Steering column to dash mount - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Steering , Power and manual- Rack & Pinion - 605
User Name
Password
Trifive Steering , Power and manual- Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Parts on Ebay
Reply
Thread Tools Display Modes
Old 05-12-2019, 10:49 PM   #1
northern56
Senior Member 1 Blue Star
northern56's Avatar
Member #7202
Default Steering column to dash mount
Went to mount the column back in place today, one of the mounting studs stripped out. Are these studs welded in place from the factory?. A couple good whacks with a ball peen hammer wouldn't pop the stud. Is it a matter of cutting off the stud flush and drilling it out, or hopefully a simple solution. Thanks.
Larry.
northern56 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-12-2019, 11:04 PM   #2
557B210
557B210 has made a donation to the forum!
557B210's Avatar
Member #5571
Default
Larry...Are you talking about the bolts that mount the lower steering bracket?
https://www.trifive.com/garage/56%20...Manual/9-5.gif
Or the two studs on the brake pedal brace that hold the upper end of the column in place?
__________________
______________________
-I have a vast data base of TriFive restoration & upgrade articles for our members' use...Send me a PM with your EMAIL ADDRESS and subject matter...See link below:
https://www.trifive.com/forums/showthread.php?t=175309
-Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Old 05-12-2019, 11:30 PM   #3
acardon
acardon's Avatar
Member #1888
Default
Quote:
Originally Posted by northern56 View Post
Went to mount the column back in place today, one of the mounting studs stripped out. Are these studs welded in place from the factory?. A couple good whacks with a ball peen hammer wouldn't pop the stud. Is it a matter of cutting off the stud flush and drilling it out, or hopefully a simple solution. Thanks. Larry.
The studs are welded in. You'll have to cut them off and drill out to use a bolt.
__________________
Don
Sent from my 1981 IBM 5150 PC.
acardon is offline   Reply With Quote
Old 05-13-2019, 10:40 AM   #4
icody
Senior Member 1 Gold Star
icody's Avatar
Member #10880
Default
Larry.
Can you run a die on the stud using a different thread pitch (say a Metric Thread so that you can then use a different nut to tighten it in place...you will be the only person that knows its two different size threads and nuts)!
Just an easy way to fix it.
__________________
Gasserville, TX (actually, San Antonio)
icody is offline   Reply With Quote
Old 05-13-2019, 12:13 PM   #5
northern56
northern56's Avatar
Member #7202
Default
I'm referring to the upper mount
Old 05-13-2019, 01:20 PM   #6
557B210
557B210's Avatar
Member #5571
Default
Got it now Larry...Agree with the above recommendations....If you can not re-thread the stud(s), you will have to cut off and replace with bolts....Probably will have to use a Dremel tool with a cut-off wheel.
__________________
Old 05-15-2019, 07:49 PM   #7
northern56
northern56's Avatar
Member #7202
Default
Tried this idea w/ 7mm. die nut. Not enough room to turn the die nut because of the contour of the dash. Dremel tool & cut off wheel did the trick. Thanks to all who replied.
Larry.
Old 05-15-2019, 10:22 PM   #8
557B210
557B210's Avatar
Member #5571
Default
Glad you got 'er done Larry
__________________
Old 05-15-2019, 10:38 PM   #9
Gary’s-Classic-Chevys
Gary’s-Classic-Chevys's Avatar
Member #42718
Default
Yep, unfortunately I had the same issue last fall on my 56 Chevy, one of the studs securing the steering column was broken off. Found out the other stud was welded in place, so I drilled the partial stud out and installed a new bolt in its place...
Glad to hear you got it repaired.
__________________
American Tri-Five Association Member!
1974 Chevy Nova 2 door- 2nd owner.
1957 Chevy 2 door Sedan 150. (Next Project)
1956 Chevy 2 door Sedan 210.
(On last leg of the project)
Retired United States Army....
Served with the 11th Armored Cavalry Regiment, Fulda, Germany, 101st Airborne Division Fort Campbell, KY, 8th US Army ROK, Fort Polk, LA, 9th Infantry Division, Senior IT Consultant, US Government
Gary’s-Classic-Chevys is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
*Under dash support bracket for dash mount mirror monkey Stock Chevy Discussion 55-56-57 8 12-26-2014 07:24 PM
Ididit steering column slop at dash mount Johnny Blaze Super Stock / Pro Street and Modified Discussion 55-56-57 13 11-26-2014 11:06 AM
Where to mount steering column under dash TBHigdon Stock Chevy Discussion 55-56-57 5 09-03-2014 07:57 AM
rubber mount for a steering column tach thehazmatguy Electrical Questions and Answers 34 03-09-2013 02:14 PM
1955 Chevy A-Arms, Manual Steering Box, Steering Column. Impy's Steering Wheel Hub Adapter. Brian TriFive related Ebay auctions and Craigs List, Links to other sale sites 1 09-12-2009 08:57 PM
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
