From metal to finish: a guide to creating a show-stopping finish - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Metal Fabrication & Repair Questions > Paint & Bodywork Questions and Answers
User Name
Password
Paint & Bodywork Questions and Answers Paint & Bodywork Questions and Answers
Parts on Ebay
Reply
Thread Tools Display Modes
Old 11-30-2006, 07:43 PM   #1
trifive
trifive has made a donation to the forum!
trifive's Avatar
Member #1
Default From metal to finish: a guide to creating a show-stopping finish
I talked to Rich Evans and he agreed to join Trifive.com and share information and help with our members, Rich has also kindly agreed to post a link to Trifive.com on his popular websites. Be sure to watch rich on his popular TV Shows, The schedule is on his website, he also manufactors over 75 custom parts for Trifives.
Thanks Rich
By Rich Evans Do you have a project car that has been sandblasted down to bare metal and needs a spectacular finish? To explain in detail the complete process of transforming a bare metal vehicle into a show quality finish, the project I'm breaking down is a 1956 Chevy Bel Air Convertible. This particular car was for Art and Dan Danchuk of Danchuk Manufacturing, Inc., the world's largest manufacturer and supplier of 55-57 Chevy parts in the world. Needless to say, there were some high expectations to meet. While some parts of this project might go above and beyond what is needed for your average car, this process is still the way to complete any car and also have a show stopping finish in the end., these are the steps you will need to finish it.
Grind down welds
On this project, the original floors of the '56 were replaced. We did all the bodywork at Hungtington Beach Bodyworks where I did all the metal refinishing myself. Begin by grinding down the new welds to get a factory look using a grinder and die tool with a bit to recreate factory spot welds. I used a brillo pad disc for any excess weld material and to generally clean up the welded areas.
Blow off any dust or residue and feather your edges with a DA sander, 150, and 320 grit sand paper to give the primer something to bite on to. Use a red Scotch- Brite pad for any areas the DA couldn't reach. Do not leave any excess weld material, dust, or residue or you can pretty much count on the paint lifting and having adhesion problems. Use seam sealer over the welds in the floor. I also applied Drip Check to the work done in the wheel wells, to keep water from leaking up and creating rust.
Apply sealer
Now it's time to apply sealer. With bare metal, the first thing to do is spray a self-etching primer to make all the other primers, basecoats, and clear coats adhere to the metal. For my sealer, I used PPG's Non-Sanding Epoxy Primer - mixed two parts primer, one part catalyst and one part DT885 reducer.
Rich tip: Always test the mixture on a spray card before applying to the vehicle. This rule holds for any mixture for any project vehicle. It's an integral step to test the integrity of the mixture and avoid any possible contamination.
This being a "non-sanding" epoxy primer, go right into spraying the PCL Polyprimer, which is a Hi-Fill polyester primer surfacer that is mixed by the quart with a catalyst and is not reduced. This is going to create the surface of the project which will be sculpted in the block sanding stages of this process.
The epoxy primer and polyprimer stages are where the project can get really messed up by not mixing exact measurements or by laying down coats that are too heavy. Using too much or too little catalyst in either primer will prevent it from drying. Be sure to mix exactly according to the instructions. Take your time. Don't rush.
Block sanding
Now that the surface has been prepared, the next step is to shape it by block sanding with various grits of sand paper. First create a black guide coat to show the high and low areas of the project. For this, I use a reduced down version of PPG's Black Epoxy Primer for the guide coat. Just a quick thin coat is all that is necessary to show the condition of the body.
Rich tip: With the guide coat on, start with a long block and some 80 grit sandpaper. My preference is to use a long block in the early stages which actually lets the block do the work. By this I mean do not to apply force to the block or angle it to do certain jobs that it wasn't meant to do. Also, do not try making it cut faster. Keep it flat and just move it back and forth.
I also use a cross cut pattern, where I'll move the block in one direction for a few strokes and then in a new direction for a few more strokes - like an "X" pattern. This helps to smooth out the surface more quickly.
High and low spots
If you come upon an area that's starting to sand down to metal again, that's your high spot. The reason it is down to metal again is because the surrounding area is to low. It is normal to have a low area surrounded by a few high spots. To raise these low areas, I apply a smooth coat of Polyester Finishing and Blending Putty. The Poly Putty needs a good 80 grit to adhere to.
Using the high spot as a guide, being sure not to sand past it, resume block sanding the Polyester Putty and feather out edges into the surrounding surface. This stage will sometimes have to be repeated to obtain a true panel and a smooth surface.
Block sand the entire surface one panel at a time to keep track of what's been blocked and what hasn't. It can be hard to tell simply by looking at it when you get into the higher grits and the surface gradually becomes smoother and smoother. After the surface has been blocked with 80 grit, apply another guide coat and then block sand the surface again with 150 grit and then again with 400 grit, applying a black guide coat between grits. The whole time I used a long block, only switching to smaller blocks in the end to sand the smaller areas like the door jams. This can sometimes be a long tedious process, but necessary to achieve a beautiful finish.
Basecoat
Now with our panels true and the surface smooth, it's time for basecoat. The first color of the two-tone project was PPG India Ivory White. The color white can be problematical with coverage when working with white basecoats, so the first thing to do is to scuff the surface with a red Scotch-Brite pad and apply a few coats of white epoxy primer (PPG DP48) reduced down 2-1-1 making it a sufficient sealer. Because the primer is mixed with a catalyst, it won't reactivate when the clear coat is sprayed and bleed through the second color.
Next spray three even coats of the PPG India Ivory White. I used a Sata Jet 2000 Digital HVLP2 with a 1.4 tip. Some painters like the 1.3 tip for their basecoats, but I personally prefer the 1.4. Allow 5-15 minutes of dry time for basecoats (15-20 minutes for clearcoats) before applying your next coat. I usually spray basecoats at 27 psi and clear at 33 psi.
Rich tip: Since this was a two-tone Chevy, there were some layout and masking techniques that I won't really get into, because it doesn't pertain to every vehicle. However, when masking off any area of a car for graphics, I generally try to apply the masking as tight and flat as possible. The reason being that sometimes a crease or a fold can give your spray pattern something to bounce off of and create an imperfection in the finish.
With the masking peeled and the edges cleaned up, apply three wet coats of clear - allowing 5-15 minutes of dry time between coats. When spraying basecoats or clearcoats and using a cross-draft booth, I recommend starting in the rear of the booth because the air flows from the rear to front. Starting at the front and working toward the back, all of the overspray would land on the freshly coated surface. Moral: Follow the air flow. Start at the back and work your way forward. I also tend to work from top to bottom as well.
Clearcoat
Different brands and types of clear coats have different cure times. Processing time will vary depending on the type of clear being used. Some types of clear will permit color sanding in as short as two hours. To obtain a show-quality finish, use a high quality clear that cures more slowly. Allowing itself to flatten out more and then I'll let it sit over night before color sanding and buffing.
Color sanding
When color sanding, start with a clean bucket, clean water, and a clean block, so there won't be any dirt particles in between the sand paper and the finish to gouge the paint and cost more work, time, and money - all because you were too lazy to get up and get some fresh water.
Rich tip: It's a good idea to add a few drops of dish washing detergent to your water bucket, which allows the sandpaper to cut faster and last longer.
Start with a good block and some 800 grit wet sand paper to smooth out any imperfections and flatten out any orange peel. From here, use the 1000 grit to remove the 800 grit scratches. Then use 1200 grit to remove the 1000 grit scratches. Finally, use 1500 as a final step to remove the 1200 grit scratches.
Stay Away from the Edges. Always remember that the paint is thinnest at the edge. Once you burn through the paint, the only way to fix it is to sand the whole thing down and spray clear again.
Rich tip: Don't touch the edges - protect them with blue 3M vinyl tape. Also be careful about dips and crevices. Keep in mind that your buffer must fit in the same area with its pad.
Buffing and finishing
Grab a buffer, some 3M Heavy Rubbing Compound and a #1 wool pad to start buffing the finish back to a shine. Next, buff with a 3M Finesse-It Finishing Material. Then switch to a foam pad or a waffle pad and buff the finish with a glaze of your choice - either 3M or Meguiars, whichever you prefer. Finally, with a micro fiber cloth, apply some hand glaze and some Meguiars wax and polish for a pristine finish.
Conclusion
This is a summary of the process I use in finishing a car. I'm not saying that this is the text book standard - do it this way or don't do it at all. I'm just saying that this is the process I've developed by taking what I've been taught, what I've learned, and what I've proven to work in the last 20 years of winning awards, shows, plaques and trophies.
All the parts are here and can be used to take any vehicle from metal to finish, but if you would like a more detailed, in-depth instruction of this process, go to HuntingtonBeachBodyworks.com or KustomShop.com to order the '56 Metal to Paint Instructional DVD. There are a whole lot more tips and techniques included that spell out all the steps in this involved and somewhat overwhelming project.
Here's hoping this information will help many of you out there who are doing one-off projects. I'll be back again with a new custom paint project for you in a future issue..
Rich Evans, owner of Huntington Beach Bodyworks in Southern California, is an award winning painter and fabricator. Currently he is offering workshops at his facility so he can share his special techniques to other industry professionals. For more information about Evans, visit www.huntingtonbeachbodyworks.com
The project begins with a 1956 Chevy Bel Air Convertible sandblasted down to bare metal...
And ends up with a spectacular two-tone finish. This Chevy is ready for a drive along the coast or a trip to Lookout Point.
Using a long block in the early stages of sanding actually lets the block do most of the work.
When spraying paint, Evans recommends following the air flow by starting at the back of the car and working forward.
Proud owners Art and Dan Danchuk of Danchuk Manufacturing, Inc., the world's largest manufacturer and supplier of 55-57 Chevy parts in the world, prepare to drive off with their masterpiece in tow.
trifive is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-30-2006, 07:53 PM   #2
ProMetalShop
ProMetalShop's Avatar
Member #7
Send a message via MSN to ProMetalShop
Default
Thats just to darn cool makes me want to head back to the shop.
__________________
The ability to Shape Metal is often easier than Shaping Minds:
https://www.facebook.com/Prometalshop?ref=bookmarks
ProMetalShop Hot Rod Sheet Metal Fab & Shaping
4431 Snydertown Road.
Danville PA. (570) 204-7767
Steve's Prostreet.com
ProMetalShop is offline   Reply With Quote
Old 11-30-2006, 08:19 PM   #3
MikeKy55
Senior Member 4 Gold Stars
MikeKy55's Avatar
Member #10
Default
I pulled this picture from his site because it shows the one extra body mount on ragtops. They are the square pieces on each side.
__________________
''Thank a police officer for being the one who runs to a report of 'Shots Fired' while others run away.''
http://www.youtube.com/watch?v=8QuJeYqNzew
MikeKy55 is offline   Reply With Quote
Old 11-30-2006, 08:25 PM   #4
PaPa Mike
Senior Member 1 Gold Star
PaPa Mike's Avatar
Member #1257
Default
Otis, looks like you've done it again, added something else to the site to really help us all out. I'm proud to be a part of a group of guys like ya'll
Thanx again
__________________
PaPa Mike
I'd rather walk a mile wearing a BowTie----:p
https://www.trifive.com/webs/papamike/
PaPa Mike is offline   Reply With Quote
Old 11-30-2006, 09:58 PM   #5
trifive
trifive's Avatar
Member #1
Default
Thanks guys, I know that the success of Trifive is because of it's members, we are growing rapidly, with links from many popular websites and word of mouth we will continue to grow, I also have a deal in the works to buy an ad in the next Issue of Chevy Classic's Magazine, The magazine that is published only once a year and is for Trifive Chevy's only.
Remember together we Grow and make more friends daily, with the goal of Restoring and Preserving 1955-1956 and 1957 Chevy's.
Otis / Trifive
Old 12-02-2006, 09:17 AM   #6
Sweden
Trifive Leaders Club
Sweden's Avatar
Member #1166
Default
Hi Otis.
You do a fantastic job, im glad i found this site with all those nice people and you guys that work so hard to make this site better all the time.
Thanks for all the time you put in.
__________________
Ove
My Website!
My Pictures.
Sweden is offline   Reply With Quote
Old 12-02-2006, 09:44 AM   #7
dseale4888
dseale4888's Avatar
Member #228
Default
AWESOME!!!!!!! Thank you!!!
Dave
dseale4888 is offline   Reply With Quote
Old 12-05-2006, 07:57 AM   #8
kmc1955
Member
kmc1955's Avatar
Member #1383
Send a message via ICQ to kmc1955 Send a message via AIM to kmc1955 Send a message via Yahoo to kmc1955
Default good help topic
This is great . I'm learning more and more each day . Some of the topics jog my memory about stuf I've forgot about . Must be the old age thing kicking in. Great site
http://autos.groups.yahoo.com/group/...vroletandmore/
kmc1955 is offline   Reply With Quote
Old 12-07-2006, 12:42 AM   #9
Daffy
Member
Daffy's Avatar
Member #1109
Send a message via ICQ to Daffy Send a message via AIM to Daffy
Default
Very good...I picked up a few tips as well as finding out I'm doing most of it right....Thanks...
Daffy is offline   Reply With Quote
Old 12-07-2006, 09:58 AM   #10
1quick57
Member
1quick57's Avatar
Hungry Hungry Hippos Champion!
Member #78
Thumbs up Great Info!
Great information.....great site!
__________________
Art M
Wyalusing, PA
"I learn something new everyday"
1quick57 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
