55 Just Arrived - What Radiator Is This? - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Cooling Systems, Radiators, Fans / A/C
User Name
Password
Cooling Systems, Radiators, Fans / A/C Engine Cooling Systems, Radiators, Fans / Shrouds, water pumps, anything cooling related. Air conditioning etc.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 01-22-2013, 08:19 PM   #1
FloridaKash
Member
Member #24232
Question 55 Just Arrived - What Radiator Is This?
Hi Guys, hoping you can help. My 55 just arrived from Alaska... happy to see her again after 3 years. This was my Dad's car, he passed away awhile ago. Even though I have driven it the most, I have no idea what components it has in it.... yes I am embarrassed. But, I know you fine guys will become my hotrod family.
The car overheats when it idles or in stop and go traffic. Does not overheat when cruising down the road. I figure either A) The Radiator is too small or B) Not enough airflow on the radiator. I have included pics. I think I definitely need a fan cowling, but I have no idea what Radiator I have and if the fan is large enough. Please see the pics and let me know your suggestions on having this thing run cool when idling.
Hope the pics work.
FloridaKash is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-22-2013, 08:27 PM   #2
Rapper57
Senior Member 1 Gold Star
Rapper57's Avatar
Member #26430
Cool
You've got air conditioning in that car. That's an AC condenser. The other cooler, the smaller one could be an oil cooler? I don't think it's transmission. Have you checked your thermostat? Do you know your water temp?
You may need an electric fan for a boost.
__________________
"Don't apologize, it's a sign of weakness" John Wayne; She Wore a Yellow Ribbon
Rapper57 is offline   Reply With Quote
Old 01-22-2013, 08:32 PM   #3
Chrome Lugnut
Trifive Leaders Club
Chrome Lugnut's Avatar
Member #14896
Default
Need Bigger fan and Fan Shroud,
Fans Up To 17" Diameter
__________________
Les AD1 USNR-R
Sometimes the things that may or may not be true are the things that a man needs to believe in the most: that people are basically good; that honor, courage, and virtue mean everything; that power and money, money and power mean nothing; that good always triumphs over evil; that love, true love, never dies... No matter if they're true or not, a man should believe in those things because those are the things worth believing in."Hub McCann Secondhand Lions"
Chrome Lugnut is offline   Reply With Quote
Old 01-22-2013, 08:45 PM   #4
FloridaKash
Member
Member #24232
Default
Yeah buddy, I was excited that it already has A/C. I think the other cooler may be a transmission cooler, but I do not know.
So you guys think a bigger fan.... 17" (is that the biggest I can go) and a shroud would help? Do they make shrouds that fit without being fabricated and look good?
I would like to avoid an electric fan if possible. Seems like it would be more difficult to install. But with the Florida Summers..... it might be a requirement.
Old 01-22-2013, 08:52 PM   #5
hammecl
Senior Member 2 Gold Stars
hammecl's Avatar
Member #22751
Default
I'm sure everyone else has pretty much covered it..
1) Need a shroud and larger fan.
2) Not enough air getting through the radiator
3) larger cooler is A/C and the smaller is a transmission cooler
Cliff
hammecl is offline   Reply With Quote
Old 01-22-2013, 08:53 PM   #6
Rapper57
Rapper57's Avatar
Member #26430
Exclamation
Well, the issue is, when you use your AC, you'll be dragging even more heat across the radiator. Even with a lower t'stat setting, you may need more cooling. I suspect the other cooler is an oil cooler, to remove more heat from the engine.
If you know of a good engine shop in your area, you may want to drop in on them with that set up. Cooler is better!
__________________
Old 01-22-2013, 09:12 PM   #7
Chrome Lugnut
Member #14896
Default
How big is that fan. I looks like one used on car that had electric fan also.
Yes Bigger fan and shroud would help. The Radiator looks big enough.
Having all the other coolers in front helps it heat up. But with right fan and shroud you may find it works fine.
shrouds
http://www.classicchevy.com/chevy-fa...1955-1957.html
http://www.classicchevy.com/chevy-ra...1955-1957.html
__________________
Les AD1 USNR-R
Old 01-22-2013, 09:18 PM   #8
karaokekng
Senior Member 1 Silver Star
karaokekng's Avatar
Member #6705
Post
Something don't look exactly right about the fan blades in a couple of the pictures. Looks like they are overly bent, or is that just the way I'm looking at them?
Bill
karaokekng is offline   Reply With Quote
Old 01-22-2013, 09:19 PM   #9
RSpring
RSpring's Avatar
Member #5505
Send a message via ICQ to RSpring
Default radiator
I had a stock rad., in my 55, thats what you have , I also had heat prob,s lot of the stock ones would overheat in traffic. Cliff has the right idea, if you can afford it a bigger radiator wouldhelp a lot,,Dick
RSpring is offline   Reply With Quote
Old 01-22-2013, 09:27 PM   #10
acardon
acardon's Avatar
Member #1888
Default
Quote:
Bill
I was thinking the same thing. It looks like that fan would churn more air than pull it through the radiator.
That's NOT a stock radiator. It looks like a 4 core Desert Cooler.
Since it's not overheating going down the highway, the thermostat is working OK.
I agree, a shroud would help a lot, along with a different fan. The shroud pictured is available from Ecklers down in your part of the country. ....http://www.classicchevy.com/catalogs...roud&x=43&y=17
__________________
Don
Sent from my 1981 IBM 5150 PC.
acardon is online now   Reply With Quote
Sponsored Links
Advertisement
Reply
Tags
cooling , radiator
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
