Old 03-03-2017, 05:14 PM   #11
Dragsix
Dragsix's Avatar
Member #20785
Its a nice looking hot rod is what it is!
Dragsix is online now   Reply With Quote
Old 03-04-2017, 12:06 AM   #12
duke57
duke57's Avatar
Member #7459
Here use this calculator to figure tire size. Just click on "Front Tire Calc' do the measurements and plug them in.
http://tri-5.chevyrides.com/front_tire.php
♫♪Duke♪♫
My build thread: http://www.trifive.com/forums/showthread.php?t=132120
Photos of my garage build: http://www.trifive.com/forums/album.php?albumid=4604
My car 86 - 2011
duke57 is offline   Reply With Quote
Old 03-04-2017, 07:57 AM   #13
shubox56
shubox56's Avatar
Member #3660
Default Another front height question..
Originally Posted by Rick_L View Post
X2 on what acardon said. Dropped spindles don't have the anchor bolt provision at the top.
Rick, are you saying that the mounting bolt at the top of the William Chassis Works spindle indicates it's not a drop spindles? I'm not sure if I'm interpreting your response correctly.
Sent from my iPhone using Tapatalk Pro
shubox56 is online now   Reply With Quote
Old 03-04-2017, 08:37 AM   #14
55 Tony
Member #22177
You really should use measurement "A" for the ride height. Factory is 9.41".
http://www.trifive.com/garage/57%20C...Manual/3-3.gif
1955 Bel Air Sport Coupe
55 Tony is online now   Reply With Quote
Old 03-04-2017, 08:38 AM   #15
55 Tony
Member #22177
And from the picture, it looks factory to me.
Old 04-10-2017, 01:57 PM   #16
Longbranch
Member #28007
Originally Posted by Longbranch View Post
Greetings. My "new to me" '55 crossmember shows 6 1/4" from front edge of crossmember to floor with BFG 205/60/15 tires up front. Rear are 295/50/15.
I was told by former owner it had 2" drop spindles, but I'm wondering if maybe just low profile front tires? Center of wheel opening to floor is 25 5/8" and tires just about 24" diameter.
Question is do members think I might be able to put a taller tire up front without rubbing anywhere in the fender? Thinking a 205/65 maybe.
From what I'm reading cars with 2" drop spindles seem to have much less crossmember clearance than mine (6+"), tire diameter depending of course.
Turns out I don't have dropped spindles after all, simply cut coil-springs. Two coils it seems. Replacing with Moog 638's. Looking forward to getting the front end together this week and see where it sits. I'll decide about a taller front tire than the 205/60/15's currently on.
Longbranch is offline   Reply With Quote
Old 04-13-2017, 03:38 PM   #17
TSACCO
TSACCO's Avatar
Member #42691
I am running 205/70R15 with 2 inch spindles and one coil cut no rubbing at all room for more tire if needed
TSACCO is offline   Reply With Quote
Old 04-21-2017, 10:38 AM   #18
Longbranch
Member #28007
Default New coils.
We finally got around to getting at the front suspension on my '55. Turns out only the coils had been cut in order to drop the front and not true "drop spindles" as previous owner said. I used Moog 638 coils which brought the front end up nicely (in my opinion). I like how it sits, but driverside is 1" lower than passengerside. Ok for now, but like to have it even. Question is how? Add spacer to driverside or cut passengerside coil?
I'm thinking of replacing the 205/60/15 front tires with 205/70/15's so maybe best to do that first and check for clearance....Hmmmmm. Think I'm over analyzing this a little.
I'll get a front pic later.
Old 04-21-2017, 11:09 AM   #19
57tim
57tim has made a donation to the forum!
57tim's Avatar
Member #2654
Looking at your pics, it looks to me like your passenger rear is lower then the drivers rear, judging by the amount of wheel exposed on both rear wheels.
It might be an optical illusion however. If what I see is true, that would effect the ride height it front.
American Tri-Five Association #462
57tim 327, 700r4, front pw disk, 500 ps, Ididit tilt
www.picturetrail.com/tmneid
57tim is offline   Reply With Quote
Old 04-22-2017, 12:28 AM   #20
Longbranch
Member #28007
Default level
From this front pic and by eyeball it looks pretty level to me though measures about an inch higher on passenger side.
Measures about 1/2 inch higher at rear passenger side.
Think I can live with that.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
