Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Non TriFive Vehicles Special Category > Non Trifive Vehicles
User Name
Password
Non Trifive Vehicles Ask all your questions Here about any non Trifive Vehicle, Any year any make or any model. As long as it has a motor and wheels this is the place.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 08-27-2017, 07:41 PM   #1
Carmine
Trifive Leaders Club
Member #6592
Default Puking out the overflow hose
Hi everyone. What makes a car puke out antifreeze through the overflow hose?? I had my '71 GTO out today for a 40 minute ride. Ran well. Temp. stayed pretty much at 190-195. Shut the car off to get ice cream and a few minutes later, the overflow hose was puking out antifreeze. Loss maybe a quart of antifreeze if that. A few days ago on a previous ride, the day was even hotter and I had a longer ride. Car temp. ran about the same. Drove the car home and shut it off. Nothing on the floor overnight. I did notice previously that the radiator was quite full. Have to wonder why it did it today, and under almost identical circumstances, it didn't do it last week. Any ideas/suggestions would be appreciated. Thank you, Carmine.
Carmine is online now   Reply With Quote
Old 08-27-2017, 07:49 PM   #2
hotrodg726
hotrodg726 has made a donation to the forum!
hotrodg726's Avatar
Member #12165
Default
several possible causes. 1 being a weak rad cap. I use a 16# cap on cross flow radiators. 2 you need a recovery tank to catch vented fluids and allow them to be sucked back in.
__________________
hotrodg726 is online now   Reply With Quote
Old 08-27-2017, 07:49 PM   #3
reds5772
Senior Member 2 Gold Stars
reds5772's Avatar
Member #16463
Default
check the cap sounds like its getting weak.
__________________
video of the build she is done!! https://www.youtube.com/watch?v=9uKC14-JyAE
reds5772 is offline   Reply With Quote
Old 08-27-2017, 07:55 PM   #4
Carmine
Member #6592
Default
Thanks guys. The cap is brand new but that doesn't mean it isn't defective. I can buy another one if need be. It's rated at 15lbs. which I believe is factory, Carmine.
Old 08-27-2017, 07:59 PM   #5
TheHotrodHandyman
TheHotrodHandyman has made a donation to the forum!
TheHotrodHandyman's Avatar
Member #8438
Default
Quote:
If your car didn't originally have an overflow tank then the radiator had a "full cold" line on the tank about 3" down from the top so it wouldn't puke out. If you are filling it to the top that is your problem, Let it seek its level and you should be good to go.
__________________
-Bruce
TheHotrodHandyman is offline   Reply With Quote
Old 08-27-2017, 08:10 PM   #6
Carmine
Member #6592
Default
Quote:
No original overflow tank to my knowledge. I do believe it was pretty full. Don't know how that happened because I like it to be down some from the top. I will check it in the morning to see how far down it is. Guess I will leave it at that level and see what happens. Thanks Bruce. See you Friday, Carmine.
Old 08-27-2017, 08:27 PM   #7
TheHotrodHandyman
Member #8438
Default
Sounds good, We will be in our usual spot.
__________________
-Bruce
Old 08-27-2017, 09:25 PM   #8
SLIM
Senior Member 1 Gold Star
SLIM's Avatar
Member #18096
Default
Exactly, hot water expands, you had it filled too much. Installing a over flow tank does help some, with a over flow tank you purposely fill the radiator to the vary top, must touch the radiator cap cold, then it will expand into the overflow and get sucked back in as it cools.
SLIM is online now   Reply With Quote
Old 08-28-2017, 08:10 AM   #9
topdog
topdog's Avatar
Member #15087
Default
Sounds like you are filling the radiator to the top when cold. You need to leave space for expansion. Most likely you will be at the correct fill after the puke
topdog is offline   Reply With Quote
Old 08-28-2017, 09:06 AM   #10
55 Rescue Dog
Senior Member
55 Rescue Dog's Avatar
Member #39226
Default
Installing an overflow tank on any car is easy, and would be the best solution. It will keep the air out of your radiator, and full to the top all the time, and not make a mess. Plus you can visually see your coolant level in the recovery tank without needing to remove the radiator cap all the time to check. If it never had a tank originally, it should have.
55 Rescue Dog is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
