steering issue - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Steering , Power and manual- Rack & Pinion - 605
Trifive Steering , Power and manual- Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Old 10-19-2019, 10:14 AM   #1
slantis
Member #6059
Angry steering issue
had a modified 605 box on 55 car, had a problem where the steering acted like it would lock but if you turned the steering wheel backwards then the steering was fine - long story short, after 2 old style steering columns and a new ididit column and new 500 series box, the steering is very touchy and there seems to be a flat spot in the middle of going straight where the steering wheel has no contact with from wheels - what am I doing wrong - all of the components under the car are tight and no slop or movement of tie rods, ball joints. Is very frustrating - using all original steering parts only with power steering and drove it for 15 yrs with now problem at all, then changed motors and this issue popped up
Please help !!!!!!!!!!!!!!!!!!
slantis is offline   Reply With Quote
Old 10-19-2019, 10:29 AM   #2
Old Buzzard
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
What p/s pump?
What operating psi?
Is the box centered?
Injector inspector.
55 210 sedan, rust bucket. The last hoorah!
Hotrodding and dragracing since 1955.
USAF, 67th Recon Tech. Yokota AFB, Japan.
6594th Test sqdn, Westover, AFB, MA. The guys that brought you the Cuban missile pics. 1960-64.
Old Buzzard is online now   Reply With Quote
Old 10-19-2019, 01:25 PM   #3
With aftermarket power steering, you have to have more caster than you can get on a tri-5 with stock control arms, to keep it from being touchy. Upper control arms are available with up to 5 degrees added caster.
The flat spot sounds like the pitman arm ball is not adjusted correctly in the center link. Fig. 5: http://chevy.oldcarmanualproject.com...55csm0903.html
Old 10-20-2019, 10:54 AM   #4
dhutton
Member #22238
Did you have the front end aligned? If not get it aligned and set with .25 - .5 degrees negative camber and as much caster as they can get, hopefully a couple of degrees.
1964 GTO - LS1 T56 - sold
1969 Firebird - LS1 4L60E - sold
1957 Belair hardtop - sold
1970 Z28 - sold
1969 Camaro - LSA 6L90E AME subframe and IRS
1966 Corvette coupe - sold
1968 Firebird - sold
1969 Camaro convertible LS3 4L65E for the wife
1957 Buick Caballero - huge project
1959 El Camino - big project
1956 Cameo - Dobbertin based C5 suspension
dhutton is offline   Reply With Quote
Old 10-20-2019, 01:45 PM   #5
oceangoer
oceangoer's Avatar
Member #14022
Yep, alignment.
If your steering is still Touchy, go to Turn One Racing, get their phone number and give them a call.
They manufacture pressure / Flow Valves that will provide lower PSI and Flow. Cost is about $45...
I was able to disconnected the high pressure hose back out the valve and replace it without removing the pump.
Shimming the Spring in the ps pump doesn't work properly,,, been there..
Michael..
oceangoer is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
