brake grabbing - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
User Name
Password
Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Parts on Ebay
Reply
Thread Tools Display Modes
Old 05-12-2019, 05:33 AM   #1
petenkim56
Member
Member #41219
Default brake grabbing
so i have put new disc brake setup on my 56 Chevrolet. I purchased a 4 wheel disc setup that came with everything from booster,master cyl,valve thing lines,discs,pads etc.all is well until i have done a few ks and things start to get hot,the pedal comes all the way back,but you can feel its like the brakes are grabbed and you can hear the engine is working to keep the car moving. i know there is wear in period but i have taken it out 3 times now and it does this after about 2 ks. now and again the pedal seems a little hard but otherwise it seems ok. when i stop there is resistance if you try to roll the car. but when it cools she will roll freely. when i fitted the pads they were a little tight getting on there but still went in without a fight. what can be wrong here.
has small block with 350 turbo box and yes vacume from manifold to booster
toms classic set up as well
petenkim56 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-12-2019, 09:39 AM   #2
acardon
acardon's Avatar
Member #1888
Default
Your pedal to booster or booster to master cylinder push rod is too long. This prevents the master from allowing the fluid to go back into the reservoir, thus traping pressure in the system. When the fluid heats up, it expands and causes lock up.
__________________
Don
Sent from my 1981 IBM 5150 PC.
acardon is offline   Reply With Quote
Old 05-12-2019, 09:41 AM   #3
Bossman
Senior Member 1 Blue Star
Member #13665
Default
It sounds like the rod that connects your brake pedal to the master cylinder needs adjusting and is not letting the master cylinder retract enough. Check to see that when the brake pedal is all the way back in its resting position that it is allowing the master cylinder to retract fully.
Bossman is online now   Reply With Quote
Old 05-12-2019, 08:10 PM   #4
petenkim56
Member
Member #41219
Default
awesome i will check those today and let you know. thanks for your replies
Old 05-12-2019, 10:57 PM   #5
SLIM
Senior Member 2 Gold Stars
SLIM's Avatar
Member #18096
Default
Simple way to test. When it's hot and the brakes feel like they are grabbing just loosen the 2 nuts holding the master and pull the master forward 1/4 inch or so, if brakes release you found the source. Now, if you can pull master completely forward and install a flat washer on each stud between the booster and master, your problem should now be gone completely
I don't think they (toms classic) checks any thing before they send it out=low bid
SLIM is offline   Reply With Quote
Old 05-12-2019, 11:25 PM   #6
acardon
acardon's Avatar
Member #1888
Default
If the pedal to booster rod is too long, shimming the master cylinder won't fix anything.
To test, push the pedal down with your hand. You should feel a "detent" after 1/8" to 1/4" of pedal travel, when the play between the pedal and booster link is taken up. Then another "detent" 1/8 to 1/4", when the clearance between the booster push rod and master is taken up.
__________________
Don
Old 05-15-2019, 03:34 AM   #7
petenkim56
Member
Member #41219
Default
YEP I JUST ADJUSTED THE PEDAL TO BOOSTER AND IT NOW WORKS GREAT. THANKS FOR ALL YOUR HELP
Old 05-15-2019, 10:13 PM   #8
mickeywestsr
Trifive Leaders Club
mickeywestsr has made a donation to the forum!
mickeywestsr's Avatar
Member #1970
Thumbs up
that's what I really like about this site .....
Cowboy
__________________
GO VOLS
COWBOY
mickeywestsr is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
*Brake Booster and Brake Issue 56-Curt Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc 20 01-06-2014 07:04 PM
CPP big brake kit E-brake Frozen North Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc 0 12-25-2010 07:08 PM
Hand brake / Parking brake 57danr Trifive Trucks Suburbans & Panel vans 4 08-04-2010 02:41 PM
Should I put in new brake lines and change to DOT 5 brake fluid? bsb1955 Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc 5 05-24-2010 06:58 PM
brake fluid shelf life....and other brake fluid questions Ari Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc 6 11-25-2008 11:02 PM
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
