Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Old 08-12-2017, 03:39 PM   #1
dexter57
Member #39932
Default 350ho flexplate
anyone got a solution for a flexplate that will work on a cast iron powerglide and a 350 ho? the 350 has a11.5 bolt pattern ,the pg has a 12.25.i have not seen any larger than 11.5
dexter57 is offline   Reply With Quote
Old 08-12-2017, 05:59 PM   #2
Tropturq
Tropturq's Avatar
Member #33781
As far as I know, no one makes an aftermarket flex plate that will bolt to a cast iron powerglide. You have to use an original.
Tropturq is online now   Reply With Quote
Old 08-12-2017, 07:36 PM   #3
TheHotrodHandyman
TheHotrodHandyman's Avatar
Member #8438
What year is the engine, One or two piece rear main?
-Bruce
Old 08-12-2017, 08:36 PM   #4
dexter57
Member #39932
new 350ho crate 1 piece crank seal. the issue is the flexplate from the new engine won`t fit the pg because the torqe converter has 11.50 boltpattern, the pg has 12.25.the flexplate from the pg won`t fit the because the bolt pattern is much larger. crank bolt pattern is 3 inchs on the 350
Old 08-12-2017, 11:22 PM   #5
just re-drill the flex plate for the power-glide pattern. easy peasy.
hotrodg726 is offline   Reply With Quote
Old 08-13-2017, 08:41 PM   #6
dexter57
Member #39932
tks for the tip hotrodg .didnt drill new holes but carved the holes out with a die grinder 3/8 each hole. trans bolted to the engine now. hopefully the flexplate won`t fly apart on me with the modification.
Old 08-13-2017, 09:04 PM   #7
TheHotrodHandyman
Member #8438
I would be more worried about the cast iron P/G trans flying apart behind a H/P crate engine. Pretty sure you have to run a 168 tooth flex plate with it as well.
-Bruce
Old 08-13-2017, 10:14 PM   #8
You are very correct on the number of teeth on a cast iron flex plate Bruce....Maybe with the correct starter it will work
Originally Posted by rrempala View Post
I need to replace the flex plate on my 1956 BelAir that has a 265 V8 and a cast iron Powerglide. The old plate has 168 teeth.
_______________________________
Old 08-14-2017, 09:15 PM   #9
dexter57
Member #39932
168 is in there tks guys
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
