Stock front spring installation (1955) - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Old 01-27-2020, 02:11 PM   #11
dogface1972
dogface1972's Avatar
Member #46020
This is where this all came from.
GEOFF told me about Laszlo. Bought a pair of front frame horns from LASZLO last year. (http://www.classicedgedesigns.com/frames.html)
Another guy in town was making a restored stock 57 into a pro street. So I scored his new rebuilt upper/lower control arms and steering components, new drums/lines for $250.00. I thought I did well there.... In progress below. Last picture is the mangled horn I removed. The nice part is the welds (for the most part) are under the control arms.
dogface1972 is offline   Reply With Quote
Old 01-27-2020, 02:15 PM   #12
Since your not reusing the ball joint, you need a bigger hammer. Put the spindle on a solid surface and hit the ball joint stud, HARD. It will come out.
acardon is offline   Reply With Quote
Old 01-27-2020, 07:37 PM   #13
dogface1972
Member #46020
I mushroomed the heck out of that ball joint, heat finally busted it loose. Thanks acardon! So I think it's going well. I'm not sure how tight the the spindle nut is supposed to be? I tightened it until I could place the cotter pin in. It feels like there is 1/8 to 1/4 slack when I pull up on the axle flange. (if that's the correct term) But I did pack it with bearing grease. And I will bend that cotter pin all the way down once I verify the spindle nut torque.
Nice to see when you google anything "stock", every article and picture is about a conversion. Thanks google. Actually, I'm to blame I just need a 55 manual. I like paper, anyone has one PM me. If not I'll check ebay.
What is going to be a real hoot, is when I drive it in the spring and see how far off the alignment is. I heard when you change out the steering linkage to measure and count threads. I'm not rebuilding the steering linkage, just replacing with pained/rebuilt stock parts.
Old 01-27-2020, 09:38 PM   #14
Chris...Since you have ball bearings, the spindle nut is tightened as described in the 55 Shop Manual:
http://chevy.oldcarmanualproject.com...55csm0303.html
* See my painfully slow and overly detailed build thread here: https://www.trifive.com/forums/showthread.php?t=79427
* I have a vast data base of TriFive restoration & upgrade articles for our members' use...Send me a PM with your EMAIL ADDRESS and subject matter...See this link:
* Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
_________________david aka POPS & sherry
Old 02-03-2020, 08:58 PM   #15
dogface1972
Member #46020
One side finished. The threaded rod compressor is the ONLY way to go and it still took a few hours. The other side should go faster. 2 jacks can be helpful.
I found lining up one lower control arm bolt at a time, and starting them one at a time worked. You have to connect your upper and lower control arms to the spindle to get the compression geometry correct to line up the lower control arm to frame (4 bolts).
Old 02-04-2020, 01:23 AM   #16
Use 2 long bolts or rods to guide the lower control arm shaft up to the cross member. Then put the other 2 correct bolts in before taking the guide bolts out.
You shouldn't have to connect the spindle until it's in place, if you use guide rods.
Old 02-05-2020, 04:42 PM   #17
hddude
hddude's Avatar
Member #10516
i always took my coils to the local spring shop, had them "banded". went right in.
hddude is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
