Tanks Inc EFI tank drain plug problems! - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
User Name
Password
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 09-02-2019, 04:15 PM   #11
teahead
Senior Member 1 Blue Star
teahead's Avatar
Member #48198
Default
they come powdercoated? Or did you powdercoat it?
That may void the warranty right there.
__________________
1955 Nomad. About 90% done.
teahead is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-02-2019, 05:03 PM   #12
hutchenc
Senior Member 2 Gold Stars
Member #3786
Default
I have a Walbro GSL 392. Gonna go with the external set-up for now. Had to order some fittings for the external pump which won't be here for a few days.
Rinsed out my old stock tank and tested it for a leak at the drain plug...still good to go after all these years. It's too bad that Tanks Inc couldn't do a 2 minute gravity leak test! That woulda helped me out a bunch.
If the external setup doesn't work I'll move to a Holley in-tank setup using the stock tank. https://www.holley.com/products/fuel...s/parts/12-309
hutchenc is offline   Reply With Quote
Old 09-02-2019, 05:04 PM   #13
hutchenc
Member #3786
Default
They come powdercoated.
Old 09-02-2019, 05:49 PM   #14
BO185
LS Tech and Moderator
BO185's Avatar
Member #1955
Default
Remove the pump from the tank and bench test it. Could be simply loose pin on plug. Never know till you actually test.
__________________
Four Seasons Metalworks
-CnC Metal art
-Custom Signs
-Custom metal parts
-Powder Coating Services
Gen III/IV "LS" swap info
TECH: LS motor to Early Auto Transmission
Email or PM me your LS questions if you need help
[email protected]
-55 210 delray 235/3sp
-73 IH 1210 Travelette SV392, 5sp, 4x4, 4.10's
-73 IH Scout II Vortec 6.0L 4L65e np241
-01 VW Beetle TDI 50+MPG!
BO185 is offline   Reply With Quote
Old 09-02-2019, 07:15 PM   #15
hutchenc
Member #3786
Default
Alright...I gotta eat my words about the pump. My dumb ass didn't plug the harness in all the way on the pump assembly itself. Had to pull it to catch that...gave it +12 volts and voila!
Stupid, stupid error on my part.
Tank still leaks.
We'll wait and see what Tank Inc says about that. I could probably have it welded if need be.
Is there any kind of sealant that I could try on that bung area that will hold up to gasoline? I can see that it's a little porous...which is certainly where the leak is.
Old 09-02-2019, 08:37 PM   #16
hotrodg726
Trifive Leaders Club
hotrodg726 has made a donation to the forum!
hotrodg726's Avatar
Member #12165
Default
Tank still leaks.
we use this on aircraft it works great but is super sticky and stinks real bad until cured.
https://www.ebay.com/itm/CS3204-B2-F...4AAOxyHslQ72Ss
it has to cure over night
I would call tanks inc first.
__________________
1956 210 delrey sedan 383 700r4 12 bolt posi
1968 Camaro 468 bbc power glide 12 bolt
1968 Camaro 408LS power glide 12 bolt super gas
1971 el Camino 383LS 700r4 12 bolt posi
still searching for the right 56 nomad project.
hotrodg726 is online now   Reply With Quote
Old 09-02-2019, 09:29 PM   #17
BO185
BO185's Avatar
Member #1955
Default
Yeah figured pump was good, they rarely out of box fail, now for tank.
Any sealant will fail over time even “aircraft” type. I am an FAA licensed A&P and was an IA but let it lapse, I have used them all and seen them all fail, with fuel at some point. They may last years may not. You’re just prolonging the headache till later. Fix it right vs wasting your time and money. Not to mention that stuff in the listing is 6 years out if date based on date in picture on reason its “cheap”. We used PR 1440 B2 (same spec) and it was like $100 a tube those qt are like $200 each new. So yeah it will fail especially the out date stuff. Not to mention that sealant is spec for jet A not gasoline, I have never used AMS-S-8802 spec sealant in gasoline either. New it may last long time that out of date stuff not so much.
As for the tank leaking they may “take care of it” as its a manufacturer defect. Especially if you can get pictures of suspected bad area. Maybe they will swap it out.
If they will not warranty it you need to remove powder from area you believe is leaking. Easiest way to do this is mechanical remove it. Then if its in a seem or over a weld you can use “aircraft striper” in the local area. Remove all powder. Then I would fill tank as I described with water and watch were it leaks from remove pump and pick etc.. Mark area then have a welder fix the beads. Touch up paint area effected.
__________________
-CnC Metal art
-Custom Signs
-Custom metal parts
[email protected]
Old 09-03-2019, 11:51 AM   #18
kbuhagiar
Senior Member 1 Gold Star
kbuhagiar has made a donation to the forum!
kbuhagiar's Avatar
Member #670
Default
Hutch,
Give them a chance to make it right, and keep us posted on the outcome.
Good luck!
__________________
Cheers!
Ken in SSF California - 56 One-Fifty Two-Door Sedan
kbuhagiar is online now   Reply With Quote
Old 09-03-2019, 07:24 PM   #19
bigblock261
bigblock261 has made a donation to the forum!
bigblock261's Avatar
Member #1324
Default Fuel delivery is better without suction.
Sorry you're having to deal with this.
As much as it stings to have to consider welding, it's just all around a better solution IMO.
Having a gravity fed external pump, hanging low, and soaking up road heat is generally less modern than a fully pressurized (45+ psi?) back to front fuel cooled delivery system.
A smooth sea never produced a skillful sailor.
It's your car and your rodeo, and you are certainly entitled to build it your way.
__________________
It is not the critic who counts, not the man who points out how the strong man stumbled, or where the doer of deeds could have done them better. The credit belongs to the man who is in the arena, whose face is marred by dust and sweat and blood... who at the best, knows in the end the triumph of high achievement, and who, at least fails while daring greatly, so that his place shall never be with those timid souls who know neither victory or defeat.
bigblock261 is offline   Reply With Quote
Old 09-04-2019, 04:42 PM   #20
hutchenc
Member #3786
Default
OK...after much fuss, I think Tanks Inc and I have figured out what is wrong here.
I purchased this tank from a retailer and it appears that the wrong drain plug was sent with the tank. I bought it a long time ago, but I had all associated hardware in a labelled bag.
Here's the deal you all (with this same tank) should know if you happen to lose your plug or run into the same problem.
The plug on this tank is NOT a 1/4 NPT...it is a 1/4 -19 BSPT (British Standard Pipe Thread). The differences between NPT and BSPT are very subtle...differences in peaks and valleys (flat vs. rolled) as well as the thread angle (NPT is 60 degrees and BSPT is 55). You cannot tell the difference by the naked eye...you'd need to put one/both into a fitting to see what's what (or use calipers).
We're pretty sure that's what's causing the slow leak...just a subtle mis-match on the threads that even sealant resolve.
The rub is that finding one of these damn plugs is nearly impossible. Tanks has them available on their website here (http://www.tanksinc.com/index.cfm/pa...rod/prd635.htm) for a few bucks, but I was not able to find one anywhere locally. I even have a Fastenal dealer in town...they could get them, but only 20 at a time at a cost of nearly $100.
So don't lose this thing and if you think the plug you have isn't quite fitting right, check to see if it's an NPT fitting first!
My pop is a machinist so he had a tap for this thread sitting around (which is awesome) and Tanks is sending me two new plugs...I think it's gonna be ok, but even if it isn't, Tanks told me they will help me out on a new tank which is fair. Partly my fault, partly the retailer/vendor.
I'll update my original post to reflect all this I'm hoping the new plug will resolve this and I can get this thing started perhaps this weekend if I'm lucky.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
