Squealing front right brake - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Old 08-20-2019, 03:27 PM   #11
copymutt
copymutt has made a donation to the forum!
copymutt's Avatar
Member #36997
If cause is not readily visible, try swapping drum side to side.
Jim
Nothing is foolproof for a sufficiently talented fool.
copymutt is online now   Reply With Quote
Old 08-20-2019, 06:41 PM   #12
Dragsix
Dragsix's Avatar
Member #20785
X2 on the drum issue. Also, I dont believe its possible to simply bolt on rear backing plates to the front but maybe you can. Hopefully someone can confirm one way or the other.
As for the ball bearings, they don't squeal, well not in my experience anyhow, when they wear out, they vibrate and grumble. No, you cant mix and match bearings so you cant install a tapered outer bearing in a stock hub (they made tapered bearings for the stock hub at one time but I have not seen them for probably 30 years or better.) The key to the ball bearings is to keep them clean and packed with fresh grease, and to install and adjust them according to the shop manual, with a torque wrench, to set the bearing into the race and to put the proper preload on the cages and balls. Mine are 30 years old, at least.
When they do go bad, you might consider changing over to the tapered bearings. The tapered Bearings are cheaper and can take a side load better.
ATFA Charter Member #23
Dragsix is online now   Reply With Quote
Old 08-20-2019, 08:41 PM   #13
The front backing plate is going to have a hole for the anchor bolt which if I remember correctly also fastens the wheel cylinder. The wheel cylinder on the rear is attached differently.
Same goes for the steering arm bolts.
Old 08-20-2019, 09:12 PM   #14
SLIM
SLIM's Avatar
Member #18096
Let alone the different bolt pattern and the e brake cable attachment
SLIM is offline   Reply With Quote
Old 08-21-2019, 07:22 PM   #15
rmalott
Member #29464
Default Squealing brake
Changed out the backing plate with a fair used one that had very little wear on the plates. I drove it around the block (about 3 miles) and so far I'm hearing nothing. Hopefully it's fixed. I've had (11) 57 Chevys and all kinds of other cars, put brakes / pads on many of them but never changed a backing plate.
rmalott is offline   Reply With Quote
Old 08-21-2019, 11:36 PM   #16
First time for everything I suppose...Hope you got it fixed now
Old 09-01-2019, 12:37 AM   #17
kerrynzl
kerrynzl's Avatar
Member #46076
Originally Posted by rmalott View Post
Supposedly, you can use a rear plate on the front even thou it has 4 bolt holes instead of two. I'll find out.
It is a totally different pressing.
GM did this to allow for narrower rear shoes even though they used the same drums front and rear.
You cannot put front brake shoes on the rear brakes because of this.
kerrynzl is online now   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
