Leaded Body Joints - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Metal Fabrication & Repair Questions > Paint & Bodywork Questions and Answers
Paint & Bodywork Questions and Answers Paint & Bodywork Questions and Answers
Old 05-09-2019, 07:15 PM   #11
55wagoncrazy
Stainless Trim Restoration
55wagoncrazy has made a donation to the forum!
55wagoncrazy's Avatar
Member #22828
Originally Posted by KiwiBelAir View Post
Mikey, this is exactly what had occurred when my body ma opened up the bubbling at the bottom corner of the rear window on the Poncho. It had rusted under the lead.
Yup, seen it a lot. The solder joint never comes up and is finished off under the window lip area. So the area under the trim and rubber are exposed and water accumulates under the seal and the stainless and penetration happens....
Mikey
40 Years of Professional Restoration of anything on a 55-57 Chevy
Michael Domoracki (Mikey)
The Stainless Shoppe Restorations
N8143 State HWY 55
Seymour WI 54165
Email: [email protected]
920 833 0290 Sunday -Friday 8AM till Sundown. Closed Sabbath until Sundown Saturday night
55wagoncrazy is offline   Reply With Quote
Old 05-10-2019, 06:33 AM   #12
Carmine
Member #6592
Several years ago, I was working on my '57 trying to get rid of an oil can type issue. While heating an area, all of a sudden I saw some silver type liquid product run down the quarter panel. WTH was that. I never realized that lead was used in some joints. Guess I really never thought about it. So after leading a joint, how would you finish it?? Has bondo type products been around for a long time. I agree with what has been said; leading is a lost talent/art, Carmine.
Carmine is offline   Reply With Quote
Old 05-10-2019, 12:44 PM   #13
LEE T
Member #24180
A wood paddle is used to smooth it out, and after it cools a file is used to finish it. Works very good on panel edges and seams. It can be sanded with certain types of sand paper, but a file is usually good enough.
LEE T is online now   Reply With Quote
Old 05-10-2019, 12:55 PM   #14
ezacres
ezacres's Avatar
Member #36923
interesting thread. I have a 55 1st series that both cowl panels are bad on. I've ordered the replacement panels. I plan on replacing these. I've been told that the joint at top is leaded. should I unmask the lead and see if there is rust. or patch around it?
this will be my first ever attempt at a full frame off restoration and while waiting for my panels to arrive have been debating this. to do the complete cowl panel is going to be a lot of work but have never messed with lead.. I will have the full panel but I'm not above just sectioning part of it. I have to replace the inner panel and the center between the inner and outer cowl.
what makes the best sense to do? The joint appears to be very good. what would you guys do?
ezacres is offline   Reply With Quote
Old 05-10-2019, 05:54 PM   #15
LEE T
Member #24180
Sorry, I don't know anything about the trucks, and I wouldn't make a recommendation on lead unless I was looking at the vehicle.
Old 05-10-2019, 09:42 PM   #16
56er_Fan
56er_Fan's Avatar
Member #36101
Very nice lead work! I'm assuming that wasn't your first attempt at working with lead?
56er_Fan is offline   Reply With Quote
Old 05-11-2019, 01:30 PM   #17
LEE T
Member #24180
Thanks, I've been doing it just long enough to be able to get it done without any problems, but no matter how good someone can do it, the use of it is limited IMO.
Old 05-11-2019, 04:11 PM   #18
NickP
NickP's Avatar
Member #2134
Originally Posted by acardon View Post
The lead can crack. Not so much on the sail panel joints, but I've seen a lot of nice paint jobs with cracks at the top of the A pillars.
Hey Don, a good day to you. I wonder, would the apparent cracks one sees in these paint jobs be attributed more to an underlying structural issue rather than the actual lead releasing its bond?
“Luck is what happens when preparation meets opportunity.”
NickP is offline   Reply With Quote
Old 05-11-2019, 04:33 PM   #19
fiftfiv
fiftfiv has made a donation to the forum!
fiftfiv's Avatar
Member #4933
Send a message via Skype™ to fiftfiv
Originally Posted by 55wagoncrazy View Post
For years I have just welded the whole recess with my mig welder. I take my time and work on multiple joints at a time to control the heat. I then grind it down and flow 2 part epoxy over the area. JB Weld works very well. Just like it was body filler. I like epoxy because it will self level and leave a nice finished area. I then sand after it has cured. I then go directly to a urethane primer as I block the car.
I don't like the idea of laying another sheet of metal over this, this will create a place for moisture to get trapped, and just like over lap joints, can cause rust formation.
Mikey
Mikey, do you mean welding just the seam where the two pieces of metal join or do you mean welding the complete joint which is about 1 inch wide?
fiftfiv is offline   Reply With Quote
Old 05-11-2019, 09:16 PM   #20
55wagoncrazy
Member #22828
Welding the complete area from recess to recess to level of the metal on either side.
Mikey
N8143 State HWY 55
Seymour WI 54165
Similar Threads
Leaded gas finder DavidY Chit Chat Area, Anything on your mind goes here. 5 05-14-2015 10:24 PM
u jOINTS KNOCKED OUT 4 SETS CHEAP U JOINTS ? boggesscharles Transmission and DriveLine Questions 20 10-28-2014 12:56 AM
Tail Pan and Removing Leaded Seams Rick Melloan Metal Fabrication and Repair Questions 14 12-12-2013 08:22 AM
Leaded gas bamiller Chit Chat Area, Anything on your mind goes here. 7 04-23-2013 09:05 PM
Leaded or unleaded. bamiller Chit Chat Area, Anything on your mind goes here. 12 08-18-2012 08:20 PM
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
