Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Non TriFive Vehicles Special Category > Non Trifive Vehicles
User Name
Password
Non Trifive Vehicles Ask all your questions Here about any non Trifive Vehicle, Any year any make or any model. As long as it has a motor and wheels this is the place.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 09-25-2017, 02:03 PM   #1
Carmine
Trifive Leaders Club
Member #6592
Default Temp. raises quickly
Hi everyone. Just wondering about something. Like many of you, I've owned a lot of different cars during my lifetime. But, my '71 GTO has me a little puzzled. I've never owned a car whose engine was cold when started, let it warm up 1-2 minutes at the most and took off down the road. No exaggeration, after 3-4 miles, flat road, 50 mph, the engine temp. climbs to 180-190. I know it was hot here yesterday, close to 90 and a little humid, but this happens all the time. This is not the first time. I just don't think this is correct. It stays around 190-195 but in slower traffic yesterday, it inched although never touched, 210. Maybe 205. I hate to compare it to my '62 409, which takes a very long time to reach operating temp., but I've never owned a car that heats up this quickly. Does anyone think this is normal?? Thank you, Carmine.
Carmine is offline   Reply With Quote
Old 09-25-2017, 02:35 PM   #2
David's 56
Senior Member 1 Blue Star
David's 56 has made a donation to the forum!
David's 56's Avatar
Member #39983
Default
my 07 Silverado does about the same. Doing 45 for 4 miles and just 30 secs warm up.
__________________
David
My Build
http://www.trifive.com/forums/showthread.php?t=156889
A problem is nothing more than an opportunity for a solution.
David's 56 is online now   Reply With Quote
Old 09-25-2017, 03:10 PM   #3
acardon
acardon's Avatar
Member #1888
Default
Does it have a mechanical fan clutch? It could be slipping which would cause quick warmup as well as running hotter then the thermostat. .
__________________
Don
Sent from my 1981 IBM 5150 PC.
acardon is online now   Reply With Quote
Old 09-26-2017, 05:44 AM   #4
Carmine
Member #6592
Default
Quote:
Yes, a brand new Hayden mechanical fan clutch, but I guess that could be defective also. Just never owned a vehicle that warmed up this quick, Carmine.
Old 09-26-2017, 11:41 AM   #5
abdiver7777
Senior Member 1 Gold Star
abdiver7777's Avatar
Member #35808
Default
Those temps don't seem like a problem to me?
abdiver7777 is online now   Reply With Quote
Old 09-26-2017, 02:21 PM   #6
Carmine
Member #6592
Default
Quote:
Agreed, but I've just never seen temps get that high that quick. Thought it might be indicative of another problem, Carmine.
Old 09-27-2017, 04:07 PM   #7
Carmine
Member #6592
Default
Did a little experiment today, if you want to call it that. Started the car in the garage and let it run until it reached operating temp. of 180 degrees. It only took a few minutes but I wish I kept better track of the time. It was 82 degrees in the garage and a little humid. Idled the engine at about 800 rpm's for a good solid 10 minutes. The gauge never moved off the 180 mark. In much less time then this going down the road, it would have climbed to 190-195. Hmm.....................Not sure how I should interpret this, Carmine.
Old 09-27-2017, 04:58 PM   #8
abdiver7777
Member #35808
Default
Just thinking out loud here...
Is it possible that there is an obstruction in the radiator core? If you can get your hands on an infrared heat gun (Harbor freight $30.00) you can shoot some surface temps from where the anti-freeze leave the intake manifold and then at various points across the core then back into the pump?
You might also find hot/cold spots on the intake manifold suggesting air pockets inhibiting flow?
Old 09-27-2017, 05:02 PM   #9
srleen
Senior Member
srleen's Avatar
Member #42620
Default
Has it always done this or this something new? Is the temp sender the right one for the gauge - is the gauge right?
srleen is offline   Reply With Quote
Old 09-28-2017, 07:18 AM   #10
Carmine
Member #6592
Default
I have one of those infra red guns and will give it a try. The radiator is a Cold Case brand and new. I replaced the original when it approached 210 degrees and started reaching higher. The new radiator has certainly helped. I would just like to see the temp. a little cooler.
I haven't had the car long enough to learn it's individual characteristics, so I don't know much about this issue from before. The PO told me it never ran hot or overheated. I don't think he was telling the complete truth. The temp. gauge is a new electric AutoMeter which came with it's own sending unit. I don't have any reason to think that it might be defective. I think it might be a good idea to check where the sending unit is in the manifold, with the infra red gun, and compare that to the gauge. I would think they should be right on or very close, Carmine.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
