Old 08-12-2017, 12:17 PM   #1
xk49
xk49's Avatar
Member #42809
Default 225/70r15 on front with 2" Drop springs
Before I order a set of whitewalls does a set of 225/70r15's fit comfortably on the front of a 2dr hardtop 57 belair? Currently I have a stock suspension, but would like to do a 2" drop spindle in the future. Front wheels are 15x7 with a 3.0 or 3.5" backspacing.
The tire I'm looking at is the "Diamond Back LS5". I chose Diamond back because it was the only place I could find a 235/70 rear and a 225/70 front that had both a 3" wide whitewall band.
xk49 is online now   Reply With Quote
Old 08-12-2017, 10:17 PM   #2
mg57
Member #15886
Default Rubbing tires
You may have rubbing issues when you lower the front. On my 57 Hdtp I have the 2 inch dropped spindles (stock springs), 215/70r15's, 15x7 rally wheels. Don't know the offset measurement, but the wheel is less than 1/2 inch from outer tie rod so can' t get it any closer. Tires rub on fender when turning and and going over bumps. Also have aluminium engine (block & heads) but no A/C, so front end weight is less than factory. If you have disc brakes the wheels will be moved outboard more than factory, also contributing to the problem. Hope this helps.
mg57 is offline   Reply With Quote
Old 08-13-2017, 01:17 AM   #3
Roscoe7
Roscoe7's Avatar
Member #7496
See if these help;
http://tri-5.chevyrides.com/front_tire.php
http://tri-5.chevyrides.com/rear_tire.php
Adding some camber, and straightening the inner edge of the fenders will also provide clearance.
fender lip.pdf
Roscoe7 is offline   Reply With Quote
Old 08-13-2017, 02:54 AM   #4
Dean
Dean's Avatar
Member #14999
You may find that the drop spindles will widen your front track also. If you roll your inner guard you should be able to run a 215/65/15 on a neutral offset rim.
Dean
1957 Aussie RHD 454 BBC
Body off Restoration
Link to my build thread : http://www.trifive.com/forums/showthread.php?t=95502
Dean is offline   Reply With Quote
Old 08-13-2017, 11:09 AM   #5
xk49
xk49's Avatar
Member #42809
Anyone use the Percy Wheelrite tire measuring tool?
Might be worth the investment considering the new shoes are going to be like a grand.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
