Charging Problem Solved - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Electrical Questions and Answers
Electrical Questions and Answers This is the place to ask all your question about electrical problems and instalation issues.
Old 06-04-2011, 11:34 PM   #1
trifive
trifive has made a donation to the forum!
trifive's Avatar
Member #1
Default Charging Problem Solved
After months of trying different things to solve my problem with alternators quit charging after a few minutes driving.
I have a big block with little room
1. Went thru 5 different alternators
2. They all charge when cool
3. Added new ground wire, new hot wire.
4. Added new resistance line, added new resistor.
Used different brands of alternators, but they all had the gm design, one fan on front for cooling.
5. Tried different amp alternators from 45 amps thru 160 amps.
6. Tried 3 wire alternators, and single wire alternators.
So finally I decided it had to be a cooling problem, because once the alternators cooled down they all started charging again.
When the alternators got hot the internal regulators would shut down.
Solution.
CS-130D alternator
It mounted to my gm brackets no problem.
I changed it to a v belt pulley.
Next you need a pigtail adapter.
Delco pigtail connector from Painless Wiring
The CS-130D alternator was introduced as the standard application for most GM vehicles. It came standard as 100 & 105 amp models. Although it only adds a "D" to the CS-130 designation, the CS-130D alternator is completely different from the earlier CS-130 series (shown below). None of the parts are interchangeable. 1994 to 1996 GM used both the CS-130 and CS-130 D. You must visually check to see which unit you have if your vehicle is within the transition years.
Improvements over the CS-130 Alternator include:
  • More open design for better air flow
  • Larger bearings
  • Dual Internal Fans to increase air volume
  • Regulator and Rectifier located on the outside, away from stator and rotor heat.
trifive is offline   Reply With Quote
Old 06-05-2011, 12:03 AM   #2
Chrome Lugnut
Chrome Lugnut's Avatar
Member #14896
Good Information to know.
thanks
Otis
Les AD1 USNR-R
Sometimes the things that may or may not be true are the things that a man needs to believe in the most: that people are basically good; that honor, courage, and virtue mean everything; that power and money, money and power mean nothing; that good always triumphs over evil; that love, true love, never dies... No matter if they're true or not, a man should believe in those things because those are the things worth believing in."Hub McCann Secondhand Lions"
Chrome Lugnut is offline   Reply With Quote
Old 08-17-2011, 11:39 PM   #3
fiddlerpin
fiddlerpin's Avatar
Member #11649
good info. Does it need an external fan being it has 2 internal ones? Jim
fiddlerpin is offline   Reply With Quote
Old 08-17-2011, 11:52 PM   #4
No, it doesn't need another fan.
That's a good upgrade but upgrade the wire from the alternator to the battery/starter if you go to the high output alternator.
The pigtail pictured is for a 10SI alternator. A CS130 uses this type pigtail.
Old 08-18-2011, 12:01 AM   #5
mickeywestsr
mickeywestsr has made a donation to the forum!
mickeywestsr's Avatar
Member #1970
Thumbs up
Hoss, you've got the patience of Job........
GO VOLS
COWBOY
mickeywestsr is offline   Reply With Quote
Old 10-19-2011, 11:18 PM   #6
hawaiian
hawaiian's Avatar
Member #19837
I am new to this, I have a stock dash on a 56 and i want to install a new alternator,instead of the generator... can i still use the original dash instruments? It has a idiot light.
hawaiian is offline   Reply With Quote
Old 10-19-2011, 11:23 PM   #7
trifive
trifive's Avatar
Member #1
Yes you can use your dash instruments with this alternator.
Acardon is our electrical expert hopefully he will post more on this subject.
otis
Old 10-19-2011, 11:27 PM   #8
angs1957
Super Moderator
angs1957 has made a donation to the forum!
angs1957's Avatar
Member #2237
glad to hear you were patienant enough to sort it out
angs1957 is offline   Reply With Quote
Old 10-19-2011, 11:55 PM   #9
rwhit57
rwhit57's Avatar
Member #10871
5 alternators? Oh wait maybe it was the 1000 -6500rpm, 1000-6500rpm, 1000-6500rpm, I think they are intended for continuous duty, not continuous acceleration!! LOL
RW in Tulsa
(Randy)
Whoever said "Money can't buy happiness" Has obviously never seen a SPEED SHOP!
rwhit57 is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
