Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Welcome to Trifive > Garages Bodyshop or Work Area
Garages Bodyshop or Work Area Tell us about your garage or bodyshop , the tools you use anything around the shop equipment and Tips. Or anywhere you work on your projects.
Old 02-17-2017, 12:07 PM   #11
abdiver7777
abdiver7777's Avatar
Member #35808
Originally Posted by copymutt View Post
If a slab is poured on a properly back filled and compacted gravel substrate a percentage of that is voids between the gravels in which air can move when either radon mitigation or humidity control is effected by creating a low pressure air exchange.
This last summer we removed and replaced a slab that had cracked and heaved in a residence. The slab was poured by someone ignorant, contained no rebar, no vapor barrier, on top of expansive clay with negative grading around the home. A recipe for disaster. When the slab was cut out a large section was suspended 4" above the clay which had receded.
When I built may garage I over excavated both footers and slab base and replaced this with abc fill and compacted gravel all because of clay. If you don't know your type of soil a call to a soils engineer can save you thousands of dollars.
Dealing with someone else's foundation mistakes is never cheap or fun.
Jim
Good decisions and wisdom come from bad decisions and experience.......
abdiver7777 is offline   Reply With Quote
Old 02-17-2017, 02:51 PM   #12
mr 265
mr 265 has made a donation to the forum!
mr 265's Avatar
Member #10768
I bought a $20 fan from WalMart it runs 24-7 for the past 9 years I never shut it off ,the best 20 bucks I ever spent ,,,
mr 265 is online now   Reply With Quote
Old 02-17-2017, 07:18 PM   #13
big wrench
big wrench's Avatar
Member #25529
During storage I put visqueen under car even with plastic under cement.
big wrench is offline   Reply With Quote
Old 02-17-2017, 08:50 PM   #14
abdiver7777
Member #35808
Just Curious.... do you collect water between the concrete and plastic?
Old 02-17-2017, 08:58 PM   #15
I thank God for being in Texas. Believe it or not, even with all our humidity and having ground water really close to the surface - we usually don't have these problems with concrete slabs. Don't even require a vapor barrier.
How does radon figure into this? I don't hear much about it anymore, figuring it was one of the myths/scares whose time had passed. And again, maybe it's just not a regional problem.
Rick_L is offline   Reply With Quote
Old 02-17-2017, 09:35 PM   #16
copymutt
copymutt has made a donation to the forum!
copymutt's Avatar
Member #36997
Radon, a gas is the natural decomposition result of radium in the soil/Rock. Living in Co. we are #7 in the US for remediation.
Lived in my current home for 40 years. Looking to relocate and decided to explore this. Just got the results, our test showed 7 pico curries. EPA sets remediation required at 4. My results are very low for this area. As we've not yet developed lung cancer. Radon is supposedly the #2 cause behind smoking) I'm electing do do nothing. I'm skeptical of any gov. entity establishing safe levels for exposure.
Jim
copymutt is offline   Reply With Quote
Old 02-19-2017, 12:10 PM   #17
'56 Sedan Delivery
'56 Sedan Delivery's Avatar
Member #26111
Originally Posted by gpachner View Post
Is there anything I can put down on my slab to keep the humidity away from my car? Whoever poured the concrete must not have put down a vapor barrier.
Are your perimeter drain pipes/tiles in good shape?If they're plugged
or collapsed this will cause moisture to penetrate up through the slab.
There should be some type of concrete sealer to help keep the moisture
from coming through if there isn't a vapor barrier under the slab.
Doug
'56 Sedan Delivery is offline   Reply With Quote
Old 02-22-2017, 12:57 AM   #18
gpachner
Member #43462
A contractor buddy of mine also suggested visqueen. I had never heard of it but it's much cheaper than the 300.00 rubber mats I saw online. I would hate to go through all the work of laying epoxy down just to have it fail. I like the fan suggestion as well. Thanks for all the help my friends.
gpachner is offline   Reply With Quote
Old 02-22-2017, 04:58 PM   #19
John McGraw
John McGraw's Avatar
Member #29638
There is a surefire test to tell you whether the moisture is coming from under the slab, or from the air. Take a 2' X2' piece of 6 mil plastic and tape it tightly to the floor with duct tape on all 4 sides. Pull it up after a day or two, and if the plastic is dripping wet on the side that was against the concrete, then the moisture is coming from under the slab. If not than the moisture is condensing out of the air.
This is the standard test we use in commercial buildings to determine water vapor migration. An awful lot of dampness on a slab is due to the slab getting cold for quite a while, and then the weather changes and gets warmer and more humid. The cold slab will make the moisture condense out of the air just like on the outside of a glass with a cold drink in it. The only thing that will help in this case, is conditioning the space.
Regards, John McGraw
John McGraw is offline   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
