Bellhousing Alignment SBC W/ 4spd Muncie - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Transmission and DriveLine Questions
User Name
Password
Ask all your Transmission and DriveLine Questions. Tranmission, Drives shaft, Rear End, Gears, etc
Sponsored By: QuickPerformance.com
Parts on Ebay
Reply
Thread Tools Display Modes
Old 05-12-2019, 09:06 PM   #11
DZAUTO
Senior Member 1 Silver Star
Member #3643
Default
ALLLLLLLLLLLLLLLL my cars with a Muncie(5), have a pure bone stock Chevy bell housing (both iron and alum) and good dowel pins on the rear of the block.
My 51 Chevy was the first car to get a Muncie (1968). I put it together with a 55-57 style bell housing. I absolutely DO NOT DISPUTE making the effort to align a bell housing. BUT, I have never had any issues with GM/Chevy parts for a manual transmission installation.
I have one Olds that is a FACTORY 5sp car (I ordered it new). The original small Olds V8 was replaced with an Olds 455 in 87, and the puny factory 5sp replaced with a Richmond Street 5sp, then the 455 was rebuilt to W30 specs in 2013. The bone stock Olds alum bell housing was used with the Richmond street 5sp tranny and it has performed flawlessly ever since.
So when it comes to bolting a bone stock Chevy bell housing to a Chevy engine and the bolting a manual tranny to the Chevy housing without taking the effort to index the engine/housing/tranny, I'm a believer.
Now, one exception to the above. My 23 T-bucket has a scattershield, which was on the car when I bought it several years ago. I have no clue if it was indexed. But the Muncie behind it works fine.
Have I just been lucky over the years? Maybe so, but if it ain't broke, I ain't fixin' it!
__________________
Tom Parsons
DZAUTO is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-12-2019, 09:11 PM   #12
Churchkey
Senior Member 1 Gold Star
Churchkey's Avatar
Member #25539
Default
Bellhousing dowels are .625 = 5/8.
Cut a piece of 5/8 round bar stock grind a taper on the ends or use a long 5/8 bolt & cut the head & threads off & taper the ends.
Churchkey is online now   Reply With Quote
Old 05-13-2019, 11:10 AM   #13
Dragsix
Trifive Leaders Club
Dragsix has made a donation to the forum!
Dragsix's Avatar
Member #20785
Default
I have always used guide pins on the bellhousing to install the transmission. If the trans goes in with nothing more then a little wiggle of the output shaft to align the clutch splines, then I am good to go. Lakewood scatter shields can be a bit of a challenge sometimes, but not always. I do the same thing, if the trans does not just slide in on the guide pins, then I will dial in the bell housing (which really dislike doing and is a big giant pain in my opinion.) I will have to try one of those tools instead of dial indicator. Seems like an less frustrating method.
__________________
ATFA Charter Member #23
Dragsix is online now   Reply With Quote
Old 05-15-2019, 10:13 PM   #14
Zman57
Senior Member
Zman57's Avatar
Member #28599
Default
Well a little update , I started off tonight with replacing the bad bellhousing alignment dowel with a new Moroso dowel. The Moroso dowels were not the stock length but the longer dowels. I thought that I was receiving the stock length from the local auto store that I ordered them from but ended up with the longer dowels.
The readings became better but still not within tolerance. With nothing to lose I replaced the other pin as well hoping for a little luck that we would be in tolerance but we are still out. My last set of readings with two new pins are, 12 o clock 0 , 9 o clock 4 thousandths,
6 o clock 30 thousandths and 3 o clock 28 thousandths.
If I am understanding this correctly, I need a pack of 0.14 Offset pins to go in the 10 o clock position.
Zman57 is offline   Reply With Quote
Old 05-15-2019, 10:41 PM   #15
Rick_L
Member #2256
Default
You are correct on the .014 dowels to fix the problem, according to your measurements.
Your measurements also follow the same trend except that your new dowel cut the error in half.
Rick_L is offline   Reply With Quote
Old 05-16-2019, 02:47 AM   #16
Speedi D
Member #11974
Default
Rick/ Just a question: what is the max dim he's looking for?
Speedi D is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
327 and Muncie 4spd in Pa Tug686spd Classifieds section of Trifive , For Sale items ONLYl, DO NOT POST WTB OR TRADES IN THIS SECTION 3 09-11-2017 05:46 PM
LS swap with stock bellhousing and 4spd? field57 Super Stock / Pro Street and Modified Discussion 55-56-57 3 06-21-2014 01:21 PM
muncie 4spd dejavu Chit Chat Area, Anything on your mind goes here. 6 08-11-2013 03:40 PM
454 4Spd W/Stock Bellhousing? OldSchool57 Big Block Install Questions and Answers 12 05-23-2009 08:23 AM
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
