Bellhousing Alignment SBC W/ 4spd Muncie - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Transmission and DriveLine Questions
User Name
Password
Ask all your Transmission and DriveLine Questions. Tranmission, Drives shaft, Rear End, Gears, etc
Sponsored By: QuickPerformance.com
Parts on Ebay
Reply
Thread Tools Display Modes
Old 05-12-2019, 10:46 AM   #1
Zman57
Senior Member
Zman57's Avatar
Member #28599
Default Bellhousing Alignment SBC W/ 4spd Muncie
I have searched threads and online regarding bellhousing alignment for manual transmissions and also watched a couple of You Tube videos on how to perform.
All of the articles deal with aftermarket bellhousings, and don't offer much on the original bellhousing. So I am going to put it out here for discussion. My setup is a mildly modified SBC with less than 400 Hp, plan on using the original bellhousing (with starter mounting) with front stock motor mounts and a newly rebuilt M20 Muncie transmission.
Is it necessary to check bellhousing alignment for this setup?
How did the factory ensure bellhousing alignment on the 60's muscle cars?
The problem that I am experiencing the setup of the dial indicator and trying to configure the dial indicator to check the readings . I am using this type of dial indicator. (Which was recommended on the Summit You Tube).
Hopefully someone has used this setup and can shed some light for me, this my first time attempting left me quite frustrated but today is a new day!!
Thanks,
Tony
Zman57 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-12-2019, 11:08 AM   #2
iequipu
Senior Member 1 Silver Star
iequipu has made a donation to the forum!
iequipu's Avatar
Member #23026
Default
I've done this application many times without complications. The alignment pins that are standard on the block is all you should need. If everything is in alignment the four speed should slide completely in the pilot bearing without having to draw up using the four bolts into the bellhousing
__________________
iequipu is offline   Reply With Quote
Old 05-12-2019, 12:29 PM   #3
Old 55-57 Fan
Member
Old 55-57 Fan's Avatar
Member #49570
Default
Agree with iequipu.
When using all original type parts especially, we just assembled them together and went on with it. Unless there was a problem after that for some reason, which would be pretty rare, we were good to go.
Good luck with it and keep us posted on it.
Old 55-57 Fan is offline   Reply With Quote
Old 05-12-2019, 12:35 PM   #4
Old 55-57 Fan
Member
Member #49570
Default
iequipu also mentioned "Pilot Bearing". If this is your first experience with a Manual Trans set-up, make sure you install one in the Crankshaft first, if one is not already there.
Old 05-12-2019, 04:46 PM   #5
nad427
Trifive Leaders Club
nad427 has made a donation to the forum!
nad427's Avatar
Member #25732
Default
There's an easier way than that dial indicator. This is a tool I plan to get for my toolbox. Might not get used very much, but vital when needed.
nad427 is online now   Reply With Quote
Old 05-12-2019, 05:36 PM   #6
topdog
Senior Member 4 Gold Stars
topdog's Avatar
Member #15087
Default
If you are using factory parts than all you need to do is bolt it together,. You would never see a dial indicator on a production line.
topdog is online now   Reply With Quote
Old 05-12-2019, 06:18 PM   #7
Rick_L
Member #2256
Default
I've used both the dial indicator and the Browell tool. Personally I prefer the indicator. So it can go either way.
Just because the factory didn't use a dial indicator doesn't make it right. They relied on whatever tolerances were in machining the individual parts. And there was some kind of quality inspection on the parts, maybe not 100% though. You're not talking just the bellhousing, it's the block and the crankshaft too.
The reason that indicator checking of the assembly became common for hot rodders was because Lakewood bellhousings are so much worse than stock bellhousings due to the way they are manufactured. Factory bellhousings have all the holes 100% machined - a Lakewood housing does not! The big hole is just a precision flame cut, but that precision flame cut is far from the accuracy of a boring bar in a milling machine.
Years ago when Detroit Diesel was part of GM, I was involved as a customer on a run of several dozen bellhousings on new engines that were far beyond GM specs. Also found out that GM specs were not as tight as SAE specs. GM and the DD dealer fixed them all at their expense - but they didn't pay for the broken hydraulic pump gearboxes their problems caused. Luckily we found the problem in time to limit that to a half dozen. So GM doesn't/didn't always make and check things to their specs all the time.
Rick_L is online now   Reply With Quote
Old 05-12-2019, 06:25 PM   #8
Zman57
Senior Member
Zman57's Avatar
Member #28599
Default
Well with a little help from a friend we managed to get the dial indicator setup and took the following readings.
We first made a couple of trial readings and we found that at 11' o clock was our negative reading and we set the Dial to zero and made that our starting point. 2 o'clock reading was 23 thousandths, 5 o'clock read 54 thousandths
and 8 o'clock read 28 thousandths.
Besides the readings here is what I found, the one bellhousing pin was damaged. Even though the damage is on the tapered end of the pin, it appears that it is deformed. I am thinking this might be causing me my problems. I am first going to try and get a OEM replacement pin and re-do the readings.
I have no idea why this pin was damaged or how it happened, and I am a little disappointed that I wasn't informed by the engine builder who did not point this out to me.
Old 05-12-2019, 07:29 PM   #9
Chuck Lea
Senior Member 1 Blue Star
Member #996
Default
Quote:
Agree.
I have a 56 Belair 2 dr HT. I removed the 265 ci engine and 3 speed manual and installed a 61 348 Tri-power stroker. The original cast iron bell housing, 168 tooth flywheel, clutch and pressure plate, starter and a M-21 Muncie all bolted right up to the engine. Everything was aligned, no pressure required to stab the tranny. I bought engine front side mounts, which positioned the engine/bell housing in the original position. I had to change only the worn-out pilot bushing and adapt the clutch cross shaft tube mounting on the engine, a simple 1" alum plate. Chuck
Chuck Lea is offline   Reply With Quote
Old 05-12-2019, 08:10 PM   #10
Rick_L
Member #2256
Default
Zman57, if your indicator reading are positive, then your bellhousing is .027" too high on the 11 o'clock to 5 o'clock axis, and it's to the right by .0025" in the 2 o'clock to 8 o'clock axis.
Given how your driver side dowel pin looks, I would replace it with another straight one and make the measurements again.
.021" is the biggest offset I can find quickly. Hopefully a new straight pin will show that you can fix it with an .021" or less offset pin.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
327 and Muncie 4spd in Pa Tug686spd Classifieds section of Trifive , For Sale items ONLYl, DO NOT POST WTB OR TRADES IN THIS SECTION 3 09-11-2017 05:46 PM
LS swap with stock bellhousing and 4spd? field57 Super Stock / Pro Street and Modified Discussion 55-56-57 3 06-21-2014 01:21 PM
muncie 4spd dejavu Chit Chat Area, Anything on your mind goes here. 6 08-11-2013 03:40 PM
454 4Spd W/Stock Bellhousing? OldSchool57 Big Block Install Questions and Answers 12 05-23-2009 08:23 AM
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
