Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Steering , Power and manual- Rack & Pinion - 605
Trifive Steering , Power and manual- Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Old 07-15-2017, 01:24 PM   #1
MrP57
MrP57's Avatar
Member #9195
Default Steering column
After 5/6 years driving my 57, I am thinking about upgrading to power steering. If I do not care about a tilt column, is there any other reason or advantage of buying a new column, or would just installing a new shorter steering shaft in-to the old column be alright, and no problems down the road.
MrP57 is offline   Reply With Quote
Old 07-15-2017, 02:36 PM   #2
irishsteve
Member #43450
If you want the inside of the car to look 57 then sure you could run a new shaft in the old column.Be sure of your measurements,and order one with either the spline,or D at the bottom for hooking it up to the new box with a joint.You will need a bearing of some sort at the base of the column to center the shaft. You will also need to buy/make a lower column mount that bolts to the floor/firewall.
irishsteve is online now   Reply With Quote
Old 07-15-2017, 03:08 PM   #3
Are you shifting on the floor or column?....I found shortening my own for an automatic shift was a tedious process....However, sometimes I'm not the sharpest brick in the drawer.
_______________________________
-I have a vast data base of TriFive restoration & upgrade articles for our members' use....Send me a PM with your requirements and I'll strive to provide what you need...Please include your EMAIL ADDRESS and the topic.
Old 07-16-2017, 11:06 AM   #4
MrP57
MrP57's Avatar
Member #9195
I have a tremec 5 speed, should be a much easer job, i'am guessing.
Old 07-16-2017, 12:10 PM   #5
Yes, it sure is....Use this piece from CCI: http://www.classicchevy.com/chevy-st...1955-1957.html
Here are the instructions:http://www.classicchevy.com/assets/p...evy/53-401.pdf
Old 07-16-2017, 02:47 PM   #6
MrP57
MrP57's Avatar
Member #9195
Thank you PoP's, just what I was looking for.
Old 07-16-2017, 09:09 PM   #7
Jalapeno
Jalapeno's Avatar
Member #4149
Mrp57, not sure it was clear to anyone reading this thread, but to install any aftermarket PS gear, the column itself needs to be shorter. Not just the shaft, but the whole column assembly. This is because the PS gear is larger than the stock manual gear. One of the links provided by David shows how to shorten your existing column, but you can buy simple non-tilt short columns made specifically for trifives for reasonable money. I say this because the column shortening takes a fair bit of skill and precision, as well as equipment like a metal chop saw and a welder. If you are on a budget, have these tools and skills, and/or just wanna do it, go for it, shorten your own. But having done a few myself I can tell you it's a steep learning curve to get it done right. I ruined a few columns at first before I did one that worked halfway decently.
Just FYI.
Jalapeno
Jalapeno is online now   Reply With Quote
Old 07-16-2017, 09:12 PM   #8
Agree with Jalapeno
Done an automatic one myself and it wasn't any picnic
Old 07-17-2017, 07:05 PM   #9
57tim
57tim has made a donation to the forum!
57tim's Avatar
Member #2654
After 60 years a new steering column sure is nice. I like my tilt Ididit column but I am sure the non tilt is just as nice, maybe even the Chinese columns are ok for non tilt.
American Tri-Five Association #462
57tim 327, 700r4, front pw disk, 500 ps, Ididit tilt
www.picturetrail.com/tmneid
57tim is online now   Reply With Quote
Old 07-19-2017, 01:12 AM   #10
sharkey
sharkey's Avatar
Member #3741
I think since you have a floor shift makes the shortening process much easier. I even shortened my own shaft and all is working well. found a bearing for the bottom that centered the shaft in the housing.You can do it for the price of the bearing and a mount (aftermarket floormount). made a piece of plastic to cover the open end at the bottom . cant see it anyway.
sharkey is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
