Fan Shroud
5K views 24 replies 12 participants last post by  Apache Old Man
#1 ·
Hello all. I have a question about fan shrouds. With the warmer weather my '57 with a 350 engine is running hot when in stop and go traffic. As long as I'm moving the needle in the original Chevy gauge is at the 12:00 position or lower. Stop in traffic for very long and the needle moves up quite a bit. I've read a lot of posts on here about cars over heating and one consistent recommendation seems to be installing a fan shroud. Since my car does not have one I'll start with that. The question is, does it matter what type of shroud? I've seen steel, aluminum, even plastic (don't think I would go that route). Is one any better than the other or is it more a matter of personal preference? Thanks in advance for your feedback.
#2 ·
In the interest of weight savings my preference would be aluminum followed by plastic. My 74 K20 still has its original plastic shroud. Position the blades half in & half out yields the best airflow. I like challenges of fabrication and intend to make my own for the 55. Upping to a 5 blade also yields more airflow.Summit Racing has both.
Jim
#4 ·
Splash shields
These cars came from the factory with a pair of what I'll call splash shields that mount BEHIND the radiator. These prevent air from being pulled up from below the front crossmember by the fan, thus reducing air flow through the radiator. I have seen quite a few cars with these missing and I'm sure this compromises the cooling system's efficiency. If you are missing these, I'd suggest adding them before, or even after adding a shroud. Just an FYI.
#7 ·
When I did mine back in the day I went with the plastic. Even though I had purchased it specific to my application I had to do major trimming to get it to work. I was glad it was made of plastic, made it easy to trim with a Dremel. It did make a big difference in keeping it cool.
#11 ·
Thanks guys. I went with the plastic. Thought it might be easier to work with if I have to start trimming it. Next thing will be some after-market gauges so I can get a more accurate temperature reading. I think the fan is doing a pretty good job. It's a six blade, 15 or 16 inch diameter. Each blade looks to be about 5 or 6 inches but there are six of them. If the shroud doesn't do the trick I may try changing the fan.
#14 ·
I went with aluminum. It's easy to trim and you can bend it around the bottom hose and if you have transmission cooler lines. I had to bend some in this area to make mine fit. The aluminum was easy to work with and massage it to fit better and it holds it's shape. Just my 2 cents.
Todd
#15 ·
I went with the black plastic.. I ended up cutting the bottom off the shroud so I could install the shroud with the fan and all hoses installed. Sorta cut it at an angle.. the sides are intact and it fits around the lower radiator hose. My fan sits half in and half out. I have a 180 degree thermostat and in 90 degree temps I maintain 180-185 degrees. I h as be a Condenser in front of the radiator and my fan is a Racing Fan. When you hold a sheet of paper up to the condenser, it sucks it hard up against the Condenser/Radiator!
#16 ·
I went with a metal fan shroud from Danchuk on my 55....The fit was great....Personally, I'm not a big fan of plastic anything on a 65 year old car, if there is an alternative....Just me I guess.
