'39 Chev coupe build - Page 14 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Non TriFive Vehicles Special Category > Non Trifive Vehicles
Non Trifive Vehicles Ask all your questions Here about any non Trifive Vehicle, Any year any make or any model. As long as it has a motor and wheels this is the place.
Old 09-17-2019, 06:28 PM   #131
1971BB427
1971BB427's Avatar
Member #16997
Got a new heavier circuit run out to the shop today, so I can weld with my Mig turned up full and not have tripping breakers constantly! Ran it with oversized wire, and a new route to reduce the length of the run, and also reduce voltage loss from resistance. So it should be good to go, and not have any issues now.
Will get back on fabricating mounts tomorrow, and test out the new feed to the shop.
1971BB427 is offline   Reply With Quote
Old 09-18-2019, 03:01 PM   #132
1971BB427
1971BB427's Avatar
Member #16997
Tack welded the mounts to the base plates, and then removed them from the car to weld them right side up. Cleaned up the shackles and bolted it all together again. Then tacked all four base plates to the frame with a single tack on each corner. Nothing permanent in case I need to adjust once the rear axle is done, and engine weight is on the suspension. Then if it's all still good I can permanently weld it up.
But it's sitting on the tires now, and ready for me to move to the rear suspension. Having a heck of a time figuring out how the rear shackles come apart? They have a single bolt in the middle hole, but when I removed it nothing seems to want to come apart. I pried and beat on the shackles, but they seem to be pressed on the top and bottom shafts. Those shafts are hollow and have zerk fittings. Removed the fittings, but no joy. Have to do some internet searching and then go caveman on them if I can't figure out how to gently remove them.
Also got the permanent front crossmember tacked in. Made it from some round tube I had leftover from the '63 Falcon build. Looks better than box tubing up front.
Old 09-18-2019, 08:18 PM   #133
1971BB427
1971BB427's Avatar
Member #16997
Thanks to a Google search I found an online copy of the 1939 Chevy shop manual! It shows the rear shackles are tapered pins on each end, and they simply hold the shackle with the taper, and that single center bolt.
I'll make up a piece of running thread with a nut on each end so I can put it between the shackles to push them apart. Then with tension on them I should be able to give them a good strike with the hammer and pop them free.
http://chevy.oldcarmanualproject.com.../39csm090.html
Old 09-18-2019, 08:59 PM   #134
blackwidow
blackwidow's Avatar
Member #23348
You are hustling on this build that breaker is going to be tested for real!
How is the flooring holding up and is there any difference kneeling on it.
As always spectacular craftsmanship!
Anyone have TIME for sale....I could use some extra!
blackwidow is offline   Reply With Quote
Old 09-18-2019, 10:26 PM   #135
1971BB427
1971BB427's Avatar
Member #16997
The flooring is holding up great. I do put wood under the jack stands when holding the car up as I think the sharp feet would dig in. I noticed that things slide easily on this flooring, which can be good and bad. Easy to slide things around, but I can also have things slide if I'm not careful. And little bits of junk can drop into the mesh surface, so sweeping isn't an option. I have to use the shop vac to clean up and pull the dirt out of the floor tiles.
But it's great to kneel on, or lay on, and much easier on my bones doing either. I still use my kneeling pads because I've got bad knees. But if it's laying down to work this is much warmer than concrete!
This is the part of a build I love! The fabrication of drivetrain and suspension is my favorite thing on a build. I keep digging through my storage shed and coming up with parts I've accumulated from the last couple decades of building. Yesterday I came across a complete set of ladder bars with all the mounting hardware, including the upper shock mounts and crossmember for coilover shocks. I wont be doing coilovers, but will try and use the upper mount for my shocks, and the ladder bars to work with my leaf springs.
Old 09-19-2019, 07:13 PM   #136
1971BB427
1971BB427's Avatar
Member #16997
Went over to Mike's today to pull the body off one more time on his '35. It will be off for some time to do bodywork and seal it.
After an short day I came home to find about 5 packages sitting at my door. So I grabbed them and headed to the shop. The 5/8"-LH heim joints were in the packages so I made up my tie rod! 1.25" OD tube to eliminate any flex or death wobble.
Then I moved to the rear of the car and pulled the 9" Ford rear axle so I can begin reworking leaf springs and install the 8.8" Ford axle.
Old 09-19-2019, 07:42 PM   #137
carls 56
carls 56's Avatar
Plops Champion! Ninja Turtles 2 Champion! Altex Champion! 2 Ball Pool Champion! Monkey Cliff Diving Champion! Baccarat Champion! Pong Champion! Block Buster Champion! Alien Invasion 2 Champion! Anti Aircraft Gun Champion! Lotads Lament Champion! Bug Hunt Champion! Chansey Champion! Desert Dash Champion! J&B Snowman Punch Champion! Roving Reporter Champion! Fruity Shuffler Champion! Grab-A-Snack Hurdles Champion! Snowboarding Santa Champion! Cubedelic Champion! Mini Putt 2 Champion! Get-A-Head Champion! Harry Potter: The Marauder`s Map Champion! Hamster Race Champion! JigSaw Puzzle Dog Champion! Graveler Gunblast Champion! Drag Race (tubesocks) Champion! PelPet Champion! Juice Squeezer Champion! Weetabix Games:Cycling Champion! Super Kickups Champion! Spell Catcher Champion! Klingemon Champion! Clash`N Slash Champion! X-Pipes Champion! Flyswatter Champion! Cone Crazy Champion! Bubble Blubbs Champion! Tobby Stick Balance Champion! Conundrum 3D Champion! Cliff Diver Champion! Cone Crazy Champion! Weetabix Games:Running Champion! Spy Hunter Champion! Starfrosch Champion! Live War Champion! Dribble Worldcup Champion! Weetabix Games:Swimming Champion! pursuit Champion! Flash Golf Champion! Red Kens Pigeon Cull Champion! Lumpy Artist Champion! Mini-Putt 3: Jarrassic Park Champion! Pepsi Bucket Launcher Champion! Renault Mr.X Champion! Springfield Snow Fight Champion! Slider Puzzle Champion! Subzero Champion! Extreme Racing Champion! Ultimate Ping Champion!
Member #4923
Cool
nice work, looking good.
"DRIVE AND ENJOY THEM WHILE YOU WORK ON THEM, LIFES TO SHORT"
my toy: 56 4dr 210
ARMY NAM VET (so proud)
carls 56 is offline   Reply With Quote
Old 09-20-2019, 08:03 AM   #138
ChevyGasserMadness
ChevyGasserMadness's Avatar
Member #12118
Great thread with a lot of do it yourself info. I know to attain the stance, performance, and look one has to visualize the result and work backwards. Great information and thanks for walking us through your build. My 38 Coupe is slated for a gasser build . So far it is soda blasted and pretty much apart . Body is in excellent shape with no rust so I'm grateful to be able to skip to the chassis build. I located an original frame that has an 9.3 rear and ladder bars . The front is the original straight axle with a disc brake set up. It is all on hold at this point until time permits. Meanwhile I will be tuning in to your build. It certainly is inspirational , thanks again for your work and posts. Greg.
"I'm Goin' the distance, I'm goin for speed." Cake
ChevyGasserMadness is offline   Reply With Quote
Old 09-20-2019, 06:38 PM   #139
1971BB427
1971BB427's Avatar
Member #16997
Getting the stance right is tough. That's why nothing gets permanently welded on my builds until both the front axle, rear axle, engine, trans, and tires and wheels are all on the car. Then I can look at where it sits, and how it all works together before doing the final welding on front axle, and rear axle.
I've done enough straight axle cars to get a vague idea of where to start, and get it close enough. But never close enough to feel comfortable enough to do the final welds.
Hit the first fall swap meet today! Found some nice old school finned aluminum valve covers, plus chrome alternator bracket, and a pair of 3.5" chrome exhaust tips. Just little bits I know I'll need at some point in the build.
Still need to locate or build a 4 speed automatic shifter for the 700R4, but another 3 or 4 swap meets coming up over the next few months, so hope one shows up.
Old 09-21-2019, 06:22 PM   #140
1971BB427
1971BB427's Avatar
Member #16997
Sold the '70 Mustang 9" rear axle today. Put it on Craigslist, and it took a little over an hour to go away!!!
While I was waiting for the guy to come pick up the old axle, I cut the perches off the 8.8" Ford, and disassembled the spring packs. They had 8 leafs in the packs, which is why it sat up like a 4x4 in the rear! I removed 5 of them, and I'll see how it sits once I have the new axle in and weight on it. Then add springs if it needs more to sit right.
I relocated the spring center pin 2" back, so the wheels will be better centered inside the opening when I radius them.
Similar Threads
*39 chevy do i sell or build it boggesscharles Non Trifive Vehicles 20 02-22-2019 02:07 AM
My 57 Belaire 2 Dr Sport Coupe 39 yr old dream Blazin57 Show us your Trifive 14 11-20-2017 12:14 AM
'39 Pontiac Plexiglas "Ghost" Car Ratpackin Non Trifive Vehicles 5 07-27-2011 10:56 AM
in storage for 39 years. convertible. johnscab TriFive related Ebay auctions and Craigs List, Links to other sale sites 10 06-16-2011 10:08 PM
And It's Only $39.95 ! auggie56 Welder advice, Hand tool Advice Shop Tool. 5 11-14-2009 06:53 PM
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
