
i bought a set of those from a local Checker/O'Rieley's store for $117.00 plus tax and had them the next day. i haven't put 'em on yet.............
__________________
56 210 2dr, sedan, Gen1 327, twin 57mm turbos, 2004R, Ford 9/3.10 ratio, C3 front spindles and brakes, Exploder disc brakes rear, shortened C10 tilt steering column, MegaSquirt 3 pro EFI, and more....
classic gary is offline   Reply With Quote
Old 01-14-2010, 06:40 AM   #6
55mike
55mike's Avatar
Member #608
Default
"Standard" trifive headers all are designed to clear the stock rear mounts that attach at to the sides of the bellhousing. This puts the bottom of the header about 2" below the front part of the frame right before it curves upwards. This is usually the lowest point to the ground as well. If your car is stock.. no problem... BUT if you are using 2" dropped spindles (depending on the aspect ratio of your front tire as well) the (standard) headers will only be about 3" off the ground. I know this because when I first built my car, I had 2" dropped spindles and standard Hooker Super Comp's... that were low enough to drag on the ground if going on a bumpy freeway at high speeds with two guys in the front seat. Forget speed bumps! Now I have the 2" dropped spindles and 1" lowered springs... ain't no way I can run the standard type header now. My frame is only about 4.5" off the ground. So, I would recommend either 3/4 length Patriot style, or a full length for "lowered cars." If you go with the full length, you will need to remove those rear trans mounts and go with a crossmember at the transmission tail shaft.
__________________
Mike
Hear it run...
Old 02-01-2010, 10:33 PM   #7
badnblack55
Member #4283
Default
I have already removed my frame horns and have 2" drop springs. Can someone link me to some headers for lowered cars? I might just pick a set up of the flowtechs from oreilys and see how they are I work at a shop so taking them back is no problem if they hang to low. Also will flowtechs work the angle plug heads , 3/4 forward side mounts?
Old 02-02-2010, 04:14 AM   #8
Triple Deuces
Member
Triple Deuces's Avatar
Member #3174
Default
Based on glowing comments from a Chevytalk member several years ago, I bought the Flowtechs for my '55. They fit well except there's no way the stock clutch linkage will work - maybe ok for a hydraulic clutch setup, and certainly fine if you're running an automatic. Summit took 'em back, no problem. Ended up with the Patriot 8025 (perfect for lowered cars).
Don
Whoops, I just looked at your ebay link and those are not the same Flowtech's I tried. Those look like they would clear the stock clutch setup just fine.
Triple Deuces is offline   Reply With Quote
Old 02-02-2010, 07:58 AM   #9
mickeywestsr
Trifive Leaders Club
mickeywestsr has made a donation to the forum!
mickeywestsr's Avatar
Member #1970
Default
I like my Sanderson Huggers, no hang down worrys.
__________________
GO VOLS
COWBOY
mickeywestsr is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
