Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Electrical Questions and Answers
Electrical Questions and Answers This is the place to ask all your question about electrical problems and instalation issues.
Old 07-16-2017, 11:01 PM   #21
Did you disconnect the lead going to the distributor and connect a test lead there? You need to ground and unground that negative lead and watch for spark from the main coil wire...Don't measure with a meter.
IF you followed the procedures that I gave you correctly, then yes I'd say that the coil is bad.
_______________________________
Old 07-17-2017, 09:24 AM   #22
What David is explaining is to use a jumper on the - terminal of the coil, to act like the points. When you touch the - terminal of the coil to ground, the coil charges, with 12 volts on the + terminal. When the jumper is removed from ground, the coil discharges through the center post of the coil and should produce a spark when the screwdriver is held close to ground.
If you don't get a spark, try the old coil the same way.
Old 07-17-2017, 09:47 AM   #23
THANKS for the back-up Don
Old 07-17-2017, 12:16 PM   #24
remove pertronix Junk and put a good quality msd in its place then enjoy driving your car instead of working on it . I have removed more bad pertronix junk than I have any other ignition including the Mallory unilite.
Old 07-17-2017, 01:58 PM   #25
techguy466
Member #35351
I got a chuckle ou tof that post above, "including Mallory Unilites". I learned a long time ago, from my go to person for ignition stuff, that Unilite is one of the best point replacement units, that NOBODY resists correctly, so, they fail.
What I was told was to use the stock GM resistor or resistor wire as stock, to the coil, then, use the .60 ohm resistor that comes with the Unilite, EXACTLY as Mallory said to do, between coil positive and Unilite red power input wire.
He says it runs the coil at one current level, and the Unilite at a lower one. He also got me to start using a 9 volt lantern dry battery to power up Unilite distributors when I run one to recurve them on my Sun distributor machine. So, I tried a few at his resistor level, what others use, only one resistor, and full volts. NO DIFFERENCE IN OUTPUT AT ALL, but, double resisted, they live long and don't have problems.
I have done that to a couple of my Unilites, and more than a few customer systems, and the failures stopped, the cars did not run one iota different than before.
He also proved to me that PerTronix Ignitors should be resisted with at least the stock GM resistance level, or, they fail.
Just like my ignition man said it would.
Willard Thompson
techguy466 is offline   Reply With Quote
Old 07-17-2017, 02:16 PM   #26
Spirit of '57
Spirit of '57's Avatar
Member #32646
I tested the coil again today as Pops described, and it worked! I got a spark off of the output wire! I mustve been doing something wrong yesterday! This doesnt fix my problem, but it appears the coil could be working okay! I called pertronix about it and they said my lack of an LED flash on the module points to the module being bad or badly grounded.
Spirit of '57 is offline   Reply With Quote
Old 07-17-2017, 04:06 PM   #27
Well, the good news is, at least we have it narrowed down to the distributor now.
Old 07-17-2017, 04:31 PM   #28
Spirit of '57
Member #32646
indeed! I'm pretty happy with this development! so I took a couple pictures of the module in case you guys can see anything that is messed up with it. the blue dust everywhere is from when I had my engine rebuilt, the guy didn't secure the cap properly and the rotor shaved off some of the cap pretty badly. I'm gonna get a new one soonishly!
Old 07-17-2017, 04:37 PM   #29
Spirit of '57
Member #32646
Old 07-17-2017, 04:42 PM   #30
angs1957
Super Moderator
angs1957 has made a donation to the forum!
angs1957's Avatar
Member #2237
I thought when you change out the points system to electronic you had to put a jump on the ignition switch between ign1 & ign2.
angs1957 is offline   Reply With Quote
Tags
no start , pertronix 3
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
