Missing headline bow? - Page 2 - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Interiors Questions and Answers
Interiors Questions and Answers Ask all your Interior questions here, Custom Interiors or Original Interiors this is the place to get advice and give advice.
Old 01-11-2020, 04:41 PM   #11
Had a few Tri 5's
Had a few Tri 5's's Avatar
Member #6536
That is correct, and the first one you put in. You center the "bow/rod" in the proper listing. Then you center that listing in the roof. The sharp points poke through the listing right next to the bow to hold it. Start in the center and poke the points through working toward the sides, gently stretching the headliner. Once it is stretched across the pointed tabs, the tabs get bent up to hold the "bow/rod" in place.
You have to stretch the headliner side to side on this one as you go since the listing cannot slide once the pointed tabs are poked through.
After that, snap the rest of the bows up into place.
I usually mark the center of the headliner of that listing and the center of the top. This ensures the headliner starts out centered.
Had a few Tri 5's is offline   Reply With Quote
Old 01-12-2020, 09:15 AM   #12
Belair-o
Belair-o's Avatar
Member #2319
Thanks, I really appreciate all the tips. I sort of understand the process, but having never installed a headliner, all the guidance helps me better understand what to do.
Thanks, Doug
Belair-o is offline   Reply With Quote
Old 01-12-2020, 06:32 PM   #13
the_lemon
Member #40742
I am curious if you are going to replace you headliner yourself of are you going to have a shop do it? If you are going to do it yourself, I just did mine over labor day weekend and can give you some advice and pointers. Dano
the_lemon is offline   Reply With Quote
Old 01-13-2020, 08:49 AM   #14
Belair-o
Belair-o's Avatar
Member #2319
I figure to do the work, and am in the process of stripping the tack strip stuff out of the car. I am slow, so after I get that part done, I would like to take you up on your offer (and GaryC on his offer). I will PM youse guys when I get the new tack strips in, as if you tell me now, I will forget before I get to the actual headliner install. The oxen are slow, but the earth is patient!
Thanks! Doug
Old 01-13-2020, 04:57 PM   #15
Had a few Tri 5's
Member #6536
Default Couple things I did
Just a tip....I recently did my tack strips. If you are going to use contact cement in addition to screws or rivets, take some 80 grit sandpaper to the cemented side of the strip so it will bond. Also, use a heat gun to form the strips around the curves. Heat it, bend it, hold it or dunk it in cold water till cool. It will hold the shape fairly well for attaching.
Old 01-14-2020, 11:12 AM   #16
Belair-o
Belair-o's Avatar
Member #2319
Thanks for the tip! Yesterday I stripped out the old tack strips, and found the strips in the tack strip kit I bought a few years back don't match the originals dimensionally. The side strips are thinner, and narrower by at least 3/16" in each dimension. Seems like I should find strips with a better fit than that so the strips stay put; ordered replacement strips for the sides. I assume one just uses the tabs to hold the side strips in place (no cement). The thin strip for the back window was too wide (like hotrodg726 said in a post might be the case), so cut the width down to better fit. The thin strip for the front looks like no width trimming is necessary.
Thanks, Doug
Old 01-14-2020, 11:23 AM   #17
chevman57
Sr. Administrator
chevman57 has made a donation to the forum!
chevman57's Avatar
Member #264
Doug, some upholstery shops will have the plastic convertible top tack strip in stock. It comes in 2 widths and thicknesses and works real well. Easy to cut on a band saw for modifying.
http://s1181.photobucket.com/albums/x437/chevman57/
http://www.cardomain.com/id/chevman57
https://www.trifive.com/forums/album.php?albumid=1177
1957 2dr sedan Bel Air, owned since 1978
1972 Chevelle Malibu, awaiting rebuild,owned since 1979
chevman57 is online now   Reply With Quote
Old 01-14-2020, 01:31 PM   #18
Belair-o
Belair-o's Avatar
Member #2319
Great, thanks Terry!
I live out in the sticks, so ordered some online. Hopefully the quoted measurements will equal reality.
Thanks, Doug
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
