Temperature Gage reading problem - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Electrical Questions and Answers
User Name
Password
Electrical Questions and Answers This is the place to ask all your question about electrical problems and instalation issues.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 10-15-2019, 04:54 PM   #1
atars
Senior Member 1 Silver Star
atars has made a donation to the forum!
Member #5126
Default Temperature Gage reading problem
I started with the original sensor and a replacement gage. I replaced the sensor with one that reads 680 ohms cold. The gage worked. But it moves all the way to the right. The sensor was not an AC Delta unit. So I got one of those and still have the same problem. The gage does not move until I increase RPM above idle. Then it moves up like the gas gage does when filling the gas tank. It stops when I go back to idle. When I turn off the engine for a minute or two and then back on the gage remains at the left until I increase RPM.
I tried testing the gage by varying the resistance in the circuit. I removed the connector from the sensor and placed a potentiometer between that connector and engine/battery ground. I varied the resistance from 700 down to 150 ohms to see if the gage would follow my variable resistance. No movement.
Was that the wrong way to test the gage in the car?
Is there something else that I must do to ensure that there is voltage in the circuit?
Should I turn on the engine and run that test again?
I checked both of the two new sensors by heating them with a hair dryer. The resistance in both were around 700 ohms and the resistance decreased as temp increased.
Tom
atars is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-15-2019, 05:33 PM   #2
acardon
acardon's Avatar
Member #1888
Default
Is the gauge terminals wired correctly? 12 v. tan wire on the drivers side terminal and sensor on the passenger side terminal.
__________________
Don
Sent from my 1981 IBM 5150 PC.
acardon is online now   Reply With Quote
Old 10-15-2019, 11:11 PM   #3
atars
Member #5126
Default
Acardon: Almost 100% sure, but will double check again in the morning.
Old 10-16-2019, 06:10 PM   #4
atars
Member #5126
Default
Quote:
Dark brown toward the driver door terminal and green on the other terminal. I was able to see the studs from below the instrument panel and checked the tightness of the the nuts that secure the back plate to the gage assembly.
After posting this thread, I saw the sticky on the 56 gage. Noted the problem with the grounding against the back plate.
After tightening those nuts I want to run the engine after rain stops to see if that makes a change.
Old 10-16-2019, 10:25 PM   #5
fiddlerpin
Senior Member 4 Gold Stars
fiddlerpin's Avatar
Member #11649
Default
fiddlerpin is online now   Reply With Quote
Old 10-16-2019, 10:28 PM   #6
fiddlerpin
fiddlerpin's Avatar
Member #11649
Default
Dark brown is the generator wire. The wire should be tan. Green to sensor. Might explain why you get a reading after revving up the motor.
Old 10-17-2019, 12:04 AM   #7
atars
Member #5126
Default
Quote:
I should have read Don's comment more carefully then I did. I can not see up there. So I put my finger on the post and followed the wire down to see the brown wire. I can see the tan wire in the same area.
Yes, I mentioned that the gage rises as I increase the engine Rpm.
I'm going to confirm my conclusion. If so, I hope to be able to swap the wires without having to remove the panel.
Thank for your information.
Old 10-17-2019, 06:54 PM   #8
atars
Member #5126
Default
Yes. Tan wire is correct. Brown is on the generator light. The generator light also flashes a little as I accelerate and the temperature gage increases movement up to the right. Any idea what can cause these indications?
Old 10-18-2019, 11:53 PM   #9
atars
Member #5126
Default
Is it likely that the new gage and sensors that I have are not direct replacements for the OEM parts?
Old 10-19-2019, 08:50 PM   #10
kerrynzl
Senior Member 1 Blue Star
kerrynzl's Avatar
Member #46076
Default
Quote:
Check the ground wire between the generator and regulator body.
And also try a jumper cable to help ground around the temp sender body to the car body.
With a poor ground, the charging system might be trying to find a better ground via whatever circuit is a available
kerrynzl is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
