Can't fix clutch shutter in 57 Corvette - Page 3 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > 1955 1956 1957 Corvettes Forum
User Name
Password
1955 1956 1957 Corvettes Forum 1955 1956 1957 Corvettes Forum, This forum is for 55-56-57 Corvette owners to ask questions and also give advice to other members about Trifive Corvettes
Parts on Ebay
Reply
Thread Tools Display Modes
Old 09-07-2018, 07:31 AM   #21
Man In Black
Member
Member #43602
Default
Quote:
Originally Posted by Rick_L View Post
So how did you have the transmission or bellhousing mounted with the aluminum bellhousing? It won't necessarily make a difference unless the mounting scheme was poor. Stock bellhousings are usually at least fair for runout, unlike aftermarket stuff. But given your problems it certainly won't hurt to measure and correct as needed. Likewise it's unusual to have parallelism problems, although it can definitely happen.
I've been playing with small block chevy's for over fifty years and this bell housing problem is new to me . In the past all you had to do was bolt one bell housing from a small block engine on to another small block . I never even heard of mis-alignment and having to use dial indicators until working on a C1. Now that I know that I have the correct cast iron and right year bell housing I'm hoping that it works .
Man In Black is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-07-2018, 07:38 AM   #22
Man In Black
Member
Member #43602
Default
Quote:
Originally Posted by Churchkey View Post
Flywheel bolted to the crank turn the motor over & dial indicate the flywheel it should run true. Had one that was machined improperly it was .040 out of true = clutch chatter.
Pilot bearing in the crank? is it worn out?
Check the trans front bearing retainer for wear from the throw out bearing.
Aluminum trans case? Check the trans to bell housing bolt "ears" many times they are broken off & welded on sometimes causing misalignment.
Your posi clunk during reverse: Rear tires may have different circumferences = the posi unloads when direction changes.
Pilot bearing is new, everything is new and good quality. Absolutely no wear on the bearing retainer , Nothing broken on trans or bell. Tires were all bought new and same size .
Old 09-07-2018, 05:46 PM   #23
Churchkey
Senior Member 1 Gold Star
Churchkey's Avatar
Member #25539
Default
Post 1:
"since there were hot burn marks on one half of the flywheel and pressure plate so I took it to the machine shop and had it checked and refaced"
Check the crank flange for burrs^^^^ indicates that the flywheel is not running true. If no burrs on the crank flange indicate the crank flange. indicate the face of the flywheel when on the crank.
Good luck
Churchkey is offline   Reply With Quote
Old 09-07-2018, 06:46 PM   #24
DavidY
Trifive Leaders Club
DavidY has made a donation to the forum!
DavidY's Avatar
Member #23645
Default
I'm surprised that no one has considered bad universal joints. One may be worn or binding up.
__________________
When in danger, when in doubt.
Run in circles, scream and shout.
DavidY is offline   Reply With Quote
Old 09-07-2018, 09:24 PM   #25
Man In Black
Member
Member #43602
Default
Quote:
I mentioned that it has new U-joints in the first post .
Old 09-07-2018, 10:07 PM   #26
Man In Black
Member
Member #43602
Default
I got the original cast iron bellhousing yesterday and found out that the one that was in there is a rare aluminum bell and will only work with a 1960 Corvette part #3764591 so apparently if it is only for 1960 , it won't work right for my 57. I don't know what the difference would be but if anyone needs one it will be for sale .
Old 09-07-2018, 10:34 PM   #27
DavidY
DavidY's Avatar
Member #23645
Default
Quote:
OK. You said you checked the universals but were they checked under load? I don't even know how you'd do that.
__________________
Old 09-07-2018, 10:36 PM   #28
Man In Black
Member
Member #43602
Default
They are new , nothing wrong with the u-joints .
Old 09-10-2018, 08:35 PM   #29
Man In Black
Member
Member #43602
Default
Post 1:
Good luck
I had a machinist friend come over Saturday and check everything with dial indicators . He said everything is within factory specs . Put everything back together with a different original cast iron bell housing and the problem is still there . I think it is time to take a close look at the inside of the trans for possible front bearing slop on the input shaft . I'm thinking maybe it is putting side force on the clutch disc . We will see .
Old 09-10-2018, 09:09 PM   #30
Rick_L
Member #2256
Default
I think you're chasing the wrong thing. And you don't have to tear down to check. Just indicate the input shaft to the front retainer. Indicator clamped to input shaft, plunger on retainer. You may have to get creative to figure out the best way to clamp.
Unfortunately I don't have any new suggestions. My thought is it's one of the things mentioned already.
Rick_L is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
