Done collecting parts ,time for gasser - Page 55 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Gassers
Trifive Gassers Trifive Gassers Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about Trifive Gassers, How to Build , Parts Etc
Old 09-01-2019, 09:40 PM   #541
blackwidow
blackwidow's Avatar
Member #23348
There was one that had a lopsided [email protected] 28 3/8 it was on driver side moved it to passenger , then passenger was 28 1/2Ē with a longer spline moved it to driver side it was stiff to plunge in , as earlier I didnít want to force it but at this point some of the splines could have been rolled? Rotated the driveshaft while trying to push the final 1/2 of bearing in. Took a 4lbs beater and give it an abrupt tap to the axle face and she seated. Tried to put in gear and couldnít turn axle ...... loaded tires and installed lug-nuts and left in gear tire is firm no spin Both sides. Very promising.......
From seal to pig was 25Ē on both sides
Had two leaks from Muncie pipe plugs that I drained and re sealed while it was up....... now completely ready for more fuel and some pavement! I will crawl it out driveway tomorrow afternoon
Anyone have TIME for sale....I could use some extra!
blackwidow is online now   Reply With Quote
Old 09-02-2019, 09:13 AM   #542
1971BB427
1971BB427's Avatar
Member #16997
Dutchman's site says 28.187" length is correct, so maybe the axles need to be trimmed? Too long can contact the spring inside and take pressure off it.
1971BB427 is offline   Reply With Quote
Old 09-02-2019, 11:03 AM   #543
blackwidow
blackwidow's Avatar
Member #23348
Well I just fired her up and no fix still same as it was. Guess Iíll gel her apart and see if clutches are in there with the steels I believe at one point the seller said I didnít need the additive because there were all steel clutches which makes sense if itís spinning as well with no friction to catch steel on steel to me would be slippery....... easy enough to pull Iíll get the proper setup for stock 9.3 and get the fabcraft gospel as well might be handy? Then Iíll see about two fresh Dutchman axles to round things off with elongated splines. Not going to hurt at this point......... as a quick fix I can install my single wheeler and stock 29 splines to get me at least rolling til parts come in
1971BB427 Iíll get a look at the 31splines again and see whatís going on?
Old 09-02-2019, 11:52 AM   #544
finn210
finn210's Avatar
Member #17830
First off...you got some heck of a nice gasser!!! Been couple years I last time checked your progress since I haven't been 'here' lately but man your 57 turn out nice!
Second...all steel clutches...what! I'm no super expert on these but from my hat I think that can't be a good idea from the first place.
Friction clutches are parts which are made the way that they worn no matter what...if your rear end has 'all metal' stuff, that metal is floating around with oil all the time...just thinking out load here
Your gasser rock!
Mikko
Sent from my Commodore 64 using one finger technique
finn210 is online now   Reply With Quote
Old 09-02-2019, 02:39 PM   #545
blackwidow
blackwidow's Avatar
Member #23348
Thanks finn210 sheís being cantankerous at the moment ...welcome back!
Short axle has a 4Ē insert into the rear
Long axle. Has a 4 1/2Ē slot
All spline inserts are in good shape in the hub no damages to either side
It seated with the beater yesterday and there was no spring to contact to cause unloading,
Figured that Iíd install the single wheel with the 28 3/16 axles and it all fit great
But of course where did I put the 5 on 5 rims? Iím exhausted and need to crack open the Posi unit........ itís the early style that bolts together.
Iíll get some pics of it when opened up.
Old 09-02-2019, 03:20 PM   #546
blackwidow
blackwidow's Avatar
Member #23348
I couldn’t wait it’s eating me alive !
A first for me well they are steel. I think if anything I need more to make tighter?
Now which way does the bevel go can I get clutches local and what’s my torque on the barrel and main caps to put back together
Old 09-02-2019, 04:12 PM   #547
1971BB427
1971BB427's Avatar
Member #16997
I'm with Finn210 as to needing clutches. I've never heard of steel on steel, and can't imagine how it can work? All the gear lube, plus metal to metal just seems like a great way for things to slip, and not grab.
I'd be shocked if any place that sells auto parts would have the clutches, but it's possible another clutch disc set might fit and work? I just couldn't tell you for sure. Might call Dutchman's and ask them if they know what else can interchange with the 31 spline 9.3 Olds?
Don't hold me to it, but torque is probably the same as other GM rear differentials of the era. Might be another question for Dutchman's to answer.
I sure miss having Dutchman's Axles just 3 miles away! Sad day when they moved to Idaho!
Old 09-02-2019, 07:01 PM   #548
stewartwhite
stewartwhite's Avatar
Member #6286
I would rebuild the entire rear end and make sure everything is set to spec by you and your quality of work standards are applied to remove any future surprises.
stewartwhite is online now   Reply With Quote
Old 09-02-2019, 08:43 PM   #549
all gm 12 bolts has steel clutches in them straight form gm.
1956 210 delrey sedan 383 700r4 12 bolt posi
1968 Camaro 468 bbc power glide 12 bolt
1968 Camaro 408LS power glide 12 bolt super gas
1971 el Camino 383LS 700r4 12 bolt posi
still searching for the right 56 nomad project.
Old 09-02-2019, 08:52 PM   #550
blackwidow
blackwidow's Avatar
Member #23348
So with that being said I’d be inclined that the Belleville springs are installed backwards, I pulled out other side and both are cupped towards the spacers and clutches and not allowing them to load..... I flipped them and it is raised 3/16 from seating the Posi body together. Still just playing with it it’s my first 9.3 internal dive.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
