Old 10-10-2017, 04:31 PM   #1
Belair-o
Belair-o's Avatar
Member #2319
Default New Detent Bracket
Pops mentioned a new detent bracket for column shifting TH350's, etc., aways down in this thread:
https://www.trifive.com/forums/showthread.php?t=168885
I tried the bracket on my shortened OE column (shortened using Ecklers kit), and found it needs some adjusting. The following image shows the installed bracket:
The 90 degree bend in the bracket hits the edge of the shift arm before it can rotate through the full range of motion needed to hit all gears, so I will have to grind off that part of the detent bracket. Not quite sure why they designed the bracket to have the 90 degree bend.
Regards, Doug
Belair-o is online now   Reply With Quote
Old 10-10-2017, 04:40 PM   #2
Regards, Doug
Doesn't that provide another detent for drive so you have to lift the lever again to drop lower than drive.
Old 10-11-2017, 08:15 AM   #3
Belair-o
Belair-o's Avatar
Member #2319
Hi Don,
That may well be, but I'm not understanding why that would be a very good thing? I wish there was a reverse lockout, instead.
Thanks, Doug
Old 10-11-2017, 09:38 AM   #4
Here's a pic of the part from Danchuk:
_______________________________
Old 10-12-2017, 09:55 AM   #5
Belair-o
Belair-o's Avatar
Member #2319
Pops, I think the 2358A detent bracket you show is for the 55-56 TriFives. Following is what you previously posted for the 57's, which is what I installed on my 57.
I don't see the value of the bend on the 57 detent bracket. I agree with Don, that it could serve as a lockout to the lower drive gears, but I am not seeing that as something desirable. Maybe someone will set me straight before I grind it off? The tech guy from Danchuk didn't see the value of me retaining it, and advised I grind it off. Ideas?
Thanks, Doug
Old 10-12-2017, 10:06 AM   #6
Pops, I think the 2358A detent bracket you show is for the 55-56 TriFives.....Thanks, Doug
My bad Doug....Should have realized by your avatar that we were talking about a 1957....Now, I have to wonder why the difference between the two.
The other detent for Turboglides looks like this:
Old 10-12-2017, 11:54 AM   #7
Belair-o
Belair-o's Avatar
Member #2319
Pops,
And to me, those ones are so bulky that they seem worthless on a shortened OE column. Already so tight on fitting in the rag joint, narrow detent bracket, column shift, column, and 500 steering box.
Thanks, Doug
Old 10-12-2017, 12:34 PM   #8
Pops,
Thanks, Doug
Agree...Not to mention that they are over priced.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
