an fittings - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Old 01-29-2020, 09:17 PM   #1
sanfredan
Member #19224
Default an fittings
I need to install a fuel press reg. What an fittings are the best, areoquip , russel , earls etc. Thanks
sanfredan is offline   Reply With Quote
Old 01-29-2020, 10:03 PM   #2
they are all about the same if you stick with the name brands. there is a seller on ebay fassterllc that has some more affordable stuff at good prices.
heres a link https://www.ebay.com/sch/fassterllc/...72.m2749.l2654
Old 01-29-2020, 10:15 PM   #3
DHR Darren
Member #21537
If you do not care about weight, go with a high quality stainless steel fitting.
DHR Darren is offline   Reply With Quote
Old 01-29-2020, 10:22 PM   #4
For the most part, there is no practical functional or appearance difference in the name brands of adapter fittings. But there are exceptions.
There is a bigger difference in the hoses and hose fittings, but this also varies with the type of hose. Also the quality or even existence of specialty products varies. Generally I stay away from Russell.
Also be sure you are buying the right product, no matter the brand, for the purpose. For instance, with power steering, stick with steel fittings.
Old 01-30-2020, 01:09 AM   #5
NickP
NickP's Avatar
Member #2134
Fragola Performance Systems Fuel Line Adapter Fittings has a proven track record.
“Luck is what happens when preparation meets opportunity.”
NickP is online now   Reply With Quote
Old 01-30-2020, 08:09 AM   #6
Old Buzzard
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
^^^ This. Fragola is used on all our "stuff"..
Injector inspector.
55 210 sedan, rust bucket. The last hoorah!
Hotrodding and dragracing since 1955.
USAF, 67th Recon Tech. Yokota AFB, Japan.
6594th Test sqdn, Westover, AFB, MA. The guys that brought you the Cuban missile pics. 1960-64.
Old Buzzard is online now   Reply With Quote
Old 01-30-2020, 08:53 AM   #7
DHR Darren
Member #21537
Call Orme Bros. In Simi Valley Ca. They will hook you up with the right stuff at a great price not just stuff at a cheap price.
Old 01-30-2020, 09:05 AM   #8
55 Tony
Member #22177
I recently bought a used carb that came with AN fittings and line for duel feed and a main line. I took it all off and ran rubber hose. The AN fittings had too much metal and extra volume of fuel it held. With all the boiling fuel problems I've had in the past, it's a no go on my car.
1955 Bel Air Sport Coupe
55 Tony is online now   Reply With Quote
Old 01-30-2020, 10:09 AM   #9
alhewitt
alhewitt's Avatar
Member #37639
I can't speak to fuel vapor being more pronounced in metal vs. rubber fuel lines
however very few GM factory engines came with rubber fuel lines. Further they used brass or steel fittings/lines and not aluminum. Maybe its just me but the risk of fire with rubber seems greater so I'm a steel fuel line guy.
AN or Army Navy, I believe is a mil spec aviation standard from WW2. If the fittings are true AN they must meet this specification... Al
alhewitt is online now   Reply With Quote
Old 01-30-2020, 11:53 AM   #10
55 Tony
Member #22177
Aluminum conducts heat much better than rubber. Plus the T fitting was a big long piece. If vapor does occur, if it's a large volume there is more of a chance of the fuel bowl not having enough time to purge itself via the needle and seat and the vent tube. Millions and millions of cars were built with rubber fuel lines and millions still are.
I admit, I did screw up. I normally use the tougher FI hose instead of the regular hose. I might change it someday. The way most of us look after our cars, it would be pretty rare for a rubber hose to develop a crack without us seeing it before it turns into a leak. Well that goes for me anyway.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
