Southern Air A/C - Page 3 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > This is a list of our Official Sponsors , Quality 55-56-57 parts Click Here > Southern Performance Systems
User Name
Password
Southern Performance Systems Southern Performance Systems , Ask questions about Southern Performance Systems here.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 08-14-2019, 06:49 PM   #21
tekctrl
Senior Member 1 Silver Star
tekctrl has made a donation to the forum!
tekctrl's Avatar
Location: Fairview Heights, IL (12 mi's east of the St. Louis arch)
Member #24553
Default
Quote:
Originally Posted by acardon View Post
At one time the compressor was cycling on and off. What changed that?
The thermostst would cause the compressor to shut off if it were adjusted to 53 degrees. Does it shut off at that point?
The compressor had been cycling, but then stopped after one shop discovered that two heater hoses had been reversed on install and corrected it.
The S-R rep at the Nationals asked about the thermostat too but after inspecting the system said that it was set correctly.
__________________
American Tri-Five Association Member
Retired Vietnam era vet (Tech Control)
Yokota, Beale, Ramstein, McClellan, Torrejon, Scott, Osan
tekctrl is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-15-2019, 12:04 AM   #22
hotrodg726
Trifive Leaders Club
hotrodg726 has made a donation to the forum!
hotrodg726's Avatar
Member #12165
Default
the heater hose coming off the intake goes to the heater control valve. the return goes to the water pump. check this out and report back.
Sounds like the outfit that reversed your hoses was wrong. the clutch should cycle and if the heater is getting hot water then the clutch will never cycle because the A/C thermostat will never be satisfied due to the hot water in the heater core.
__________________
1956 210 delrey sedan 383 700r4 12 bolt posi
1968 Camaro 468 bbc power glide 12 bolt
1968 Camaro 408LS power glide 12 bolt super gas
1971 el Camino 383LS 700r4 12 bolt posi
still searching for the right 56 nomad project.
hotrodg726 is online now   Reply With Quote
Old 08-15-2019, 12:54 AM   #23
acardon
acardon's Avatar
Member #1888
Default
See post #12: ...........
Quote:
The Southern Rods rep at Bowling Green looked at it and advised that it was getting some hot coolant past the heater valve (not closing properly) and recommended putting vise grips on the heater hose going home and then two ball valves in (both hoses) to isolate the a/c system from the engine coolant when running the a/c. ............
Installed the two ball valves this afternoon (high of 84), made certain that they were both closed, and took it out to test the a/c with NO hot coolant to the a/c system ... no change. Measured temp still got no cooler than 53 ............
__________________
Don
Sent from my 1981 IBM 5150 PC.
acardon is online now   Reply With Quote
Old 08-15-2019, 09:59 PM   #24
tekctrl
tekctrl's Avatar
Member #24553
Default Southern Rods a/c not cooling
Dropped by a local speed shop (Old Dog in St. Louis) and talked with them about the a/c. Looks like one of those situations where everything is right but it still won't work. Asked them about what they'd want to rip our the S-R system and put in a V-A system. Approximately $5,000 to rip it all out and put in a new V-A system!!! Since I haven't won the Lottery lately, that's not happening. It'd be a lot cheaper for me to rip it out myself and then give them a clean slate...ripping stuff out is Easy...cut/cut/cut/rip/rip...trash/trash...done. I'd still rather have a fully functional S-R system, but will do it if I have to. The good news is that the summer cruises are winding down and there's time to try to figure this out. The earlier poster is right, this isn't rocket science...it's just that I'm quite ignorant about a/c systems. Don't want to spend the extra $$ or effort, but ....
We have all fall and winter to figure this out, along with our vapor lock issues.
__________________
Old 08-15-2019, 10:15 PM   #25
Rick_L
Member #2256
Default
Looks like they REALLY REALLY didn't want anything to do with your a/c!
Rick_L is online now   Reply With Quote
Old 08-15-2019, 10:43 PM   #26
hotrodg726
hotrodg726's Avatar
Member #12165
Default
you know you only have to replace the evaporator unit inside the car. the condenser, compressor can be reused. .
find the thermostat under the dash on the evap unit between the fan housing and coil box, and make sure it is turned fully counter clockwise. that's the coldest setting
__________________
Old 08-16-2019, 09:37 AM   #27
acardon
acardon's Avatar
Member #1888
Default
What did they do to determine that it can't be fixed? Did they put gauges on it? Did they use a laser thermometer to check the temps at different points of the system?
I would not change the evaporator, without knowing if the compressor is bad or the system is water logged or the condenser is too far from the radiator to get enough air flow.
Would you like to try to diagnose this yourself with help from the A/C experts on site here?
Borrow some gauges from an auto supply, connect them, run the idle up to about 1200-1500.
Read the pressures. (Write them down). Post them in a new post. We need current data.
Temp in front of radiator.
Center vent temp.
If the compressor cycles, how often and at what inside temp and pressure?
Cooling fan running?
__________________
Don
Old 08-16-2019, 01:51 PM   #28
hotrodg726
hotrodg726's Avatar
Member #12165
Default
Quote:
I agree Rick. that's the we don't want to do it price. in my shop a VA install is $1300-1500 for labor depending on the car. a tri-five is about as easy as it gets. the kit if you buy all the bells and whistles is between $1600 and 2000. so in my shop about $3500 max out the door.
I think the op needs to invest in some gauges, check pressures and take the time to fix it himself. along with checking hose routing etc. it almost sounds like it is over charged. most shops don't charge VA systems correctly and this is the issue.
__________________
Old 08-18-2019, 11:18 AM   #29
tekctrl
tekctrl's Avatar
Member #24553
Default S-R a/c won't cool
Even though the S-R rep at the TriFive Nationals said that the thermostat was set correctly, I'm going to try to open it up under the dash and look for myself.
I admit to being totally incompetent in a/c matters. Sort of like asking someone to dive under the hood of their PC and check/change settings and components. If you're experienced and knowledgeable, it's easy. If you aren't, it's very easy to do the wrong thing and make things so much worse.
__________________
Old 08-18-2019, 11:39 AM   #30
tekctrl
tekctrl's Avatar
Member #24553
Default
Center vent temp.
The 'a/c guru' that I was referred to by the staff of the Corvette Test Track i in Bowling Green put gauges on the system and said that everything was good except that the low-pressure side of the compressor was nowhere near as cold as it should have been. He tested the system with the engine idling and at operating temperature.
Engine cooling fan (electric puller, 1300cfm, with full shroud) runs just fine, with temp gauge rock solid at 190 even in B-G traffic.
Engine radiator has a/c condenser and trans cooler in front of it but the 'a/c guru' saw no issues with that. He did put the I-R temp gauge on the radiator and said it was good, though he didn't tell me what it read.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
